Dual Klipsch RW-12D vs ANY single sub under $600??? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 02-28-2013, 03:57 PM - Thread Starter
SSEiYah's Avatar
I'm trying to find something that is equivalent in output and sound quality to a pair of Klipsch RW-12D subs. I have a $500 budget, the pair of Klipsch RW-12d's can be had for $560 onsale at newegg which is slightly over my budget but that is ok. I'd say $600 is my absolute limit, but I'd like to spend $500 or less.
Anyway, my use is primarily for movies and music is secondary.
Currently the system consists of:
Klipsch RF-82 (5 Speaker System, first generation, minus a sub)
Rotel 5.1 Receiver, with around 100watts/channel.
SSEiYah is offline
post #2 of 4 Old 02-28-2013, 05:37 PM
kesando's Avatar
Liked: 31
How big is your room and is it open to other areas of your home?
kesando is offline
post #3 of 4 Old 03-01-2013, 08:40 AM
cel4145's Avatar
Quoted: 2660 Post(s)
Liked: 2991
I don't think you'll find two subs for $600 that have the equivalent output and equal or better SQ to dual RW-12ds.
However, in a single sub, the Rythmik LV12R should have better SQ than the RW-12d. You'll lose the benefit of dual subs, and you may have less output (hard to say).
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | NAD HP50 | AKG K550 | Soundmagic E50 & E80 | DX50 | E12 | X1
cel4145 is online now
post #4 of 4 Old 03-01-2013, 09:44 AM
flickhtguru's Avatar
Liked: 110
I have 2 subs and love a dual sub setup. But with your budget of $500-$600 I would suggest starting with a single Rythmik LV-12R OR a single Outlaw Audio LFM-1 Plus..... Then if you really fall in love with one of those subs if you buy one of them, you can buy a second identical sub in the future as your budget allows. Then you can have the benefits of stepping up into good subs with sub 20hz ability and the benefits of dual subs.
Shawn
flickhtguru is offline
Klipsch Rw 12d 12 Subwoofer Each
