Replacement grill pins for elemental designs A5-350 subwoofer...? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 03-01-2013, 06:42 PM - Thread Starter
slammin86's Avatar
Quoted: 25 Post(s)
Liked: 31
3 out of 4 of the grill pins on my A5-350 were damaged in transit and I need to buy some more. If I can find something stronger I will go ahead and upgrade the pins on each sub.
I remember reading about the breaking all the time. Does anyone know something I can buy that will fit in the existing holes and lock the grills in place?
slammin86 is offline
post #2 of 6 Old 03-01-2013, 06:59 PM - Thread Starter
slammin86's Avatar
Quoted: 25 Post(s)
Liked: 31
Based on the dimensions I took with my calipers I think these will work.
http://www.parts-express.com/pe/showdetl.cfm?partnumber=260-367
Can anyone confirm?
post #3 of 6 Old 03-01-2013, 07:20 PM
SULLY12's Avatar
One thing I have found out is that ED used all kinds of pe stuff. From feet to ports to griil pins to even the drivers. I'm sure those are the same ones. ED did a great job of pulling the wool over everyone's eyes. rolleyes.gif
SULLY12 is offline
post #4 of 6 Old 03-01-2013, 07:40 PM
Bill Fitzmaurice's Avatar
Liked: 4972
Possibly, but it's not like PE makes it. They source everything. If ED was smart they got their parts from the same sources that PE does. Where high grade hardware is concerned that would be Penn-Elcom.
Bill Fitzmaurice is offline
post #5 of 6 Old 03-01-2013, 08:07 PM
SULLY12's Avatar
Originally Posted by Bill Fitzmaurice View Post
Possibly, but it's not like PE makes it. They source everything. If ED was smart they got their parts from the same sources that PE does. Where high grade hardware is concerned that would be Penn-Elcom.[/ quote]
good point.
SULLY12 is offline
post #6 of 6 Old 03-03-2013, 05:24 AM - Thread Starter
slammin86's Avatar
Quoted: 25 Post(s)
Liked: 31
I ended up buying these.
http://www.madisoundspeakerstore.com/grill-fasteners/hedlock-grill-fastener-ball-and-socket/
This was the cheapest place I could find them with the lowest total shipping cost. From the dimensions I believe they are the same as what is on there now. I will update this thread once they arrive.
