Big room pc12 plus not cutting it - AVS Forum | Home Theater Discussions And Reviews
post #1 of 14 Old 02-19-2013, 04:17 PM - Thread Starter
mominayal's Avatar
Room is 40'x16'x7' basement rec room which is now ht. LP is 14' from one end. Pc12 plus is about 5' from the LP and despite this not as much sound as I like despite increasing the gain.
My question is replace with a paradigm sub1 or add another pc12 plus?
mominayal is offline
post #2 of 14 Old 02-19-2013, 04:44 PM
ack_bk's Avatar
Quoted: 548 Post(s)
Liked: 631
How old is the PC12+. If you are looking for more, duals will help, but if you are a bass head you made need to look into the big boys (JTR Captivator, Seaton Submerssive).
You should also try and measure the response in your room. What types of floors do you have (carpet, hardwood)?
ack_bk is offline
post #3 of 14 Old 02-19-2013, 04:49 PM - Thread Starter
mominayal's Avatar
Sub is 10days old. Floors are carpet. How do I measure the response in the room?
post #4 of 14 Old 02-22-2013, 09:16 AM - Thread Starter
mominayal's Avatar
purchased a seaton subM F2. This has solved my problem. What a monster. Couldnt be happier.
post #5 of 14 Old 02-22-2013, 05:37 PM
JimWilson's Avatar
Quoted: 1267 Post(s)
Liked: 1564
You got an F2 in just 3 days? Impressive...
If you take yourself too seriously, expect me to do the exact opposite
JimWilson is offline
post #6 of 14 Old 02-22-2013, 07:09 PM
Skylinestar's Avatar
Quoted: 1046 Post(s)
Liked: 182
That's a large space. You'll need at least 2 PC12-Plus for that.
Skylinestar is offline
post #7 of 14 Old 02-22-2013, 07:57 PM
JimWilson's Avatar
Liked: 1564
In addition to the Seaton Submersive F2 he already bought??
post #8 of 14 Old 02-22-2013, 08:14 PM
Liked: 182
post #9 of 14 Old 02-22-2013, 08:20 PM
JimWilson's Avatar
Liked: 1564
Correct. My point was he already chose the latter, so it appears to be a done deal already.
post #10 of 14 Old 02-23-2013, 01:08 PM
Mark Seaton's Avatar
Quoted: 495 Post(s)
Liked: 1293
Great to hear things worked out and the room acoustics weren't insurmountable.
A finish that's in stock combined with living within a 1 day shipping window from Chicago = unpacking a shiny new subwoofer in 2 days. smile.gif
Mark Seaton
Seaton Sound, Inc.
"Make no little plans; they have no magic to stir men's blood..." Daniel H. Burnham
Mark Seaton is online now
post #11 of 14 Old 02-25-2013, 09:23 AM - Thread Starter
mominayal's Avatar
Havent tried this yet, but what is everyone (or anyones) thoughts on using the PC12 AND the subM? the pc12 would have to be placed diagnoally across the listening area and basically 5-7ft to the left of where I sit. the subM is in the front right corner. Do I need to do any tuning to the PC12?
post #12 of 14 Old 02-25-2013, 11:04 AM
Quoted: 495 Post(s)
Liked: 1293
Sometimes it works, sometimes the ported and sealed subs will fight around the tuning frequency. You can probably use the quickmeasure feature in ARC to save a lot of guessing or head scratching. The ultimate question will be to determine if you can find a complimentary location for the sub which allows it to help while not pushing it to its limits.
You can try different tunings to see how they interact with the response of the SubMersive F2, where sealed might end up be easiest to integrate. Either way you can also experiment with setting the room gain compensation to a smaller room setting (more gain) which will reduce the low frequency workload for the same playback level.
Mark Seaton
Seaton Sound, Inc.
post #13 of 14 Old 02-25-2013, 12:58 PM - Thread Starter
mominayal's Avatar
DO you think plugging the ports on the pc12 will make it an easier to integrate?
post #14 of 14 Old 02-25-2013, 01:12 PM
KidHorn's Avatar
Quoted: 1374 Post(s)
Liked: 877
It's a total crap shoot. Every room is different. Every sub placed in a different spot within a room is different. I suggest trial and error until you find the best setup to your liking.
What I like best with my setups, many posters would say is completely wrong. But in the end, what I think is best is what's best.
KidHorn is offline
