Using Wireless Kits for Subs -- Only down to 20hz?! - AVS Forum | Home Theater Discussions And Reviews
post #1 of 20 Old 03-02-2013, 07:13 AM - Thread Starter
Newbie01's Avatar
Quoted: 44 Post(s)
Liked: 36
So I was reading through posts all over the internet about using a sub wireless kit and which one was universal and worked best...
And I hit across a post that mentioned almost all wireless sub kits only go down to 20hz... Buttkicker goes down to 5hz (Buttkicker though only works with BUttkicker..it is not universal.)
Now one of the big reasons I bought my sub is I want to feel those sub-sonic sounds... Anyone have advice to go wireless and get below 20hz?
Newbie01 is offline
post #2 of 20 Old 03-02-2013, 11:06 AM
cel4145's Avatar
Quoted: 2658 Post(s)
Liked: 2990
Maybe you should get a different room for your audio setup that doesn't require wireless wink.gif
You might call Outlaw Audio about their OAW3: http://www.outlawaudio.com/products/OAW3.html Perhaps it's not a cliff at 20hz, and you can still get some usable response from it a few hz lower.
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | NAD HP50 | AKG K550 | Soundmagic E50 & E80 | DX50 | E12 | X1
cel4145 is offline
post #3 of 20 Old 03-02-2013, 11:27 AM - Thread Starter
Newbie01's Avatar
Quoted: 44 Post(s)
Liked: 36
Says right on their site...
OAW3 Wireless Audio System...means you can use it to send extremely low latency, full fidelity, 20Hz to 20kHz. Strange that all these high performance sub makers would design a wireless system but cut off single at 20Hz. Allot of the reason we buy Outlaw and other high performance subs is the response below 20Hz.
Unless I am missing something? I really doubt I am smarter than all these engineers?
Newbie01 is offline
post #4 of 20 Old 03-02-2013, 11:31 AM
cel4145's Avatar
Liked: 2990
You are right. It is kind of pointless. But don't assume it's a cliff at 20hz. Could be it's a gradual slope down from there.
cel4145 is offline
post #5 of 20 Old 03-02-2013, 11:51 AM - Thread Starter
Newbie01's Avatar
Quoted: 44 Post(s)
Liked: 36
I will call to ask on Monday...can't hurt.
Newbie01 is offline
post #6 of 20 Old 03-02-2013, 11:21 PM
Archaea's Avatar
Quoted: 2846 Post(s)
Liked: 2427
keep in mind that lots of electronics use the 20hz to 20khz stat. Nearly all receivers for instance - yet they go much lower.
It's sort of a general standard, but not a limit typically.
Archaea is online now
post #7 of 20 Old 03-03-2013, 06:17 AM
Bill Fitzmaurice's Avatar
Liked: 4641
+1. They do so as they'd rather exceed spec than come up short, and rest assured there's no shortage of those who'd scream bloody murder if they claimed being flat to 10Hz but were actually only flat to 11.
Bill Fitzmaurice is online now
post #8 of 20 Old 03-03-2013, 12:01 PM - Thread Starter
Newbie01's Avatar
Quoted: 44 Post(s)
Liked: 36
That helps! I will call just to confirm... Will try to run with cable but if I can't ill go wireless. Thanks guys.
Newbie01 is offline
post #9 of 20 Old 03-14-2013, 07:31 AM
ogodei's Avatar
Did you get any response from Outlaw? I was about to put this in place for my subs but now I'm wondering.
ogodei is offline
post #10 of 20 Old 03-28-2013, 10:18 AM
Colecat's Avatar
I'm curious as well.... need a solution with high WAF and this fits the bill
Colecat is offline
post #11 of 20 Old 03-28-2013, 12:05 PM
ndskurfer's Avatar
Quoted: 39 Post(s)
Liked: 52
I'll do some sweeps with mine after my new subs come next week. Wired vs OAW3. I'm in between subs as of now
Sent from my RM-820_nam_att_100 using Board Express
ndskurfer is offline
post #12 of 20 Old 03-29-2013, 10:48 AM
BenjaminKing's Avatar
Quoted: 28 Post(s)
Liked: 27
Any update on this? I'm really curious to hear the outcome.
Benjamin King
Sic Transit Gloria
BenjaminKing is offline
post #13 of 20 Old 04-04-2013, 01:23 PM
ndskurfer's Avatar
Quoted: 39 Post(s)
Liked: 52
Update:
I did run some sweeps on 1 of my new PSA XS30's wired vs wireless. I did find that there is a large gain difference (roughly 10db), but this is easily fixed on the sub gain to compensate. The bigger concern that we all have is how it performs below 20hz. My sweeps do not have any smoothing nor do I have any kind of room correction engaged.
What I did find is that as you go sub 20hz (15hz & 10hz), you do lose about 2 - 2.5db's vs a wired connection. Below are my measurements:
I also created a table so you can see the #'s at 10hz intervals:
post #14 of 20 Old 04-04-2013, 02:48 PM
jjcook's Avatar
Quoted: 336 Post(s)
Liked: 139
Originally Posted by ndskurfer View Post
Update:
Thanks for taking these measurements -- I was planning to set up up my new XS15 with the OAW3 next weekend and measure (and I still will and report back) but now I have the confidence that the effort to move the sub won't be in vain.
jjcook is offline
post #15 of 20 Old 04-04-2013, 03:19 PM
Quoted: 28 Post(s)
Liked: 27
Any idea if Audyssey (or similar) would make corrections for the slight drop?
Benjamin King
Sic Transit Gloria
post #16 of 20 Old 04-04-2013, 03:38 PM
jjcook's Avatar
Quoted: 336 Post(s)
Liked: 139
Yes, Audyssey should be able to easily correct this AFAIK.
jjcook is offline
post #17 of 20 Old 04-16-2013, 11:28 AM
jjcook's Avatar
Quoted: 336 Post(s)
Liked: 139
I am using a Audioengine W3 wireless kit for my PSA XS15 subwoofer. As you can see from the REW graph below (Audyssey off) the Audioengine W3 (purple) extends well below 20Hz. The distortion plots for each in REW look virtually identical as well.
jjcook is offline
post #18 of 20 Old 04-16-2013, 07:53 PM
basshead81's Avatar
Quoted: 179 Post(s)
Liked: 5223
Im using the rocket fish wireless transmitter for 69.00 on a PSA XV15. It operates on a 5ghz bandwith and I notice no difference between my other xv15 thats hooked up direct. I get extension down to 16hz before it rolls off.
Getting Started with REW: A Step by Step Guide -->http://www.roomeqwizard.com/REWhelp.pdf
Mini DSP Tutorial by Neutro --> http://www.avsforum.com/forum/113-su...g-minidsp.html
basshead81 is offline
post #19 of 20 Old 04-24-2013, 09:41 AM
ogodei's Avatar
ndskurfer, thanks for the measurements. That looks like an acceptable drop for the benefit of wireless.
ogodei is offline
post #20 of 20 Old 04-06-2015, 07:11 AM
Liked: 0
I realize this is an old thread,but hopefully you can help.
I'm looking to use multiple subs to smooth bass response for a 2-channel system and would like to go wireless, but am concerned about latency, static, pops, and line-of-sight constraints.
Are you all still happy with your wireless set up? Is 5 GHz definitely the way to go?
AC
ACHiPo is offline
