2 Klipsch or 1 SVS - AVS Forum | Home Theater Discussions And Reviews
post #1 of 17 Old 02-24-2013, 03:27 PM - Thread Starter
cgott42's Avatar
Quoted: 133 Post(s)
I currently have a set of Klipsch reference speakers RF82 II ,64 II , 62II snd an SVS 23-39cs cylinder sub with a denon 2809ci AVR
My room is approx. 10 x 22
I saw a sale on Klipsch Reference RW 12d sub - my Q is- would I be better off with 2 of these Klipsch or my 1 SVS
Also - my equip is in a separate equip room, and the SVS sub (being passive, just has standard speaker cables going to it (coming from the walls) - would the Klipsch subs require different cabling (which woudl be a problem as my HT is already finished)
thanks
cgott42 is offline
post #2 of 17 Old 02-24-2013, 04:04 PM
BeeMan458's Avatar
Liked: 813
In my opinion, you'd be better served by powered RW-12d's connected with some standard shielded subwoofer cables to your AVR.
BeeMan458 is offline
post #3 of 17 Old 02-24-2013, 04:21 PM
acevesf's Avatar
Quoted: 25 Post(s)
Subscribing. Currently asking myself a similar question, 2 rw-12d's or one sub of equal price ($600 or less)
acevesf is offline
post #4 of 17 Old 02-24-2013, 06:04 PM
colohtpc's Avatar
I think that people should be thinking of the RW12D as a $700 sub. There are reviews of this sub in that price range and is was well thought of, about middle of the pack at 700 a couple years ago. So when the single for 600 question comes up I personally don't think you will out perform ONE of these by much at all. Two of these would for sure be better that one other at $600.
colohtpc is offline
post #5 of 17 Old 02-24-2013, 10:29 PM
Stiltz's Avatar
Quoted: 18 Post(s)
So you think 2 RW-12d would be better than 1 Rythmik LV12R?
Media Room - JVC RS500 PJ, 130" Dalite JKP 1.3, Anthem MRX 1120 AVR, Panasonic UB900 UHD, Martin Logan Vantage, ML Stage, 4xML Motion FX, 4xML R Ceiling, PS Audio PWD, Seaton Submersive F2 / 2xOutlaw LFM-1EX / HSU MBM Subs, Dune 3D, Sonos, HTPC, 2xButtKicker
Family Room: LG 65EF9500 OLED, Marantz SR7010, Philips UHD, 2xMartin Logan Motion 15, ML Motion C2, 2xML Motion 2, 2xML IC Ceiling, REL T9 Sub, HTPC
Stiltz is online now
post #6 of 17 Old 02-25-2013, 08:53 AM
Cowboys's Avatar
Liked: 107
I like the Rythmik but no, two rw-12d are probably better.
Cowboys is offline
post #7 of 17 Old 02-25-2013, 09:02 AM
Louquid's Avatar
Liked: 38
Two RW12-d's or one Rythmik LV12R? That's a pretty tough one. I would say it comes down to what you want. Do you want lower extension while sacrificing a few db's in output and room response? Or would you rather 3db of added spl with better in room bass response while sacrificing anything below 23Hz?
It's a tough one.
Louquid is offline
post #8 of 17 Old 02-25-2013, 08:19 PM
blake18's Avatar
Quoted: 299 Post(s)
Liked: 185
I have two RW-12d's and they certainly dig deeper than 23hz. Mine go down to 18hz with authority.
Lumenlab "Community driven video lab".
blake18 is offline
post #9 of 17 Old 02-26-2013, 06:04 AM
Louquid's Avatar
Liked: 38
That may be possible in your room, but you certainly didn't buy those subwoofers with the intentions of reaching that low. That's just a bonus and can't be relied on for decision making. It's very possible to have a room that only allows the RW12-d to play down to 25Hz.
But, comparing a subwoofer with a 23Hz -3db point and a 19Hz -3db point, it's safe to assume that the sub with the lower -3db point will play lower in the same room. Imagine how deep the LV12R would go with all that room gain.
One last thing, can you hear 18Hz?
Louquid is offline
post #10 of 17 Old 02-26-2013, 06:58 AM
RickMa's Avatar
He may not hear it...but I bet he can FEEL it.
Theatre
Onkyo TX-NR818 * Epson 8700UB * Samsung BD-E5900 * Cornscala - Heresy II - Cornscala (LCR) * PSA XV15 SUB
2 Channel
C 33 Pre * MC 2505 Amp * Thorens TD-160 w/ Denon DL-110
Cornscalas w/ Custom Mid Horns from Dave at Fastlane Audio, Tweeters from Bob Crites and ALK Universal X-Overs.
RickMa is offline
post #11 of 17 Old 02-26-2013, 07:01 AM
acevesf's Avatar
Quoted: 25 Post(s)
not sure if it helps but I went with 2 rw-12d's should be here Thursday!
acevesf is offline
post #12 of 17 Old 02-26-2013, 08:08 AM
Louquid's Avatar
Liked: 38
Well, I was just trying to get an idea of what sort of output levels he is reaching at 18Hz. If he can feel it then that's cool, but if he can hear it then it's at least 85db (about where it would be faintly audible).
Louquid is offline
post #13 of 17 Old 02-26-2013, 08:28 AM
BeeMan458's Avatar
Liked: 813
Is this measured?
post #14 of 17 Old 02-28-2013, 01:13 PM
colohtpc's Avatar
Originally Posted by colohtpc View Post
I think that people should be thinking of the RW12D as a $700 sub. There are reviews of this sub in that price range and it was well thought of, about middle of the pack at 700 a couple years ago. So when the single for 600 question comes up I personally don't think you will out perform ONE of these by much at all. Two of these would for sure be better that one other at $600.
I know that I can hear 20hz with mine in my room, substantially, on at least three different test tones and sweeps. I don't have a way to measure but it is substantial and not much below what it gives me at 30hz. So maybe it is below the specs of -3db but I am glad I can hear it. Below that I get lots of "movement" of the woofer and air pushing out of the port big time but can't hear it. My storage room door was rattling pretty good though.
colohtpc is offline
post #15 of 17 Old 03-04-2013, 12:54 PM
blake18's Avatar
Quoted: 299 Post(s)
Liked: 185
Originally Posted by BeeMan458 View Post
Is this measured?
blake18 is offline
post #16 of 17 Old 03-04-2013, 01:47 PM
BeeMan458's Avatar
Liked: 813
Out of curiosity, when measured, what do they measure at, at 18Hz and on the same graph, what do they measure at twenty-five Hz?
For a comparison, the last measurement I took a few minutes ago, from 25Hz to 20Hz, the graph is down 15dB. The boxes are tuned at 28Hz.
As another comparison, using the REW provided spectrogram, our subs go down to 23Hz with authority.
My question is not a challenge but a curiosity of how much slope do you have when posting the subs are strong at 18Hz.
post #17 of 17 Old 03-04-2013, 01:56 PM
Louquid's Avatar
Liked: 38
It seems like you are getting some really nice room gain here. With that amount of room gain you can almost expect the LV12R to reach 16Hz with the strength that your Klipsch's hit around 22Hz.
Louquid is offline
