SVS PC12-PLUS Disappointment - AVS Forum | Home Theater Discussions And Reviews
post #1 of 13 Old 02-15-2013, 11:30 PM - Thread Starter
ceh383's Avatar
Quoted: 418 Post(s)
Liked: 2575
I've had my sub for a couple weeks now, and it has been impressive until tonight.
I watched LOOPER at a modest volume (-25db) and at several points the sub rattled...not good...my focus went to the sub immediately...
I'm wondering if moving to an SB13-Ultra would be worth the additional $400?
Yamaha RX-A2020 | Outlaw M-2200 (x5) | Oppo BDP-103 | Sony CDP-CE500 | Dish VIP622
Definitive Technology BP-8060ST : CS-8060HD : PM-1000 | SVS PC12 Plus | PSA S1500
Sharp LC-70C6400U | miniDSP DDRC-88BM | Belkin PureAV (x2)
ceh383 is online now
post #2 of 13 Old 02-15-2013, 11:40 PM
pokekevin's Avatar
Liked: 102
Did things in the room rattle or did something in the sub rattle? Any port noise? if the sub was rattling there could be something wrong with the sub
pokekevin is offline
post #3 of 13 Old 02-16-2013, 09:28 AM - Thread Starter
ceh383's Avatar
Quoted: 418 Post(s)
Liked: 2575
It wasn't a port noise type sound, it was more like a vibration or rattle, it sounded like it came from the sub.
I'm still within the 45 day in-home trial period, and am wondering if going with the SB13-Ultra would be worth the extra $400
Either way I need to send the Plus back, question is exchange it for another model or repair it?
post #4 of 13 Old 02-16-2013, 09:36 AM
ack_bk's Avatar
Quoted: 548 Post(s)
Liked: 631
You need to isolate where the sound is coming from and confirm it is coming from the sub. If not, upgrading will not fix your issue. If you confirm it is from the sub I would contact SVS and discuss your options.
ack_bk is online now
post #5 of 13 Old 02-16-2013, 09:42 AM
LastButNotLeast's Avatar
Quoted: 1479 Post(s)
Liked: 1069
Run some test sweeps to try to reproduce and localize the problem:
http://files.hsuresearch.com/downloads/
MemX likes this.
Did you really need to quote that entire post in your reply?
Downloadable FREE demo discs: Demonstration Blu-Ray Discs (Independently Authored)
Welcome to AVS - Get out while you still can!
LastButNotLeast is offline
post #6 of 13 Old 02-16-2013, 09:47 AM - Thread Starter
ceh383's Avatar
Quoted: 418 Post(s)
Liked: 2575
Good idea, thanks for that...I'll give it a try...
post #7 of 13 Old 02-16-2013, 11:24 AM - Thread Starter
ceh383's Avatar
Quoted: 418 Post(s)
Liked: 2575
I downloaded the test tones, burned to a CD.
The 16Hz and 20Hz tones produced the rattle.
It turns out the rattle is the wall directly behind the sub. A little pressure on the wall stopped the rattle.
A couple well placed drywall screws seems to have corrected the issue....Now I get to Spackle and paint....
Thank you LastButNotLeast, that was a very good suggestion....
post #8 of 13 Old 02-16-2013, 12:03 PM
Liked: 1069
My pleasure. Glad the solution turned out to be relatively simple.
So . . . are you going to keep the sub?
post #9 of 13 Old 02-16-2013, 01:24 PM - Thread Starter
ceh383's Avatar
Quoted: 418 Post(s)
Liked: 2575
It does work well, I thought if I had to send it back, would it be worth the upgrade?
Since it works, no reason to fix it....
post #10 of 13 Old 02-16-2013, 08:13 PM
kesando's Avatar
Liked: 31
If your walls are rattling then it sounds like your sub it's doing its job!
kesando is offline
post #11 of 13 Old 02-17-2013, 12:57 PM - Thread Starter
ceh383's Avatar
Quoted: 418 Post(s)
Liked: 2575
Indeed, the sub is doing what it is supposed to....
It was just coincidence that the rattle in the wall was directly behind the sub from my LP.
I was seriously thinking I had a problem with the sub, I'm glad I didn't.
Over the years I've bought so many things that didn't live up to the expectations, so far, this sub has exceeded them....KNOCK ON WOOD....
post #12 of 13 Old 02-17-2013, 03:46 PM
Liked: 1069
Don't knock too hard, you'll need more of those drywall screws.
post #13 of 13 Old 02-17-2013, 06:47 PM - Thread Starter
ceh383's Avatar
Quoted: 418 Post(s)
Liked: 2575
Or perhaps some Aspirin....LOL...
