Need some opinions please! - Page 12 - AVS Forum | Home Theater Discussions And Reviews
post #331 of 338 Old 05-31-2013, 02:15 PM - Thread Starter
basshead81's Avatar
Quoted: 234 Post(s)
Liked: 6443
Thanks Beeman! If I hook it up usb power to my laptop there is no hum...must be the dc power supply I used.
basshead81 is offline
post #332 of 338 Old 05-31-2013, 02:23 PM
BeeMan458's Avatar
Liked: 813
Allow me to be envious of your newly acquired miniDSP appliance.
When you ran the miniDSP, did you run it after running other EQ programs such as Audyssey?
BeeMan458 is offline
post #333 of 338 Old 05-31-2013, 04:11 PM
Bond 007's Avatar
Quoted: 2596 Post(s)
Liked: 2061
You should eq and then run YPAO. Right?
Licence to Kill
Bond 007 is offline
post #334 of 338 Old 05-31-2013, 05:56 PM - Thread Starter
basshead81's Avatar
Quoted: 234 Post(s)
Liked: 6443
I ran ypao, didnt like how it sounded at the lp, so I manually adjusted the distance setting, then eq'd with the mini dsp.
oh and I ran usb cord to a cell charger and no hum, so yea I must have a noisy dc power supply.
Its amazing how much tighter and punchier the bass is now the peak is gone. When I get more time l, I am going to tweak some more, I think I can get the graph even smoother and flat out to 14-15hz. Ill add more gain in the 15hz region and adjust the Q. The Mini DSP is a awsome unit!
post #335 of 338 Old 06-06-2013, 03:01 PM - Thread Starter
basshead81's Avatar
Quoted: 234 Post(s)
Liked: 6443
Here is todays efforts after I got home from work. I measured all speakers in 7ch stereo and had to do a bit of eq'ing from my previous graph. With my main speakers added into the equation I had a huge spike in the 80hz range. Yea I know my subs are running hot...for some reason I like them that way...well not this hot but yea.
post #336 of 338 Old 06-06-2013, 03:08 PM
BeeMan458's Avatar
Liked: 813
If all speakers were running, asking the obvious, what happened after 95Hz?
post #337 of 338 Old 06-06-2013, 03:13 PM - Thread Starter
basshead81's Avatar
Quoted: 234 Post(s)
Liked: 6443
Im guessing that's how much hotter my subs are from the other speakers.
post #338 of 338 Old 06-06-2013, 04:21 PM - Thread Starter
basshead81's Avatar
Quoted: 234 Post(s)
Liked: 6443
I only had a half hour to use the equipment. I am going to recalibrate the subs and remeasure...
