Placing Left and Right speakers on top of subwoofers - AVS Forum | Home Theater Discussions And Reviews
post #1 of 17 Old 04-06-2013, 09:00 AM - Thread Starter
Blu_One's Avatar
Liked: 62
Does anyone see a problem with this setup?? In terms of vibrations etc.. I cranked it up with music pretty good and everything seemed pretty solid..
65" Panasonic ST60 | Onkyo 809 | Oppo 103 | Apple TV4 | Darbee Darblet | 5.2 system - 5x Arx A2 + 2x SVS SB12-NSD
Blu_One is offline
post #2 of 17 Old 04-06-2013, 09:17 AM
Bill Fitzmaurice's Avatar
Liked: 5687
The primary issue is room modes. Subs look good under mains, and symmetry of placement is pleasing to the eye, but good looks and symmetry seldom give the best result where low frequencies are concerned. Usually modes are best controlled when two subs are placed as far apart as possible. Do a search, there are plenty of sub placement threads.
Bill Fitzmaurice is offline
post #3 of 17 Old 04-06-2013, 09:22 AM
Toe
Toe's Avatar
Quoted: 1984 Post(s)
Liked: 2283
I am using large bookshelf speakers (JBL S38s) and have to put them on top of my PB13 Ultra subs. Never had any issues and I have played countless BIG LFE films over the years. Probably not ideal putting mains on top of subs, but I have not had any issues as far as them falling down or anything.
Toe is online now
post #4 of 17 Old 04-06-2013, 09:49 AM
croseiv's Avatar
What you have done is create a floorstander with a powered woofer basically. I see no problem with it at all. In fact it is a very good idea and will help with imaging/balance of the lower end when listening to music.
croseiv is offline
post #5 of 17 Old 04-06-2013, 10:03 AM - Thread Starter
Blu_One's Avatar
Liked: 62
Sounds great then, thanks for the advice !
Blu_One is offline
post #6 of 17 Old 04-06-2013, 11:49 AM
Liked: 5687
Or not. One of the main reasons why floor standers have been supplanted by separate mains and subs is that separates allow the mains to be placed where they work best, and the subs to be placed where they work best. In the vast majority of cases they don't both work best when stacked.
post #7 of 17 Old 04-06-2013, 01:22 PM - Thread Starter
Blu_One's Avatar
Liked: 62
Well this is in the main living/tv room. My wife has somehow allowed me to mount a 60" flat screen, have five massive speakers, including two on floating glass shelves for the surrounds, and two 12" subs, and amazingly she's about to give me the go ahead to swap out the 60" for a 70" beauty.. so the subs look good and sound good where they're at now, and they're not going anywhere else.. I just wanted to make sure I wasn't creating a huge problem by setting it up that way.. Sometimes, I guess you just can't get it all
Blu_One is offline
post #8 of 17 Old 04-06-2013, 01:26 PM
sivadselim's Avatar
Quoted: 268 Post(s)
Liked: 225
It's fine.
But I would pull all the speakers, particularly that center, as far forward as possible in their respective locations. In other words, to the front edge of whatever they are sitting upon.
"All men are frauds. The only difference between them is that some admit it. I myself deny it."
sivadselim is offline
post #9 of 17 Old 04-06-2013, 01:31 PM - Thread Starter
Blu_One's Avatar
Liked: 62
Originally Posted by sivadselim View Post
It's fine.
Good point, I'll try that, which means I'll have to run Audyssey again.. lol
Blu_One is offline
post #10 of 17 Old 04-06-2013, 01:32 PM
craig john's Avatar
Quoted: 554 Post(s)
Liked: 798
One of the primary reasons to use subwoofers and Bass Management is because the positions of the speakers is almost never the optimal placements for bass response. Subs should be placed where they provide the best transfer function of bass to the listening position(s). Placing the subs underneath mains and making a "floorstander with a powered woofer" violates that principle. Sometimes you gotta do what you gotta do, but let's not portray a compromised setup as a "very good idea."
Craig
Lombardi said it:
"Perfection is not attainable, but if we chase perfection we can catch excellence."
My System
craig john is offline
post #11 of 17 Old 04-06-2013, 01:40 PM - Thread Starter
Blu_One's Avatar
Liked: 62
Craig
It sounds damn good the way it's setup now though, including the killer bass. I guess it could always be better, nothing's perfect, but like I said some compromise in regard to equipment placement must be made from my part since this setup is on the ground floor, in the main living/tv room.
Blu_One is offline
post #12 of 17 Old 04-06-2013, 01:48 PM
craig john's Avatar
Quoted: 554 Post(s)
Liked: 798
Good for you. When I tried putting my subs underneath my speakers, it looked really cool. It measured poorly and it sounded like Schlitz. I moved them to some distributed placements and the measurements improved radically. The sound improved in a similar fashion.
Craig
Lombardi said it:
My System
post #13 of 17 Old 04-06-2013, 02:54 PM
Toe
Toe's Avatar
Liked: 2283
Craig
Every room is different. Between my rear sub and my front subs which are right below my mains, I could not ask for better response. Of course it took multiples to get there, but you can certainly get good response with the subs below the mains. Until you run some FR sweeps, you wont know for sure and exactly how your particular room, sub position and seating position all correspond.
In my room, there was no single spot that covered everything well which is why I had to go to multiples.
Having said all that, OP have you experimented with one sub in the rear and one up front? After all my sub shifting, swapping and experimenting, subs in front and rear gave me the best results in my 12x17 sealed room.
Toe is online now
post #14 of 17 Old 04-06-2013, 02:57 PM
Toe
Toe's Avatar
Liked: 2283
EDIT: Double post............damn phone.......or maybe I should say damn user. biggrin.gif
Toe is online now
post #15 of 17 Old 04-06-2013, 03:46 PM
craig john's Avatar
Quoted: 554 Post(s)
Liked: 798
Agree with everything you said. The "distributed" multiple subs will provide optimal response. I have 2 subs in the front, one between the R and C, and one on the L at 1/5 of the wall length. The 3rd sub is in the rear at 4/5 of the wall length. My seating is at 1/3 of the long dimension. The "system" yields this response:
(This also shows the added response of PGM2 in my Submersive HP amps. PGM2 adds output at the lowest frequencies; hence the rising response at ULF's.)
Craig
Lombardi said it:
My System
post #16 of 17 Old 04-06-2013, 03:59 PM
Toe
Toe's Avatar
Liked: 2283
Looks excellent Craig. That is very close to how I have my subs placed as well. What are your room dimensions just out of curiosity?
Toe is online now
post #17 of 17 Old 04-06-2013, 04:02 PM - Thread Starter
Blu_One's Avatar
Liked: 62
There isnt really any space in the back (theres the couch and then the wall, and the couch is only 9.5ft away from the screen..). That's why I was hoping everything would work out 'ok' with having them under the mains.
Blu_One is offline
