quick technical question .... - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 03-24-2013, 12:58 AM - Thread Starter
nemoreborn's Avatar
At 20 Hz, our subs vary in their maximum output capability. The output at 20 Hz is shown relative to F12.
•F12: 0db (baseline)
•F15: +2db D15: +2db
•FV12: +3db
•E15HP: + 3.5db
•F15HP: +4db
•FV15: +7db
•FV15HP: +9db
•F25: +7db
considering those info ... buying a fv12 at 599$ is almost the same output as buying a f15hp at 1274$ ... what would be the point of buying the fv12 then ????
i know 1 is sealed and 1 is ported , but other than that , if they have the same output , whats the point ?
nemoreborn is offline
post #2 of 11 Old 03-24-2013, 05:49 AM
eljaycanuck's Avatar
Quoted: 1234 Post(s)
Liked: 1808
With sufficient room gain, the F15HP should extend lower than the FV12 (no longer available; replaced by the LV12R). And it may (does?) have greater output at higher frequencies, which is worth something if you plan to play more than just 20Hz notes... wink.gif
And then there's the (subjective?) matter of the sealed F15HP having a cleaner / "tighter" / more "musical" sound than the ported FV12, which only really matters if music - rather than HT - is your primary focus.
eljaycanuck is offline
post #3 of 11 Old 03-24-2013, 12:48 PM - Thread Starter
nemoreborn's Avatar
and btw i made a mistake !! i meant what is the point buying the f15hp !? if the LV12R have the same output ...
post #4 of 11 Old 03-24-2013, 01:00 PM
Liked: 1808
post #5 of 11 Old 03-24-2013, 01:03 PM - Thread Starter
nemoreborn's Avatar
i really need to find a place where i can hear the difference between a ported and a sealed sub .. cause im not sure what to buy at allllllllllll
post #6 of 11 Old 03-24-2013, 01:05 PM - Thread Starter
nemoreborn's Avatar
actualy the only ported sub i heard was a monitor 12 sub .. 300rms ( sealed ) ... and i felt like i had almost no sub compared to the bass my monitor 11 was producing
post #7 of 11 Old 03-24-2013, 01:18 PM
Bill Fitzmaurice's Avatar
Liked: 4667
You can't hear the difference between a ported and a sealed sub because there isn't a difference that can be purely attributed to it being ported or sealed, there are many other factors involved. You can see the difference in their measured responses and maximum output. Data-bass is one place where you can see measured results with different subs.
Bill Fitzmaurice is offline
post #8 of 11 Old 03-24-2013, 01:22 PM
Liked: 1808
... im not sure what to buy at allllllllllll
This thread has a few suggestions in it.
post #9 of 11 Old 03-24-2013, 01:41 PM - Thread Starter
nemoreborn's Avatar
what u mean
post #10 of 11 Old 03-24-2013, 02:47 PM
Liked: 4667
what u mean
post #11 of 11 Old 03-24-2013, 03:11 PM - Thread Starter
nemoreborn's Avatar
oh yea i guesss ...so many newb like me come over and ask the best buy tongue.gif ... well i know its going to be PSA / Rythmik / svs , just need to figure sealed or not and what output needed for this room ..
