Need some opinions please! - Page 4 - AVS Forum | Home Theater Discussions And Reviews
post #91 of 338 Old 04-04-2013, 03:54 PM
Alan P's Avatar
Quoted: 5032 Post(s)
Liked: 3709
Originally Posted by basshead81 View Post
LMAO!
Im thinking about placing one xv15 on each side of the couches like end tables...need to order a mic now.
Your couch will definitely be shaking!!
Alan P is offline
post #92 of 338 Old 04-04-2013, 07:01 PM
Bond 007's Avatar
Quoted: 2594 Post(s)
Liked: 2056
basshead,
http://www.avsforum.com/t/732186/to-bi-amp-or-not-to-bi-amp
Licence to Kill
Bond 007 is online now
post #93 of 338 Old 04-04-2013, 07:37 PM - Thread Starter
basshead81's Avatar
Quoted: 231 Post(s)
Liked: 6382
Originally Posted by Bond 007 View Post
basshead,
thx...sounds like im pissing up a rope lol. live and learn!
basshead81 is offline
post #94 of 338 Old 04-05-2013, 04:12 AM
Bond 007's Avatar
Liked: 2056
This is a great resource too:
http://www.avsforum.com/t/1294455/amplifier-faq
Licence to Kill
post #95 of 338 Old 04-05-2013, 05:11 AM - Thread Starter
basshead81's Avatar
Quoted: 231 Post(s)
Liked: 6382
post #96 of 338 Old 04-08-2013, 02:23 PM - Thread Starter
basshead81's Avatar
Quoted: 231 Post(s)
Liked: 6382
Ok a big update!! I received the xv15's and let me say these bad boys are something sweet. The build quality is nothing short of excellent...I absolutely love the enclosure design!!
Initial hookup after running ypao was me resulting in being severely disappointed!! For some reason ypao wants to pull all the gain out and set the distance to 52ft. However I believe this was attributed to the rocketfish wireless devices. So I removed the devices and hard wired the subs in the front part of the room. I noticed no difference in sound quality other than ypao set the distance to 22ft, which resulted in more output, but I had nulls everywhere. So I hooked the rocketfish devices back up, moved the subs on each end of my couch near field with the ports facing adjacent walls, then manually set up the AVR and phasing...WOW!! These xv15's are so musical, deep, and clean!! Truly Impressed no doubt! All my listening positions are now filled with tight clean bass that drops so low, you almost think there is a earthquake! Now Everybody that comes over will be in the "sweet spot"! Hoping I receive the mic soon so I can take some measurements and post the results... stay tuned!!
post #97 of 338 Old 04-08-2013, 02:30 PM
Alan P's Avatar
Liked: 3709
Congrats basshead! I told ya, PSAs simply rock.
Alan P is offline
post #98 of 338 Old 04-08-2013, 02:32 PM
Alan P's Avatar
Liked: 3709
I predict that pic frame on the left sub ain't gonna stay there long. wink.gifbiggrin.gif
Alan P is offline
post #99 of 338 Old 04-08-2013, 02:33 PM - Thread Starter
basshead81's Avatar
Quoted: 231 Post(s)
Liked: 6382
yes they do!! I appreciate your advice along the way as well!!!
post #100 of 338 Old 04-08-2013, 02:43 PM
Bond 007's Avatar
Liked: 2056
Licence to Kill
post #101 of 338 Old 04-08-2013, 03:07 PM - Thread Starter
basshead81's Avatar
Quoted: 231 Post(s)
Liked: 6382
thanks! my only question is why ypao does not set my distances and gain correctly on my subs? 2 different sets of subs, same problem. no biggie really since i dialed it manually, but yea its wierd.
post #102 of 338 Old 04-08-2013, 03:35 PM
Bond 007's Avatar
Liked: 2056
YPAO isnt the greatest for subs. Add the fact that you have 2 and it is designed for 1 then it will never work properly.
Licence to Kill
post #103 of 338 Old 04-08-2013, 04:23 PM - Thread Starter
basshead81's Avatar
Quoted: 231 Post(s)
Liked: 6382
Lol I wondered...good that makes me feel better. Now Im thinking about using y adapters to plug into both inputs? I have seen opinions both ways...thoughts?
post #104 of 338 Old 04-08-2013, 05:00 PM
Bond 007's Avatar
Liked: 2056
Its unnecessary and has no advantage.
Licence to Kill
post #105 of 338 Old 04-08-2013, 06:18 PM - Thread Starter
basshead81's Avatar
Quoted: 231 Post(s)
Liked: 6382
ahh ok thats what i figured.
post #106 of 338 Old 04-09-2013, 05:02 PM - Thread Starter
basshead81's Avatar
Quoted: 231 Post(s)
Liked: 6382
got my dayton microphone, now trying to setup rew...do i need to calibrate my soundcard to measure frequency or can i skip it? Im a newb with this so all help is greatly appreciated!!
I thought all I needed was a laptop and the umm-6 mic? from reading the rew help section, it says not to use the laptops headphone output? I am confused here?
post #107 of 338 Old 04-09-2013, 05:32 PM
Bond 007's Avatar
Liked: 2056
Wish I could help but thats above my pay grade. I think theres a thread dedicated to that stuff. You may want to look for it and try posting there.
Licence to Kill
post #108 of 338 Old 04-09-2013, 05:55 PM
Bond 007's Avatar
Liked: 2056
I would try browsing through some of this stuff while youre waiting for a response.
http://www.avsforum.com/newsearch?advanced=1&containingforum%5B0%5D=113&output=all&resultSortingPreference=relevance&search=REW&type=all
Licence to Kill
post #109 of 338 Old 04-09-2013, 05:56 PM
BeeMan458's Avatar
Liked: 813
You might have misread the help section as in looking the help section over, or, I might have misunderstood your lament. The help section mentions not using the "input" as opposed to not using the output.
A soundcard (internal or external) with line inputs and outputs. Note that most PC and laptop mic inputs are NOT suitable and should not be used (they have too much gain and most suffer from high noise levels and limited bandwidth). Inexpensive soundcards are typically adequate, a reference measurement or a loopback connection can be used to remove the soundcard's frequency response from the measurement. Examples of USB soundcards which have been found to work well are the Soundblaster MP3+, Soundblaster Live! 24-bit USB External, Turtle Beach Audio Advantage RSM, Behringer UCA202 and the M-Audio MobilePre-USB. Higher quality units that work well are the EMU 0404 and the Tascam 144.
If using a high end sound card, you'll be fine. Also, I'm sure you know this, the UMM-6 is a USB microphone so you'd plug into your laptop using a USB port.
BeeMan458 is offline
post #110 of 338 Old 04-09-2013, 06:02 PM - Thread Starter
basshead81's Avatar
Quoted: 231 Post(s)
Liked: 6382
Originally Posted by BeeMan458 View Post
You might have misread the help section as in looking the help section over, it's mentions not using the "input."
Ok thanks! however I was informed here in this forum all I needed was a umm-6 mic and a laptop...so I obviously need more? My question is what is the best way to interface my hp g70 laptop with my rx-v773 so I can use rew? Or do I not need to do this? I guess Im confused on how to loopback to calibrate my sound card?
post #111 of 338 Old 04-09-2013, 06:17 PM
BeeMan458's Avatar
Liked: 813
Just plug the USB microphone into the laptop. You should need the microphone, a USB cable, your laptop and a downloaded copy of REW. :confused"
If you needed anything else, it would be an independent sound meter to calibrate REW and to set the measuring volume of the subwoofer using the sub's gain knob and the AVR provided pink noise.
That's it. Microphone stand and additional cabling aside, unless a ground loop problem, that's it.
Our measuring kit comprises of:
A microphone.
A microphone stand.
A phantom power supply as we're not able to use a USB microphone.
Connecting cables.
A ground loop isolator.
RCA connectors to connect the isolator to the AVR.
A place to store it all when not in use.
A downloaded copy of REW.
And a boatload of time to measure the room and play with the subwoofer/AVR settings so as do one's best to improve the measuring graph.
That's it.
post #112 of 338 Old 04-09-2013, 06:21 PM - Thread Starter
basshead81's Avatar
Quoted: 231 Post(s)
Liked: 6382
I have all of that and the mic is plugged in, but the tutorial said something about calibrating my sound card first, then the mic? would you mind taking the time to give me a quick step by step for noob guide on how to run this thing for sub measurements? I will paypal you some cash!! Thanks
post #113 of 338 Old 04-09-2013, 06:28 PM
BeeMan458's Avatar
Liked: 813
Also, I do a terrible step-by-step tutorial.
First things first, you're fine if you don't calibrate the sound card. The important thing would be to get you up and running.
The USB microphone should have available, a calibration file. If purchased from Parts-Express, you can download the calibration file, no charge from Dayton.
On YouTube, there's an entry level video you can checkout.
This tutorial should get you moving forward and includes sound card calibration directions.
post #114 of 338 Old 04-09-2013, 06:38 PM - Thread Starter
basshead81's Avatar
Quoted: 231 Post(s)
Liked: 6382
my confusion is how to interface my laptop with my AVR, which the tutorial speaks nothing about? If I can not use the headphone out on my Laptop how to I get audio to my AVR? What am I missing??
Can I use the hdmi out on my laptop direct to my avr?
post #115 of 338 Old 04-09-2013, 06:54 PM
BeeMan458's Avatar
Liked: 813
You can use the headphone out to your AVR.
My setup is such that I cable from the computer's headphone out to the AVR using the AUX setting and the front two RCA connections.
The settings to the computer headphone out gets a bit tricky.
If using Windows 7 or something Windows related.
Set the speaker volume to 100%
Set the microphone level in the computer setting to 15 or so.
...right click the speaker icon
...left click "recording devices"
...double left click the check "line in"
Doing the above should activate the USB connection for the USB microphone.
post #116 of 338 Old 04-09-2013, 07:28 PM - Thread Starter
basshead81's Avatar
Quoted: 231 Post(s)
Liked: 6382
here is my first measurement. I used my hdmi out from my laptop to avr and downloaded the mic calibration file. I then proceeded to calibrate the mic spl at 60db...however the spl seems off because it sure as hell seems louder than 70db(my avr was @ -1.5db)...if this is not correct let me know? this is two measurements taken, all i did was change distance settings on subs.
post #117 of 338 Old 04-09-2013, 07:40 PM
Bond 007's Avatar
Liked: 2056
lol
Licence to Kill
post #118 of 338 Old 04-09-2013, 07:42 PM - Thread Starter
basshead81's Avatar
Quoted: 231 Post(s)
Liked: 6382
lol
post #119 of 338 Old 04-09-2013, 07:42 PM - Thread Starter
basshead81's Avatar
Quoted: 231 Post(s)
Liked: 6382
edit* looking at the graph again they do not appear to be rolling off hard, it just looks that way at first because of the boost in the 30hz range.
post #120 of 338 Old 04-10-2013, 06:39 AM - Thread Starter
basshead81's Avatar
Quoted: 231 Post(s)
Liked: 6382
Ok calibrated my sound card and ran another measurement...thoughts?
