Subwoofer Plate amp Help - AVS Forum | Home Theater Discussions And Reviews
Old 03-22-2013, 12:56 PM - Thread Starter
Gunaa's Avatar
Hi, I got this plate amp from ebay but how do i connect to my subwoofer?
I only see high out and no sub out?
I already have amp to run center, front, rear speakers.
I'm planing to use this plate amp to my car subwoofer.
Gunaa is offline
Old 03-22-2013, 01:35 PM
Bill Fitzmaurice's Avatar
Liked: 4631
There should be two wires to connect the amp to the driver.
Bill Fitzmaurice is offline
Old 03-22-2013, 01:55 PM - Thread Starter
Gunaa's Avatar
I don't see any other wires.
Item link
Gunaa is offline
Old 03-22-2013, 01:56 PM
Tom Vodhanel's Avatar
Quoted: 1565 Post(s)
Liked: 4482
Can you take another picture showing the "face" of the PCB(printed circuit board)? That's the board on the left on the top picture you posted. There should be a couple of terminals labeled + and - somewhere on that board.
EDIT---see you beat me to it by a few seconds!
Anyway----I see the negative terminal in the first picture " SPKR - "
Look for another terminal labeled SPKR +
Tom V.
“The bitterness of poor quality remains long after the sweetness of low price is forgotten" --- Ben Franklin
Tom Vodhanel is offline
Old 03-22-2013, 02:25 PM - Thread Starter
Gunaa's Avatar
Thank you very much!
! found the +. Is this one?
Gunaa is offline
Old 03-23-2013, 11:30 AM
Liked: 4482
Yes that appears to be it.
I have no experience with that particular amplifier so if the seller seems knowledgeable enough it wouldn't hurt to verify things with him/her of course.
Tom V.
