Auralex SubDude vs. Spike feet - Page 4 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
post #91 of 103 Old 03-02-2014, 07:08 PM
mattg3's Avatar
Quoted: 264 Post(s)
Liked: 169
So bottom line here is i live on second floor of condo and want to use sub in my home theater but dont want to upset my downstairs neighbors.You are saying forget the subdude product for it wont help.
Matt
mattg3 is offline
post #92 of 103 Old 03-02-2014, 08:12 PM
Bill Fitzmaurice's Avatar
Liked: 4628
If you want to stop bass from passing through your floor a few inches of poured concrete over the entire floor will help. Anything shy of that is like trying to stop a charging rhino with spitballs.
Bill Fitzmaurice is online now
post #93 of 103 Old 07-02-2014, 05:38 AM
Liked: 0
What if my sub itself is vibrating and moving along the floor even on spikes? I was going to buy a SubDude for this.
LocutusEstBorg is offline
post #94 of 103 Old 07-02-2014, 06:07 AM
Liked: 4628
Is this on carpet? Or a hard floor? Spikes should only be used on carpet. On a hard floor cut a piece of this to size:
http://www.homedepot.com/p/TrafficMA...0300/202015909
If neither fixes the problem chances are you're pushing the sub a lot harder than you should be. The cure for that is to add a second sub.
iatacs19 likes this.
post #95 of 103 Old 07-02-2014, 11:34 PM
Liked: 0
It's on a hard tiled floor. First I covered the spikes with the provided rubber caps but that resulted in massive rattling. It was just freely sliding across the floor. I then removed the rubber caps and placed the spikes directly on the floor. This eliminated the horizontal movement but the spikes still vibrate on the surface of the floor. I can feel the metal of the spikes vibrating resulting in vertical movement and rattling of the sub. The floor is even and all four spikes are firmly in contact with the floor and the sub has no tilt whatsoever.
It's a Wharfedale SPC-12 and has a sustained output of 400 W. After Audyssey calibration I never run it above 0.0 dB so there's no way the sub is anywhere near its limit.
post #96 of 103 Old 07-03-2014, 06:49 AM
Liked: 4628
Use the linked pad. BTW, a tile floor is the worst material there is for a listening room. You should have as much of it as possible covered with rugs.
You can't tell from where the calibration or volume controls are set whether it's near its limit or not. The very long cone excursion that's required to make it dance about is a pretty good indication.
post #97 of 103 Old 07-03-2014, 12:48 PM
neuspeed94's Avatar
Just from my personal experience, A subdude or gramma do actually make a difference on hard floors (wood. tile, etc.). I live in a really nice house, but it was built in the 20s and has hard wood floors. My gramma pad eliminated a little bit of wood floor vibration from my floor where the wood floors had a little bit of play in them. Also, since my theater room is located upstairs and above my living room, I can from experience tell you that the gramma pad made the subwoofer much less noticable in the living room. Before the pad, the subwoofer was coupled to the floor via it's rubber feet and I could hear explosions, etc. much louder down there than I can now. Family in the living room usually don't even know I am upstairs watching movies or playing video games since getting the pad.
I also tend to believe that any kind of foam will do the same thing, even cheap packing foam. But for tower speakers that require stability, a gramma pad or great gramma pad cut in half securely gets the job done.
neuspeed94 is offline
post #98 of 103 Old 07-03-2014, 03:47 PM
KurianOfBorg's Avatar
Quoted: 136 Post(s)
Liked: 27
I lowered the volume down from 0 dB to -18 dB and listened closely to the sub. I hear the same "rattling" at exactly the same moments. I can physically see that the cone is excursing almost 1 cm less so it's probably not "bottoming" out. The floor has stopped vibrating around the sub but I still hear the rattling. I have no explanation for this...
KurianOfBorg is offline
post #99 of 103 Old 07-03-2014, 03:53 PM
Blacklightning's Avatar
Quoted: 411 Post(s)
Liked: 282
I did use spikes with a penny under then for years. One day I figured I needed an upgrade so I moved up to nickels and man did it sound good. After some saving and a big promotion at work I now have quarters under each spike. I did notice less and less improvement. I guess diminishing returns kicked in. Since I'm in Canada my dream system would have Toonies under the spikes but I can't see my wife wanting to spend that kind of money our system.
Blacklightning is offline
post #100 of 103 Old 07-03-2014, 08:10 PM
Liked: 4628
Use hockey pucks, hoser.
post #101 of 103 Old 07-05-2014, 06:36 AM
Quoted: 136 Post(s)
Liked: 27
I live in India so I can't get easy access to materials. I folder up a thin carpet into a 15x12 rectangle and put the sub on top of it. The sound is a little muffled but the vibration noise has completely stopped. The spikes are also sinking in to the carpet reducing the distance between the excursed cone and the carpet. I wonder if it will negatively affect the sound.
post #102 of 103 Old 07-05-2014, 06:46 AM
Liked: 4628
It will when the distance alteration is a significant percentage of a wavelength. Since the shortest wavelength a sub with an 80Hz crossover passes is 14 feet long you don't have to be concerned.
post #103 of 103 Old 10-27-2014, 01:39 PM
Quoted: 136 Post(s)
Liked: 27
I've got the SubDude. Now the SubDude is sliding across the floor. The sub stays firmly in place on top of the SubDude.
