Subwoofer help - get 1 large or split budget and get 2 small? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 02-18-2013, 10:54 AM - Thread Starter
db4809's Avatar
So I have room 15x20x9.... it is an upstairs gameroom area that has two half walls... we have converted this into our home theater.... would it be better to go with 1 large sub like a Power Sound Audio XV15 or would it be better to split my budget and buy a couple of 12's like the Klipsch SW308 that is on sale at Newegg......
db4809 is offline
post #2 of 5 Old 02-18-2013, 12:21 PM
KidHorn's Avatar
Quoted: 1374 Post(s)
Liked: 877
Given your two choices. I would get the powersound. It's much better than the klipsch.
Generally speaking, you're better off getting 2 lesser subs than one better one, but in this case, I would choose the PSA.
KidHorn is offline
post #3 of 5 Old 02-18-2013, 12:47 PM
aufVidyZen's Avatar
Quoted: 34 Post(s)
When you say "half walls" do you mean the ceiling slopes down to a 4-5 ft wall on two sides, or the game room is a loft open on two sides to a larger space?
If the latter, then you can realize the benefits that a 15" sub has. Lower bass cutoff and greater efficiency. Two small sub's can be "tuned" (by moving them around) to reduce room nodes in the low frequencies, and for most people with average size rooms (and resonant 5/8" sheetrock on 2x4 studs) cleaning up the low bass is a big problem.
Depending on your main speakers there could be more of a gap in acoustic output between a 15" sub and the mains. If your taste runs to action movies this won't be an issue. If you listen to, say, acoustic jazz, then the double bass or Fender bass will sound "wrong".
aufVidyZen is offline
post #4 of 5 Old 02-18-2013, 12:51 PM - Thread Starter
db4809's Avatar
Thanks, yes half walls open on one corner over looking living room(so 2 sides).....I do 95% or better with movies and TV..... so sounds like a 15 is the way to go....thanks for the help.
db4809 is offline
post #5 of 5 Old 02-18-2013, 01:02 PM
Joshjp's Avatar
Quoted: 13 Post(s)
Liked: 115
Yea get the PSA XV-15, there supposed to be really great for the price, later down the road get another one.
HT~
PANASONIC TC-P50ST60, OPPO BDP-103D, ONKYO TX-NR818, PANAMAX MR4000, KLIPSCH RF-62's, RC-62, RS-52's, PSA TRIAX
2.1CH~
ADAM AUDIO F5's, EMOTIVA STEALTH DC-1, SVS SB-2000
Joshjp is offline
