TWO SVS PB12 Pluses vs ONE Seaton Submersive HP or ONE SVS PB13 Ultra? Which would you choose... - Page 2 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
post #31 of 51 Old 03-21-2013, 08:10 PM
jbrown15's Avatar
Quoted: 2523 Post(s)
Liked: 1993
According to the Rythmik web page the FV15HP still has a 1db advantage over the F25 though.
jbrown15 is offline
post #32 of 51 Old 03-21-2013, 08:28 PM
dstew100's Avatar
I could be wrong on this but...
I think that is at 20Hz with the FV15HP in max output 2port mode. I use max extension 1port mode, From what I can tell a lot of us FV15HP owners do 1port. So the F25 should pull ahead a tad vs FV15HP in max extension. Plus the F25 will perform better below the FV15HP's tune.
F25 looks like an incredible value to me.
Also Jim Wilson found a pic of that finish on the F12G
http://www.rythmikaudio.com/F12G.html
dstew100 is offline
post #33 of 51 Old 03-22-2013, 09:37 AM
MKtheater's Avatar
Quoted: 1592 Post(s)
Liked: 1123
The ported sub tuned to 15hz should be better from 13-25hz in room due to the porting if the 15's are the same. The only way the dual sealed sub will be stronger around the tuning is if they are using better 15's with more displacement. Porting should get you anywhere from 8-12 dBs increase in spl from a sealed sub with the same driver. Dual drivers brings that down 6 dBs so closer to 2-6 dBs of an advantage. For this to be only 1 dB difference the sealed sub must be using a better 15 or there is some limiters or something be used. All this stuff is verified by Ricci's tests.
Marantz 7702 Atmos
MKtheater is offline
post #34 of 51 Old 03-22-2013, 11:22 PM
dstew100's Avatar
Thanks for the analysis. They are the same driver. The measurement is at 20Hz and I think the FV15HP is in 2port mode.. but Im not sure.
Please tell me more kind sir.
dstew100 is offline
post #35 of 51 Old 03-22-2013, 11:24 PM
dstew100's Avatar
^^^^ Servo'd though
dstew100 is offline
post #36 of 51 Old 03-23-2013, 08:09 AM
PaulF's Avatar
There's a multi sub discount. 10% off each sub. so 20% off the total.
Maybe you should check your math.
PaulF is offline
post #37 of 51 Old 03-23-2013, 09:10 AM
dstew100's Avatar
Why? Are you referring to the fact that they don't discount the shipping and I said total?
10% off of each SUB
dstew100 is offline
post #38 of 51 Old 03-23-2013, 10:15 AM
ironhead1230's Avatar
Liked: 48
10% off of each SUB
10% off each sub does not equal 20% off the total. If an individual sub cost $1000, without discount two would cost $2000. 10% off each sub would be $900 each so two would cost $1800. $1800 is a 10% discount from $2000, not 20%.
Or for those that like equations.
Cost of sub = X
Cost of two subs without discount = X + X = 2X
Cost of two subs with 10% discount = .9(2X)
Cost of two subs with 20% discount = .8(2X)
Cost of sub with 10% discount = .9X
Cost of two subs with 10% discount off each sub = .9X + .9X = .9(X+X) = .9(2X)
Clear as mud?
ironhead1230 is offline
post #39 of 51 Old 03-23-2013, 10:32 AM
dstew100's Avatar
10% off of each SUB
Cost of sub = X
Clear as mud?
haha, thanks. yup totally right.
Brain fart, and I have a math minor.
dstew100 is offline
post #40 of 51 Old 03-27-2013, 08:48 PM
tpaxadpom's Avatar
Quoted: 39 Post(s)
Liked: 26
Originally Posted by shadyJ View Post
A shipped FV15HP isn't more expensive than a PB12 Plus (unless you want the gloss black finish) and its performance is measured to be better than the PB13 Ultra. That is very high bang for the buck.
Can you provide a link to measured performance of PB13 vs FV15HP? I would really appreciate that.
tpaxadpom is offline
post #41 of 51 Old 03-27-2013, 09:34 PM
shadyJ's Avatar
Quoted: 1330 Post(s)
Liked: 1350
http://www.data-bass.com/systems
shadyJ is offline
post #42 of 51 Old 03-27-2013, 09:59 PM
tpaxadpom's Avatar
Quoted: 39 Post(s)
Liked: 26
Thank you for the link. I am not sure how you come up with this conclusion: "A shipped FV15HP isn't more expensive than a PB12 Plus (unless you want the gloss black finish) and its performance is measured to be better than the PB13 Ultra".
Take a look at total harmonic distortion of both subs at 110dB SPL.
http://www.data-bass.com/data?page=system&id=51&mset=63
http://www.data-bass.com/data?page=system&id=55&mset=61
Which sub offers more linear response?
post #43 of 51 Old 03-27-2013, 10:04 PM
allredp's Avatar
Any update on decision? I have a SubM HP and my room is similarly sized, though not as challenging potentially. Have not had anything in the room that exceeded it, though my buddy's active Cap was just as strong on movies.
creative>energy
allredp is offline
post #44 of 51 Old 03-29-2013, 08:21 AM
basshead81's Avatar
Quoted: 181 Post(s)
Liked: 5266
i just contacted rythmik and was told for a 20x15 room on concrete slab with 8ft cielings, the f25 is the way to go for a combination of music and hom theatre. i was contemplating 2 of the entry level 12's, but was advised to go with the f25.
Getting Started with REW: A Step by Step Guide -->http://www.roomeqwizard.com/REWhelp.pdf
Mini DSP Tutorial by Neutro --> http://www.avsforum.com/forum/113-su...g-minidsp.html
basshead81 is offline
post #45 of 51 Old 04-01-2013, 11:38 AM
tpaxadpom's Avatar
Quoted: 39 Post(s)
Liked: 26
Another interesting observation is how 12.5Hz max spl numbers differ from measurements done on Ultra with Bash amp. It could be the measurement setup/technique or measurement error or the fact that the older sub subsonic filter tuned differently (high pass filter set to lower frequency). If they were tuned in a similar fashion I would expect to see some gain in max SPL numbers with sledge amp with additional 250W. Instead here is what I am seeing:
http://www.avsforum.com/t/1464484/two-svs-pb12-pluses-vs-one-seaton-submersive-hp-or-one-svs-pb13-ultra-which-would-you-choose/30
vs audioholics measurements:
http://www.data-bass.com/data?page=systems&type=0
15HZ tune:
Sledge amp (1000W) Audioholics 12.5Hz: 89.3dB 16Hz: 105.1Hz
Bash amp (750W) Ilkka 12.5Hz: 93.1dB; 16Hz: 103.5Hz
post #46 of 51 Old 04-03-2013, 12:06 PM
Randy Schmidt's Avatar
Quoted: 46 Post(s)
Liked: 25
Sorry to get off topic just a little bit, but I have a similar question about my sub set up. I have ($) Epik Empires... They are all placed on the left and right of my screen. I had Mark Seaton come out to my theater and run calibration on my subs for my room. We got the placement just right for max output. I am looking to replace the four Epik Empires with something that will give me the low freq output as well as the mid bass slam I am missing. Any thoughts?
Theater: Denon AVR 4520ci - Emotiva XPR-5 - Denon 3313 BDP - L/C/R Klipsch KL7800 THX, SL/SR Klipsch KS7800 THX SBL/SBL, FHL/FHR, FWL/FWR Klipsch 5800W - (2) Epik Empire subs/(1) DIY 18" sub - Darbee Darblet - Epson 5030UB/150" Fixed Mount Screen
Family Room: Denon AVR X6200W - Sony XBR55X930D - Samsung UBD-K8500 - (5) Speakercraft Profile AIM8 One
Randy Schmidt is offline
post #47 of 51 Old 04-03-2013, 12:49 PM
jbrown15's Avatar
Liked: 1993
What's your budget?
jbrown15 is offline
post #48 of 51 Old 04-03-2013, 09:07 PM
Quoted: 46 Post(s)
Liked: 25
$3k
post #49 of 51 Old 04-03-2013, 09:31 PM
craig john's Avatar
Quoted: 513 Post(s)
Liked: 718
Originally Posted by Randy Schmidt View Post
$3k
Randy
Please start your own thread with these types of questions. You'll get more focused replies in a thread specific to your own questions.
More importantly, let the OP have his thread, Don't take his thread away with your similar, but still off-topic inquiries.
Craig
Lombardi said it:
Perfection is not attainable, but if we chase perfection we can catch excellence."
My System
craig john is offline
post #50 of 51 Old 04-04-2013, 12:46 PM
Quoted: 46 Post(s)
Liked: 25
Originally Posted by craig john View Post
Randy
Craig
Understood. Sorry if I offended anyone.
post #51 of 51 Old 04-04-2013, 06:26 PM
craig john's Avatar
Quoted: 513 Post(s)
Liked: 718
No offense taken. It's just that you would be better served with your own thread, as would the OP of this thread. smile.gif
Craig
Lombardi said it:
My System
Svs Pb13 Ultra
