Recommend me a subwoofer - Page 5 - AVS Forum | Home Theater Discussions And Reviews
post #121 of 126 Old 03-06-2013, 04:05 PM
shadyJ's Avatar
Quoted: 1330 Post(s)
Liked: 1351
Its not your setup so much as $600 seems to be a point where subs begin to to reach a certain performance level. At that point, you get a respectable amount of output, bass to 20 hz, a flat frequency response, and very good sound quality ie non-boomy bass. The $600 subs are the Outlaw LFM-1 Plus, Rythmik FV12r, and Hsu VTF2 mk4. Below that you find compromises in some regard which you might find tolerable, but you will always know there are there.
shadyJ is offline
post #122 of 126 Old 03-06-2013, 04:13 PM
eljaycanuck's Avatar
Quoted: 1346 Post(s)
Liked: 1962
What is it specifically about my setup that screams $600 subwoofer?
The part where you say "I think I'm overpowering my subwoofer, it's beginning to pop on me at some really bassy loud scenes ... " wink.gif
$500 will get you an SVS PB-1000. $600 will get you a couple of RW-12ds, or up into the subs shadyJ mentioned.
In either case, you'll realize the difference between a "lesser sub" and a good sub. smile.gif
eljaycanuck is offline
post #123 of 126 Old 03-06-2013, 04:14 PM
Bond 007's Avatar
Quoted: 2627 Post(s)
Liked: 2091
Originally Posted by CheYC View Post
Thanks for the input guys. What is it specifically about my setup that screams $600 subwoofer? Certainly not doubting you guys, I'm just curious basically how to match an ideal subwoofer given a certain setup.
I dont know but the best thing you could do for $600 is get 2 RW12s.
Licence to Kill
Bond 007 is offline
post #124 of 126 Old 04-09-2013, 09:28 AM
dave trimble's Avatar
Quoted: 38 Post(s)
Originally Posted by kesando View Post
If you just want the most SPL for your money then the Outlaw is perhaps your best bet. You could place it in between your sectional in position #2 and use it as an end table. It also has a plexiglass top.
I'm seriously considering the Outlaw EX for my next sub, and it has been recommended to me in another thread. But I have a question about using it as an end table (I had heard this elsewhere as well). Is there any kind of problem actually using it as a functional end table? Like having beverages and the like on it (is that why it has a plexiglass top)? Does the placement of objects on it alter the sound at all, or are the vibrations a problem for the items placed on top?
Also, does anyone have any experience with the wireless kit Outlaw sells for their subs? Does the sound quality suffer at all?
dave trimble is offline
post #125 of 126 Old 04-09-2013, 09:35 AM
cel4145's Avatar
Quoted: 2668 Post(s)
Liked: 3002
The plexiglass top on the Outlaw subs is not suitable for end table use. It's very, very scratch prone. You'd probably want to have a glass top cut and finished to set on top.
And yes. At very high volumes, it could be prone to some vibration.
That being said, at it's current sale price, the Outlaw EX is probably the best HT sub for the money for under $750. Since it seems like you have a lot of questions about it, the AVS outlaw owners thread would be a great place to get them answered: http://www.avsforum.com/t/848339/official-outlaw-owners-thread
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | HE-400i | NAD HP50 | Sony MDR-1A | Soundmagic E50 & E80 | X5ii | DX50 | E12
cel4145 is offline
post #126 of 126 Old 04-09-2013, 10:33 AM
newc33's Avatar
Quoted: 957 Post(s)
Liked: 1234
I just got my lv12r and I'm really enjoying it. Very glad its ported for the extra output and the advanced servo design rythmik uses makes it very musical for being ported IMO. I would imagine it would give you plenty of quality output in your condo. IV cranked this sub pretty good(nothing I would call insane yet) and it handles eveythinkg with ease. I actually think this sub sounds best when its pushed a little bit or maybe better worded that's where it really shines. To take it another step, at moderately high volumes and times of high detailed and extrymly fast and or variable lfe this sub is almost gaurenteed to make u grin from ear to ear:D
Also I have never yet heard this sub distort or make any unpleasent sounds.
1600 cubic foot sealed room! Samsung 8500 curved 4k
denon x4100
JTR noesis 228s LCR
Ascend acoustics cmt 340se side ss.
ascend acoustics cbm170se rear ss
Quad PSA T18s!!!!!!
newc33 is offline
