"woofer out" on sound processor - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 03-04-2013, 12:15 PM - Thread Starter
martin16v's Avatar
hi guys
i thought it was about time i added a subwoofer to to my system. i have a single phono on the sound processor for the sub.
im guessing its a pre-out for a actve sub ?
so my question is..can i use any size sub as regaurds to wattage.?
martin16v is offline
post #2 of 5 Old 03-04-2013, 12:19 PM
eljaycanuck's Avatar
Quoted: 1352 Post(s)
Liked: 1964
If your "sound processor" has a subwoofer output, you can connect any powered subwoofer to that output. Connecting a sub is usually pretty straighforward; the more important element is integrating that sub into your system.
eljaycanuck is offline
post #3 of 5 Old 03-04-2013, 12:31 PM - Thread Starter
martin16v's Avatar
picking the right sub you mean ?
when my system was released. it only came with a sub in newziland. not in the uk.
i have the spec for sub in the manual.
type> 1 way bass reflex
ohms> 8
music> 180w
din> 90
frequency range> 41hz/1.8khz/ -16db
45hz/1.6khz/ -10db
post #4 of 5 Old 03-04-2013, 01:24 PM
Liked: 1964
Sorry, I'm not sure what the point of post #3 is. Picking the sub is fairly straightforward: Determine your budget and other requirements (size restrictions, aesthetics, etc.) and look for a well-rated sub that meets them. Buy it, hook it up to your processor and then integrate it into / calibrate it to the rest of your system.
post #5 of 5 Old 03-04-2013, 02:06 PM - Thread Starter
martin16v's Avatar
thank you for your help
