BIC PL-200 crossover switch question - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 03-06-2013, 08:59 AM - Thread Starter
fuzzydisco's Avatar
I recently purchased a BIC PL-200 after reading all the rave reviews. I've been tweaking the settings over the past few days, but I'm confused about the crossover "In / Out" switch on the back. I'm assuming this switches between the internal crossover (IN) and the receiver settings (OUT). However, the sub's manual refers to this switch as a Digital 5.1, 7.1 / Pro Logic switch; and says it should be set according to the receiver. My receiver is an Onkyo TX-NR616, and the PL-200 is attached to it via an RCA cable from the sub out port. I know the NR616 has Pro Logic, but the labeling of the switch makes me unsure which setting to use. An someone please clarify this for me?
Thanks in advance,
John
fuzzydisco is offline
post #2 of 5 Old 03-06-2013, 09:23 AM
BillCinLR's Avatar
Set the switch so the receiver sets the crossovers, then run the Audyssey automatic setup
Bill C
BillCinLR is offline
post #3 of 5 Old 03-06-2013, 09:26 AM - Thread Starter
fuzzydisco's Avatar
Is is safe to assume that is the "Out" position, then?
post #4 of 5 Old 03-06-2013, 09:27 AM
BillCinLR's Avatar
Yes, the "OUT" position is correct.
Bill C
post #5 of 5 Old 03-06-2013, 09:33 AM - Thread Starter
fuzzydisco's Avatar
Thanks Bill!
