Please recommend me a sub at around $250 for my living room - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 03-30-2013, 11:55 AM - Thread Starter
bourmb's Avatar
I am looking for a sub that is up to around $250. My system will be budget minded. Here is my setup:
1. My living room is 19x16x9 with one side partially open to the kitchen. Since this is my living room, a BIC F12 would probably not work as my wife had me move my vintage Altecs to the basement due to their size before I sold them due to lack of use!
2. Due to this being my living room, the sub will most likely be up front and center under next to the electronic cabinet or near the front-corner of the room.
3. Would a front or bottom firing sub work better as it could be moved closer to the wall?
4. I estimate 80% movies/20% music
5. Probably end up getting a Denon AVR-1613 or AVR-1713 (still deciding)
6. I will purchase either the Energy Take Classic 5.0 or Energy RC Micro 5.0 satellites. I am having a very hard time deciding on which ones, but I will stay under $200.
a. The TC go down to 115 Hz and the RC go down to 150 Hz so the sub I get needs to at least cross into the frequency of the satellites
in order to not miss any source.
b. However, would a sub crossing in at 150 Hz need to sit front/center in order since it most likely not be sonically invisible at a high
crossover point?
bourmb is online now
post #2 of 11 Old 03-30-2013, 09:36 PM
blake18's Avatar
Quoted: 315 Post(s)
Liked: 191
If you can push it to $299 the Klipsch RW-12d is by far the best option.
Lumenlab "Community driven video lab".
blake18 is offline
post #3 of 11 Old 03-31-2013, 06:15 AM
basshead81's Avatar
Quoted: 238 Post(s)
Liked: 6513
basshead81 is offline
post #4 of 11 Old 03-31-2013, 06:24 AM
eljaycanuck's Avatar
Quoted: 1346 Post(s)
Liked: 1962
eljaycanuck is offline
post #5 of 11 Old 03-31-2013, 10:04 AM
dave1969's Avatar
dave1969 is offline
post #6 of 11 Old 03-31-2013, 04:56 PM
cel4145's Avatar
Quoted: 2668 Post(s)
Liked: 3002
At $299, the Cadence Acoustics CSX12 Mark II would work well to pair with the Energy Takes or Energy Micros. Lots of midbass output.
Then there is the Premier Acoustics PA-120, which is more within your budget range.
Because of their lower crossover, I would go with the Energy Takes. I have heard them, and they sound very good for small satellite speakers (although not a substitute for larger more full range speakers).
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | HE-400i | NAD HP50 | Sony MDR-1A | Soundmagic E50 & E80 | X5ii | DX50 | E12
cel4145 is offline
post #7 of 11 Old 03-31-2013, 05:02 PM
BeeMan458's Avatar
Liked: 813
I'm going post something you don't want to read. You need to choose speakers that have better specifications. The reason, frequencies >80Hz are locatable (the directionality of your hearing can tell where the sound is coming from) and if you're porting locatable signals over to your sub, you're going confuse the heck out of your listening pleasure as the sound is not going come from where is suppose to be coming from.
crossover point?
Based on your above, I don't recommend doing what you suggest in your original post. Even if used, can you find a set of speakers that comes down to 80Hz?
BeeMan458 is offline
post #8 of 11 Old 03-31-2013, 05:08 PM
cel4145's Avatar
Liked: 3002
+1
If size restriction is not a factor, the Pioneer SP-BS22 and Pioneer SP-C22 are 252 for 5 speakers on Amazon right now. Those would work much better than the Takes or Micros. smile.gif
cel4145 is offline
post #9 of 11 Old 04-01-2013, 09:08 AM
Alan P's Avatar
Quoted: 5083 Post(s)
Liked: 3771
Not necessarily true - if your sub is positioned in the front of the room near your mains, this point becomes (mostly) moot.
Alan P is offline
post #10 of 11 Old 04-01-2013, 08:47 PM - Thread Starter
bourmb's Avatar
I need satellite sized front speakers. This is my main living room and it needs to blend into the decor. Same goes for sub, it can't have the same footprint as my old Altec speakers! What would be a good sub in my price range that has a foot print less than a BIC F12 so I can put it front/center and set at 120Hz cross over. I am mostly going to be listening at moderate levels only.
post #11 of 11 Old 04-02-2013, 04:26 AM
toolbox875's Avatar
Klipsch RW-12d on sale again. $279.99 with coupon EMCXSXV78. Free shipping
http://m.newegg.com/Product/index?itemNumber=N82E16882780078
toolbox875 is offline
