Yamaha NS-W210 only left channel? - AVS Forum | Home Theater Discussions And Reviews
Old 02-14-2013, 12:49 AM - Thread Starter
lanceinnola's Avatar
I have an Onkyo TX-8050 stereo reciever with four Boston Acoustics A Series bookshelf speakers and a Yamaha NS-W210 sub.
For some reason the sub output is only out of the left channel...is this normal?
I bought the Onkyo refurbished. If there is a problem could it be the Onkyo or the Yamaha or possibly the sub cable?
Any help would be greatly appreciated.
- Lance
lanceinnola is offline
Old 02-14-2013, 11:19 AM
Tom Vodhanel's Avatar
Quoted: 1599 Post(s)
Liked: 4560
- Lance
1)Do you have the subwoofer output of the receiver connected to a RCA input on the sub?
If not, how is the subwoofer connected?
If son, how did you determine that the subwoofer is only reproducing the signals from the "left channel"?
Tom V.
“The bitterness of poor quality remains long after the sweetness of low price is forgotten" --- Ben Franklin
Tom Vodhanel is offline
Old 02-14-2013, 11:37 AM
eljaycanuck's Avatar
Quoted: 1246 Post(s)
Liked: 1825
I can't find a Yamaha NS-W210, but I can find an NS-SW210. It appears to have a single LFE input (as well as a gain knob and a power button). The Onkyo AVR has three different pre-outputs: L+R main-channel out; subwoofer out; and Zone 2 out.
OP, are you running a connection from the output circled in red (below) on your AVR, to the input on the sub?
- If 'no', try this connection.
- If 'yes', then perhaps you need to: try a different cable; raise the gain on the sub itself; check some settings in the receiver's speaker set-up menu.
eljaycanuck is offline
Old 02-26-2013, 11:01 AM - Thread Starter
Thanks guys, you are right, I had it plugged into standard left channel pre-out as eljaycanuck's diagram suggests. Plugging it into the sub pre-out fixed things, doh! Btw, I bought the receiver from Accessories4less. Have you guys ever bought from them before? And if so, turnouts were good? Thanks again for all your efforts in helping out.
