Need Sub advice - under $1500 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 02-12-2013, 09:38 PM - Thread Starter
Kevin_Roy's Avatar
Hello,
Can someone give me some ideas of a good sub under $1500 to go with Paradigm Studio 100 v3's. My receiver is a Pioneer Elite SC-55. I have the original Paradigm Servo-15 but I think it is finally going.
Kevin
Kevin_Roy is offline
post #2 of 6 Old 02-12-2013, 10:02 PM
nashou66's Avatar
Quoted: 89 Post(s)
Liked: 103
nashou66 is offline
post #3 of 6 Old 02-12-2013, 10:45 PM
jbrown15's Avatar
Quoted: 2523 Post(s)
Liked: 1993
Take a look at the FV15HP, you would need almost three of the SVS PB12-NSD's to equal one FV15HPs.
Here's the number of both subs to would show this.
http://www.data-bass.com/data?page=system&id=66&mset=71
I would also look at the PSA XV30 if its size and looks don't bother you.
jbrown15 is offline
post #4 of 6 Old 02-12-2013, 10:54 PM
justindo's Avatar
I'm looking in this price range as well and have narrowed down my search to the Rythmik F15HP and the PSA XS30 (both sealed), but the ported versions of each have more output.
justindo is offline
post #5 of 6 Old 02-13-2013, 08:37 PM
mikepos's Avatar
Quoted: 24 Post(s)
I have a rythmik FV15HP in an 18x14x8 foot room in a system with PSB Stratus Gold mains on Brytson 3bst amps. The sub blends fantastically with the Golds for movies and music and I haven;t even set it up properly yet. I've heard your speakers in a decent room and they're slightly less warm than mine, and slightly more detailed. Based on how the sub sounds in my system I'd expect you to get a perfect match. I replaced a Hsu vtf3mk2 and the difference was phenominal, I highly recommend the rythmik. I was a bit hesotant on getting the vented sub but it sounds fantastic with music, cleaner and slighlty punchier than running the Golds without the sub, and the golds are very capable down low.
Oppo BDP-105
Bryston 3B-ST 2ch on mains, Lexicon 512 5ch
PSB Stratus Gold mains, C6i center
Rythmik FV15HP
Paradigm ADP-370 surrounds
cheap energy rear speakers
mikepos is offline
post #6 of 6 Old 02-14-2013, 07:23 AM
dstew100's Avatar
Rythmik FV15HP or PSA XS30. I love my Rythmik
dstew100 is offline
