Replacing A Driver - Mordaunt-Short MS309W - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 03-19-2013, 02:29 PM - Thread Starter
Jnipz's Avatar
I have a Mordaunt-Short MS309W and would like to replace the original driver. The problem is when the sub hits certain frequencies, I hear a clanking sound as if 2 glass bottles are hitting each other.
Does anyone have any recommendations as to what would be a fine replacement?
Specifications for the Mordaunt-Short MS309 Subwoofer:
Enclosure Type: Twin downward facing tuned ports.
Frequency Response: 35Hz to 200Hz
Power Rating: 150 watt Active
Drivers: 1 x 10" (255mm) Long throw aluminium CPC cone woofer
Cross-Over Type: Active - variable between 50 - 150Hz
Cabinet Dimensions: Width 370mm
Height 370mm
Depth 370mm
Weight: 15Kg
Here is the back of the amplifier
I was looking at drivers on this site.
Jnipz is offline
post #2 of 5 Old 03-19-2013, 04:29 PM
qguy's Avatar
Quoted: 122 Post(s)
Liked: 91
Check out Peerless drivers
qguy is offline
post #3 of 5 Old 03-19-2013, 05:37 PM - Thread Starter
Jnipz's Avatar
What model would you recommend? I'm looking for decent response but not more than $150
Jnipz is offline
post #4 of 5 Old 03-19-2013, 08:35 PM
Bill Fitzmaurice's Avatar
Liked: 4628
That's just as likely to be the amp running out of headroom as it is the driver. You can only get so much out of a sub that small. As for replacing the driver, you need to match the T/S specs of the driver to the cab. And if you don't know the specs of the stock driver, specifically xmax, you have no way of knowing if a replacement would be better, or even as good for that matter.
Bill Fitzmaurice is online now
post #5 of 5 Old 03-20-2013, 04:31 AM
Lecter83's Avatar
Liked: 41
Height 370mm
Depth 370mm
Weight: 15Kg
Hello, I have the answer.
It is a manufacturing defect quality MS driver itself.
I have a 309i and avant devido noise is that the cable that goes from behind the driver's membrane, is too long and rubs when the driver is moving.
I giving solve tape strips and the other wire tying a small inward curve of the driver spider.
I hope you will help.
Anyway the subwoofer and not use it, has been replaced by SVS in my system.
A hug.
Lecter83 is offline
