SVS-Outlaw..... - AVS Forum | Home Theater Discussions And Reviews
View Poll Results: SVS or Outlaw
Outlaw 11 55.00%
SVS 4 20.00%
other 5 25.00%
Voters: 20. You may not vote on this poll
post #1 of 12 Old 04-03-2013, 09:37 PM - Thread Starter
deepat04's Avatar
Quoted: 94 Post(s)
Liked: 94
Need help deciding on what to buy, this will go in a 20x20x9 room. 80% HT HDTV 20% music/gaming, listening levels moderate volume, upgrading from a PL-200.
I am debating between SVS PB12NSD or an Outlaw LFM-1 EX
I like reviews on the SVS and warranty, free shipping, no CA TAX
The Outlaw LFM-1EX has similar specs and is currently on sale.
Based on specs and savings the outlaw seems like an easy choice, I'm hesitant due to the different reviews one mainly from audioholics regarding the build quality and driver used.
What are the main differences between the two subwoofers? Is the SVS worth the extra $140? I am also open to other suggestions in this price range.
Also what differences will notice between these two subwoofers vs the PL200 based on my usage? Thanks in advance
deepat04 is offline
post #2 of 12 Old 04-03-2013, 11:54 PM
shadyJ's Avatar
Quoted: 1330 Post(s)
Liked: 1350
Go for the Outlaw, it is a higher performing sub. The build quality and driver is on par with a PB12 NSD. Compare their measurements here, the NSD gets beaten easily. If they were equally priced it wouldn't be much of a decision, but at the current Outlaw sale, this is a complete no-brainer. Your Pl-200 is on data-bass as well, so you can compare it to the others. Remember that a 6 dB difference is a doubling of power so you would need two subs to equal one that has 6 dB more output. There are big swaths of mid bass where a single LFM-1 EX is like having two PB12 NSDs.
shadyJ is offline
post #3 of 12 Old 04-04-2013, 12:09 AM
Randall.White's Avatar
Quoted: 353 Post(s)
Liked: 89
I have the Outlaw LFM-1EX now and upgraded from the PL-200. Honestly, no comparison. The Outlaw sounds amazing, before the lady of the house would turn off the BIC sub because it hurt her ears. Now she always remembers to turn it on before she watches a movie. I picked mine up on Black Friday for a little less than the sell price but this sale has me thinking on grabbing another one.
My room is roughly 3.000+ and the Outlaw fills the room. I just love the BOOOOOOM scenes and really want the impact. I'd say the only downside of the Outlaw is the size, it's big and heavy.
Randall.White is offline
post #4 of 12 Old 04-04-2013, 04:01 AM
flickhtguru's Avatar
Liked: 110
There will be a huge difference with the Outlaw EX compared to the PL-200: more SPL, deeper bass, more accurate bass, room shaking bass.
One thing to keep in mind is you have a square room which are the worst rooms for standing waves and room modes and nulls. So make sure you pay close attention to sub placement AND listening position. I would think the listening position should be 6 to 8 feet from the rear wall. You want to avoid sitting at the 50% mark.
Shawn
flickhtguru is offline
post #5 of 12 Old 04-04-2013, 06:35 AM
basshead81's Avatar
Quoted: 184 Post(s)
Liked: 5354
with your room being 3600^3 I would look into 2 12" subs or atleast 1 dual driver 15". the 1 12" sub will not be enough if your looking for high output room pressurizing bass. most internet direct sub companies will recomend 1 15" or 2 12" up to 3000^3.
Getting Started with REW: A Step by Step Guide -->http://www.roomeqwizard.com/REWhelp.pdf
Mini DSP Tutorial by Neutro --> http://www.avsforum.com/forum/113-su...g-minidsp.html
basshead81 is offline
post #6 of 12 Old 04-04-2013, 07:08 AM
eljaycanuck's Avatar
Quoted: 1246 Post(s)
Liked: 1826
+1 to the LFM-1 EX. And, IMO, for a room that size you'll likely want two of them. (Buy one now, add another one the next time a sale comes around.)
eljaycanuck is offline
post #7 of 12 Old 04-04-2013, 02:10 PM - Thread Starter
deepat04's Avatar
Quoted: 94 Post(s)
Liked: 94
Thanks for the replies.
I am leaning towards the outlaw, for those that voted other what else would you recommend?
deepat04 is offline
post #8 of 12 Old 05-26-2013, 04:26 AM
steve nn's Avatar
Liked: 433
So many good subs now. Another choice you might consider..
http://www.hometheatershack.com/forums/speaker-subwoofer-reviews/67309-rythmik-lv12r-subwoofer-review.html
http://www.rythmikaudio.com/LV12R.html
Klipsch RB-75
Klipsch C-7
Klipsch RB-35
On-going SW management class
Denon
PS3
steve nn is offline
post #9 of 12 Old 05-26-2013, 07:36 AM
brian6751's Avatar
Quoted: 909 Post(s)
Liked: 718
The outlaw subs sound great. I owned the EX's little brother for a while. Best bang for the buck. I have also owned the older pb12nsd.
The svs is a little bit higher quality product IMO. Mostly fit and finish. Not saying the outlaw is bad. I just think svs is a little better.
Also, saying that the outlaw has more output based on those measurements is not totally correct. The outlaw shows more mid bass output but that's because the svs is dsp limited at those frequencies to have a flatter overall response.
I would bet they would be about the same in a room with EQ.
Is the svs worth $140 more? Not sure about that. Depends on the customer I guess.
That's not science! - Cyborg
Steam ID: The Barbeerian
Rivers Edge Theater
brian6751 is online now
post #10 of 12 Old 05-26-2013, 08:59 PM
Quoted: 73 Post(s)
Liked: 112
The Rythmik is definitely worth a look.
rnatalli is offline
post #11 of 12 Old 05-27-2013, 01:10 AM - Thread Starter
deepat04's Avatar
Quoted: 94 Post(s)
Liked: 94
Went with dual SB12's
deepat04 is offline
post #12 of 12 Old 05-27-2013, 01:25 AM
steve nn's Avatar
Liked: 433
Klipsch RB-75
Klipsch C-7
Klipsch RB-35
Denon
PS3
steve nn is offline
