subwoofer recomendation - AVS Forum | Home Theater Discussions And Reviews
post #1 of 22 Old 02-13-2013, 06:01 AM - Thread Starter
milll36's Avatar
Hi i need to buy subwoofer for my master bedroom. i have around 3400 sq foot. Im looking at these options:
2 Triad Silver Dsp Subs
2 MK 12 Ultra Sub( New Model)
other option can be
PB 13 ultra i like it but i think the size its huge for a bedroom don't know how many i need
or the new SB 13 ultra also don't know if i need 1 or 2 ...
whats your suggestions?
Daniel
milll36 is offline
post #2 of 22 Old 02-13-2013, 06:10 AM
BeeMan458's Avatar
Liked: 813
The need for SVS, Ultra's is for power and authority in replicating movie sound tracks. Unless you like it incredibly loud in your bedroom, you won't have need for a pair of "Ultra's"
You state they're going be used in the master bedroom, how loud do you want it? Is this your main viewing venue as opposed to a living room/family room situation? Just saying, in my opinion, for normal use, a pair of Ultra's is a lot of subwoofer system for a master bedroom based listening environment.
BeeMan458 is offline
post #3 of 22 Old 02-13-2013, 06:13 AM
Prime316's Avatar
Quoted: 185 Post(s)
Liked: 205
Your bedroom is 3, 400 sq feet?
Projector: Benq W1070 1080p 2D/3D
AVR: Denon X2200W
Mains: Klipsch RF-62ii x 2
Center: Klipsch RC-62ii
Surrounds: Klipsch RS-42ii x 4
Subs: Dual Hsu VTF-15H's
Prime316 is offline
post #4 of 22 Old 02-13-2013, 06:18 AM - Thread Starter
milll36's Avatar
sorry is 3400 cubic feet
I have already a 108 inch screen in my master, I'm choosing my speakers at the moment, thinking on either triad gold lcd in room, or rbh 8300 se . Its mostly for movies and tv shows,for music i use my den.
Daniel
milll36 is offline
post #5 of 22 Old 02-13-2013, 06:20 AM
BeeMan458's Avatar
Liked: 813
Daniel
If mostly for movies, again, much of your choice is dependent on available budget and how loud you want it and at this point, first things first, one must have a budget to move forward with recommendations.
post #6 of 22 Old 02-13-2013, 06:30 AM - Thread Starter
milll36's Avatar
budget can be around 2000 to 3000..
from what i spending on the speakers i need to have good lows on the room... the wife won't hear it to loud but i like to go loud when watching movies...so what a good setup.
milll36 is offline
post #7 of 22 Old 02-13-2013, 06:36 AM
BeeMan458's Avatar
Liked: 813
In this price range one has many excellent choices but to make the proper recommendation, the $3,000.00 limit may get broken by a bit.
If you need good lows, in a room that size, in the simple, pressurization might take three or four subs. It will depend on if the room is open, high ceiling or closed with low ceiling. If going with two subs, based on your above, a PSA, XV30 comes to mind. Now I have to ask about wife approval (physical appearance) and how much room do you have for subwoofer boxes as these are large boxes.
In your price range, one will find some beautiful and functional subs but in your price range, you'll only be able to get one of these beautiful subs and subs best serve their acoustical purpose in quantities of two or more due to the acoustical (sonic) room smoothing, multiple subs provide.
post #8 of 22 Old 02-13-2013, 06:43 AM
eljaycanuck's Avatar
Quoted: 1346 Post(s)
Liked: 1962
eljaycanuck is offline
post #9 of 22 Old 02-13-2013, 06:52 AM - Thread Starter
milll36's Avatar
this is a hand made sketch of the room.
milll36 is offline
post #10 of 22 Old 02-13-2013, 06:59 AM
BeeMan458's Avatar
Liked: 813
From that image, I'd go with three subs. One in each corner, to the side of the bed and one under the movie screen.
How hard can you realistically push your budget?
You want multiple subs to fill in sound voids that naturally occur and it's a lot of effort to fill these nulls in. Hence why four subs is the minimum ideal. Everything is about the Benjamins, that I understand but on the other hand, subwoofer acoustics don't care so we serve them as opposed to them serving us. They think they're cats. tongue.gif
post #11 of 22 Old 02-13-2013, 07:03 AM - Thread Starter
milll36's Avatar
well i could prewire for 4 subs and start with 2 .. and take it from there..if i feel that i need more ill buy them later in a couple of months, let the bank account grow a little bit again..lol
milll36 is offline
post #12 of 22 Old 02-13-2013, 07:16 AM
Liked: 1962
Four subs is the minimal ideal? Less than two weeks ago, the standard was a two sub system. confused.gif
OP, fwiw, I run two sealed subs @ ~475W/sub in a 3,375 cu.ft. basement (laminate over concrete) room. They're more than "minimally ideal", even though (IMO) they don't come close to offering the kind of performance you can get from subs like the ones I listed earlier.
post #13 of 22 Old 02-13-2013, 07:25 AM
BeeMan458's Avatar
Liked: 813
Originally Posted by eljaycanuck View Post
The recommended minimum standard should not be confused with the recommended minimum ideal. Two subs is the minimum recommended standard but one sub on the middle of each wall is considered the "minimum" ideal.
post #14 of 22 Old 02-13-2013, 07:31 AM - Thread Starter
milll36's Avatar
so if going with two at the moment, what would be the best position for them, also with models would you suggest?
milll36 is offline
post #15 of 22 Old 02-13-2013, 07:38 AM
Liked: 1962
You weren't able to substantiate your "minimum recommended standard" claim: Although you did state that "many acoustical studies have been done", you didn't provide a link to any generally-accepted standards document or study.
Could you at least substantiate your "minimum ideal" claim? Could you please provide a link to a generally-accepted standards document or study which supports your assertion that "one sub on the middle of each wall is considered the 'minimum' ideal"?
post #16 of 22 Old 02-13-2013, 07:39 AM
Louquid's Avatar
Liked: 38
These are self imposed standards and "minimums". Of course multiple subs will sound better than a single in any room, but that doesn't mean a single wouldn't sound good/great. I think most agree that two subs are better than one, and that four may be better than two, but they wouldn't suggest someone up their budget of $3000 in order to have four subs. Four subs in a bedroom I might add.
I think the OP could go with duals of the Rythmik FV15HP, PSA XV30, HSU VTF-15H, or SVS PB12-Plus. Any of those subs would be awesome
Louquid is offline
post #17 of 22 Old 02-13-2013, 07:41 AM
Reefdvr27's Avatar
Quoted: 1579 Post(s)
Liked: 1063
I have dual Power Sound Audio XV-30's and I love them. They are priced well and two of the best guys in the buisness to deal with!! If you have the room and want deep powerful bass, XV-30's are your sub!
Reefdvr27 is offline
post #18 of 22 Old 02-13-2013, 07:42 AM
BeeMan458's Avatar
Liked: 813
Assuming no complaint from Big Momma, better know as the "Wife Approval Factor" (WAF) a pair of either of the below:
PSA, XV30 or XS30
Rythmik, F15, F15HP or FV15HP
SVS, PC13-Ultra, SB13-Ultra
And based on all you've shared, if Big Momma will go along with my recommendation, I'd give first consideration to a pair of the XS30's. All recommendations should come close to your stated max of $3k and yes, I know I've pushed the budget boundary a bit but in doing so, hopefully I'm giving you the best possible recommendations within your stated parameters.
post #19 of 22 Old 02-13-2013, 07:49 AM
Louquid's Avatar
Liked: 38
The positions would be best determined once you have them and can do a bit of testing. Literally just trying different positions until you find the most ideal.
Louquid is offline
post #20 of 22 Old 02-13-2013, 07:49 AM - Thread Starter
milll36's Avatar
waf factor didn't mind on the sb13 ultra.. the pb13 she said it looks to big.. its only 5 inches more lol for me is nothing but she didn't like it.. if i compare those two what would be the difference?
Tks
Dan
milll36 is offline
post #21 of 22 Old 02-13-2013, 07:52 AM
Liked: 1962
Since you're looking at two right off the bat, I'd go with the Rythmik FV15HP. It's a very well-regarded sub. As for placement, I can't really say. If it were me, I'd start with symmetrical placement on the display wall. I'm a sucker for symmetry. smile.gif
Realistically, I think you'd need to do a sub crawl to find optimal placement locations and experiment with the ones that offer the best compromise between output, FR, placement restrictions, etc.
post #22 of 22 Old 02-13-2013, 08:21 AM
BeeMan458's Avatar
Liked: 813
IIRC, price, size and appearance aside, in a room when cranking, the performance should be close with normal sealed vs ported being considered. As a suggestion, give SVS a call and ask.
