driver replacement for hsu sft-1? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 02-13-2013, 10:15 AM - Thread Starter
roccol's Avatar
Quoted: 20 Post(s)
I recently replaced the plate amps on two HSU SFT-1s(both were blown). The amps work great. However, one of the drivers are somewhat blown. These do not look like the greatest drivers, so I'm not looking to spend a bunch of money and buying from HSU at this point is out of the question. I am looking for an adequate replacement driver for the faulty unit. Does anyone know if something like below will work well?:
http://www.parts-express.com/pe/showdetl.cfm?partnumber=295-484
http://www.parts-express.com/pe/showdetl.cfm?partnumber=295-200
roccol is offline
post #2 of 6 Old 02-13-2013, 10:31 AM
Bill Fitzmaurice's Avatar
Liked: 4459
The only way to know what will work in the cabinet is via software response modeling of the cab. The only way to know if something might work better than the original driver is to software model it, which requires knowing the T/S specs on the driver.
Bill Fitzmaurice is offline
post #3 of 6 Old 02-13-2013, 11:19 AM - Thread Starter
roccol's Avatar
Quoted: 20 Post(s)
Yes I understand this. I figured someone would know this considering the popularity of the products in question.
roccol is offline
post #4 of 6 Old 02-13-2013, 11:21 AM - Thread Starter
roccol's Avatar
Quoted: 20 Post(s)
THIELE-SMALL PARAMETERS
Resonant Frequency (Fs) 31 Hz
DC Resistance (Re) 3.2 ohms
Voice Coil Inductance (Le) 1.16 mH
Mechanical Q (Qms) 3.10
Electromagnetic Q (Qes) 0.45
Total Q (Qts) 0.39
Compliance Equivalent Volume (Vas) 1.35 ft.³
Mechanical Compliance of Suspension (Cms) 0.62 mm/N
BL Product (BL) 7.7 Tm
Diaphragm Mass Inc. Airload (Mms) 42.4g
Maximum Linear Excursion (Xmax) 6 mm
Surface Area of Cone (Sd) 208.7 cm²
Resonant Frequency (Fs) 30.2 Hz
DC Resistance (Re) 3.53 ohms
Voice Coil Inductance (Le) 1.76 mH
Mechanical Q (Qms) 5.86
Electromagnetic Q (Qes) 0.35
Total Q (Qts) 0.33
Compliance Equivalent Volume (Vas) 1.19 ft.³
Mechanical Compliance of Suspension (Cms) 0.53 mm/N
BL Product (BL) 10.1 Tm
Diaphragm Mass Inc. Airload (Mms) 52.5g
Maximum Linear Excursion (Xmax) 8.8 mm
Surface Area of Cone (Sd) 213.8 cm²
roccol is offline
post #5 of 6 Old 02-13-2013, 11:25 AM - Thread Starter
roccol's Avatar
Quoted: 20 Post(s)
I think the woofer may still be covered under warranty.
roccol is offline
post #6 of 6 Old 02-14-2013, 06:13 PM
cel4145's Avatar
Quoted: 2599 Post(s)
Liked: 2956
I think HSU's drivers are warrantied for 7 years, aren't they?
Meanywhile, if you've blown two amplifiers and one driver, sounds like you need bigger subs. smile.gif
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | NAD HP50 | AKG K550 | Soundmagic E50 & E80 | DX50 | E12 | X1
cel4145 is offline
