new subwoofer questions and recomendations - AVS Forum | Home Theater Discussions And Reviews
post #1 of 16 Old 03-11-2013, 05:17 PM - Thread Starter
lunxbox's Avatar
I have a cerwin vega cmx 12s 12" 300watt subwoofer. It's decent for what it is and how much I paid for it but it doesn't really "do" for me.
I've been looking into getting new sub(s) for a while now but can't really decide on one. I'm really interested in svs either the pb13ultra or sb13ultra. I'm also intersted in others such as hsu vtf15h or even a seaton or rythmik sub. I really like the look of the svs subs the basket and everything looks fantastic and really well built, and all the great reviews. however I'm a little concerned to buy one as I've heard they are not the best for music and since thats my primary use for it I'm a bit skeptical. so leads my inclusion of the ported 13. However I've been told that ported subs dont sound as nice, yes they may be tighter and flatter response but I've been told they just sound "different" is this true?
I'd like some thoughts and recomendations of which sub(s) to get.
My stereo is pretty much going for at least 6 hours a day
My system is mostly used for music however I do watch a couple movies a day (almost reference level).
Thanks I look forward to reading your thoughts and suggestions.
lunxbox is offline
post #2 of 16 Old 03-11-2013, 05:26 PM
BeeMan458's Avatar
Liked: 813
Seaton is all about the smile factor.
It all depends on your budget and how many subs your room's decor can suck up.
Two subs better than one, three are better than two and four are better than three. It's all about spreading the sound waves around so as to overlap each other and not cancel each frequency sound wave out. Makes for smoother bass room sound.
The common choice is to go with two subs. In the end, for most, it's about the smile factor.
BeeMan458 is offline
post #3 of 16 Old 03-11-2013, 06:53 PM
cel4145's Avatar
Quoted: 2660 Post(s)
Liked: 2991
Since you like to listen to movies near reference level, the size of your room is a big factor in how much/which sub to get. What is the total volume (cubic feet) of your room, including any adjoining open areas?
And yes. Dual subs can create a more even frequency response throughout a room. So if you are listening to the music while moving around the room and sitting in locations other than where you watch movies, duals seems your best bet.
As far as the music quality of the subs you are looking at? Sure. You can get Rythmik sealed subs that will sound excellent, but the SVS and HSU ported subs are no slouches. Should be a good upgrade over your Cerwin Vega.
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | NAD HP50 | AKG K550 | Soundmagic E50 & E80 | DX50 | E12 | X1
cel4145 is offline
post #4 of 16 Old 03-11-2013, 07:58 PM - Thread Starter
lunxbox's Avatar
Thanks for the replies. My room is nearly 1500 cubic feet and I have a doorway that leads to a hallway and an entirely open space about the same size as my room directly outside my door.
lunxbox is offline
post #5 of 16 Old 03-11-2013, 08:03 PM
cel4145's Avatar
Liked: 2991
If your door way closes, then you have a small space that is easily pressurized by a sub. And even 3,000 cubic feet is not bad, with the space added through the doorway.
I'd get two of the Rythmik sealed subs if those are in your budget. That's your best bet since your priority is music.
cel4145 is offline
post #6 of 16 Old 03-11-2013, 08:46 PM - Thread Starter
lunxbox's Avatar
Doorway does not close unfortunately. So is a rythmik really that much better than one of the svs 13 ultras?
lunxbox is offline
post #7 of 16 Old 03-12-2013, 05:35 AM
BeeMan458's Avatar
Liked: 813
And your budget?
As to different subwoofers, to a point, depending on what your goals are, yes it makes a difference in how loud and how deep one's subwoofer system can go but one needs a budget to answer your question or they're just throwing out the names of manufactures and the names of the different models they make.
post #8 of 16 Old 03-12-2013, 12:33 PM - Thread Starter
lunxbox's Avatar
Budget is around $3000 give or take. would like the company to have a Canadian dealer.
lunxbox is offline
post #9 of 16 Old 03-12-2013, 12:46 PM
eljaycanuck's Avatar
Quoted: 1246 Post(s)
Liked: 1825
That limits you to SVS (via sonicboomaudio.com) and Funk Audio.
IMO, dual SVS PB12-Plus subs would be very awesome in your space, and they fit your "$3000 give or take" budget.
eljaycanuck is offline
post #10 of 16 Old 03-12-2013, 02:30 PM
nashou66's Avatar
Quoted: 89 Post(s)
Liked: 103
+1
Nashou
nashou66 is offline
post #11 of 16 Old 03-13-2013, 01:09 AM
cel4145's Avatar
Liked: 2991
Yep. Can't go wrong with SVS or Funk Audio
cel4145 is offline
post #12 of 16 Old 03-13-2013, 02:03 PM - Thread Starter
lunxbox's Avatar
So most of you are saying to go ported?
If I'm going dual svs subs I might as well go ultras.
lunxbox is offline
post #13 of 16 Old 03-13-2013, 04:01 PM
Prime316's Avatar
Quoted: 179 Post(s)
Liked: 204
I don't think you are going to get 2 PB13 Ultras for $3,000. If they are what you want then go for it. I love the look of that sub but I have to admit that you are going to be paying more than you have to in order to get what they offer.
Projector: Benq W1070 1080p 2D/3D
AVR: Denon X2200W
Mains: Klipsch RF-62ii x 2
Center: Klipsch RC-62ii
Surrounds: Klipsch RS-42ii x 2
Subs: Dual Hsu VTF-15H's
Prime316 is offline
post #14 of 16 Old 03-13-2013, 04:16 PM - Thread Starter
lunxbox's Avatar
There $3800 before taxes
lunxbox is offline
post #15 of 16 Old 03-13-2013, 04:18 PM
Liked: 1825
post #16 of 16 Old 03-13-2013, 04:31 PM - Thread Starter
lunxbox's Avatar
Yeah I hope its worth it haha I still need to upgrade the rest of my system as well.
Planning on getting 2 parasound halo jc1s, a jc2, oppo bd105, and some speakers I have yet to decide which ones.
lunxbox is offline
