Sub help - AVS Forum | Home Theater Discussions And Reviews
post #1 of 37 Old 04-07-2013, 01:47 PM - Thread Starter
HarleyBC's Avatar
Newbie here, and I need a little help deciding which sub to go with. I'm in the process of putting a home theater together, and the sub is the last thing I need to get. I've got a fairly large room (24x18) with a cathedral ceiling. I've sort of narrowed the choice down between a kipsch sw-112 or a hsu Vtf-2 mk4. I've got a budget of about $600...due to the budget and WAF factor, I need to go with 1 sub for the time being. I can always add an additional one later.
So which way should I go?
HarleyBC is offline
post #2 of 37 Old 04-07-2013, 01:58 PM
eljaycanuck's Avatar
Quoted: 1234 Post(s)
Liked: 1808
IMO, the SVS PB-1000 (one now...and another one later on?) would be a very solid choice:
- 10" driver
- 300W RMS amp
- 19-270Hz +/-3dB
- $499, shipped
eljaycanuck is offline
post #3 of 37 Old 04-07-2013, 02:37 PM
shadyJ's Avatar
Quoted: 1330 Post(s)
Liked: 1350
Go for a Outlaw Audio LFM-1 EX, right now is on on sale for $630 shipped, it will have far better performance than the VTF2, PB1000, or SW-112. You have a big room and you will need all the output you can afford.
shadyJ is offline
post #4 of 37 Old 04-07-2013, 02:44 PM
BeeMan458's Avatar
Liked: 813
Does the WAF apply to one sub or the $600.00 budget? If you can buy two subs with the $600.00 budget, I'd go with a pair of Klipsch, RW-12d which can be had, delivered (minus local taxes), for $279.99 from Newegg. Two RW-12d's will is a better choice than one PB-1000 but if you're limited to one subwoofer, the better way to go would be the SVS, PB-1000.
Two lesser subs are better than one next step up, better sub due to spreading sound waves out and around the room, known as smoothing. Smoothing gets rid of sonic holes or nulls where sound waves meet in the room and in effect, cancel each other out.
BeeMan458 is offline
post #5 of 37 Old 04-07-2013, 03:51 PM
vardo's Avatar
Quoted: 41 Post(s)
Liked: 130
I would go with the Outlaw Audio LFM-1 EX. It's basically has the same features of a HSU VTF3/4 or the Hsu VFt2/3....and has the variable tuning of one port
plugged for max ex, unplugged for max output. You will love it....and multiples are nice for smoothing out and evening out the bass across
the listening area, so Beeman has a point when he says get multiples (I have 3). If you can, save up for a second sub (try to make it match the Outlaw,
or HSU) depending on which you decide to go with.
I've had the VTF3/3 and VTF2/3 and both would be very capable subs in your listening area. Great subs with superb customer service from HSU.
l do own an Outlaw audio piece (not a sub), and their customer service is very good also.
vardo
vardo is offline
post #6 of 37 Old 04-07-2013, 04:05 PM
BeeMan458's Avatar
Liked: 813
Originally Posted by vardo View Post
(I have 3).
Hi Vardo. Since our last interaction, we've added a third Klipsch sub, an on sale, RW-12d sub from Newegg. The room finally sounds alive.
(still breaking in the sub and a bit more to go in properly integrating the addition into the room's acoustics)
post #7 of 37 Old 04-07-2013, 04:23 PM
vardo's Avatar
Quoted: 41 Post(s)
Liked: 130
Hey Bee,
How are ya?!
Sounds like (per your posts) you are one happy guy with the Klipsch RW-12D as your third sub. Really opens things up!
Nothing like being surrounded by bass......betcha it sounds great.
I've got a 3rd PSA XV-15 being delivered next Tuesday. Had to experiment around before ordering it (put another but
very dissimilar sub directly behind the listening area tongue.gif ).
Made a huge difference....so I could not help myself and ordered a third sub from PSA smile.gif .
Really helps out with the null I have......that happens when you sit right in the middle of a 20'L room.
Anxious to see the result of your (freq curve) when all is said and done.
vardo
vardo is offline
post #8 of 37 Old 04-07-2013, 06:15 PM
BeeMan458's Avatar
Liked: 813
post #9 of 37 Old 04-07-2013, 06:47 PM - Thread Starter
HarleyBC's Avatar
I had thought about the rw-12d, but it seemed like there were a lot of problems in shipping (broken grills, loose ports, etc). I got a little apprehensive about that.
And the WAF factor is mostly the budget. Although she would probably think 2 big subs is a bit overkill. But if those 2 would be better than 1 of the others mentioned, then I could probably persuade her. Just a little nervous of what would come in the two packages from newegg.
HarleyBC is offline
post #10 of 37 Old 04-07-2013, 06:58 PM
vardo's Avatar
Quoted: 41 Post(s)
Liked: 130
HarleyBC....
Those Klipsch subs for $299 are probably the best deal on the internet.
If you can convince the wife, go for it! 2 subs will really fill out the bass.
vardo
vardo is offline
post #11 of 37 Old 04-07-2013, 07:26 PM
nemoreborn's Avatar
maybe sound stupid but ... WAF mean ?
nemoreborn is offline
post #12 of 37 Old 04-07-2013, 07:29 PM
BeeMan458's Avatar
Liked: 813
The last day of the $279.99 deal, is tomorrow. With local taxes applied to the purchase price, our tab was $300.99. Tick-tock.
As to the broken grills, based on what others have had to post, a call to Klipsch customer service will reward you with a replacement grill.
As to the loose tube issue, simply sticking your hand in the vent opening and pulling on the tube, moves the loose porting tube back into place and if need be, simply remove the driver and glue that puppy into place.
Despite these minor inconveniences, the RW-12d is the Top Dog of this price point. The box is huge as the sub is double boxed, a factory box, inside a larger shipping box, supported with thick Styrofoam padding panels; well packed.
Remember, two subs is better than one sub, it's da law.
Hope the above helps.
post #13 of 37 Old 04-07-2013, 07:30 PM
BeeMan458's Avatar
Liked: 813
Wife Approval Factor.
post #14 of 37 Old 04-07-2013, 07:32 PM
nemoreborn's Avatar
LOL ...
post #15 of 37 Old 04-07-2013, 11:48 PM
jarretc's Avatar
Liked: 130
I just ordered two rw-12d subs from newegg last week. They came in just the sub box and not double boxed like I had read about others getting online.
I was prepared to find a broken grille or loose port but both subs didn't have any issues whatsoever. Maybe I got lucky but you also have to realize that people will complain far more than they will praise. So you're going to hear more about the issues versus all the perfect shipments.
That said, I would recommend to get 2 of these. And as others have stated the fixes are very minor and easy to fix by yourself.
Denon X4000
Power Sound Audio (MT-110 / MTM-210C / MT-110)
Oppo BDP-103
Dual Power Sound Audio Triaxes
Sony KDL60W630B
jarretc is offline
post #16 of 37 Old 04-08-2013, 06:32 AM
basshead81's Avatar
Quoted: 181 Post(s)
Liked: 5265
Hey Bee,
How are ya?!
vardo
triple xv15's....now thats what im talkin bout jack!
Getting Started with REW: A Step by Step Guide -->http://www.roomeqwizard.com/REWhelp.pdf
Mini DSP Tutorial by Neutro --> http://www.avsforum.com/forum/113-su...g-minidsp.html
basshead81 is offline
post #17 of 37 Old 04-08-2013, 09:11 AM - Thread Starter
HarleyBC's Avatar
Let's assume that the WAF is far too great biggrin.gif...and thus requiring a single sub. If you had to pick one, which one would you go with?
I appreciate all the help. These forums have a ton of very useful info...thanks again!
HarleyBC is offline
post #18 of 37 Old 04-08-2013, 09:18 AM
wronganswer's Avatar
Klipsch rw12 or Big America PL200 are great budget subs
wronganswer is offline
post #19 of 37 Old 04-08-2013, 09:51 AM
BeeMan458's Avatar
Liked: 813
Yes, the WAF is a powerful force indeed but I bet if the husband tries, he'll find a way to slowly get a second or third sub into the room. Incessant whining has been known to work. tongue.gif
"Crap, shut up! Yes, if you'll shut up, put ten subs in the room!"
post #20 of 37 Old 04-08-2013, 12:43 PM
Alan P's Avatar
Quoted: 4697 Post(s)
Liked: 3327
Hey Bee,
How are ya?!
tongue.gif ).
vardo
This is almost my exact experience except I have 2 XS15s. I'm ordering 2 more very shortly. biggrin.gif
Alan P is offline
post #21 of 37 Old 04-08-2013, 01:38 PM
BeeMan458's Avatar
Liked: 813
Hi Vardo.
Can't say it's all said and done but the graph is looking mighty good, +/-3dB from 19Hz to 78Hz and then that pesky null kicks in.
10dB graph, no smoothing applied:
For all the effort and expense, we're getting a solid 19Hz and this from boxes originally tuned to 28Hz. And even though obviously needing to eliminate that glaring null, we're still not using room treatments. tongue.gif
post #22 of 37 Old 04-08-2013, 03:43 PM - Thread Starter
HarleyBC's Avatar
Any other thoughts on the Outlaw vs Hsu listed above?
HarleyBC is offline
post #23 of 37 Old 04-08-2013, 10:22 PM
cel4145's Avatar
Quoted: 2660 Post(s)
Liked: 2991
The EX vs. the HSU VTF-2 MK4? The EX is the winner free and clear. Now the choice between the VTF-3.4 and the EX would be a contentious one, when the EX is at regular price.
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | NAD HP50 | AKG K550 | Soundmagic E50 & E80 | DX50 | E12 | X1
cel4145 is offline
post #24 of 37 Old 04-09-2013, 01:49 AM
cesarrpha's Avatar
cesarrpha is offline
post #25 of 37 Old 04-09-2013, 05:48 AM
Joe0Bloggs's Avatar
Any 15" or 18" subs available for his $600 budget?
Joe0Bloggs is offline
post #26 of 37 Old 04-09-2013, 05:52 AM
basshead81's Avatar
Quoted: 181 Post(s)
Liked: 5265
klipsch sw-115 400watt rms for 649.00 shipped on ebay. bnib but they are scratch and dent...thats the closest youll get to 600.00 for a decent 15" sub. I got a quote for 1200.00 shipped for 2. However with the lack of reviews , I went with PSA XV15's.
post #27 of 37 Old 04-09-2013, 07:16 AM
BeeMan458's Avatar
Liked: 813
In the case of two subwoofers, a whole heck of a lot of cardboard. tongue.gif
post #28 of 37 Old 04-10-2013, 05:10 PM - Thread Starter
HarleyBC's Avatar
I found a Klipsch SW-115 for a little over my $600 budget...compared to the Outlaw, Hsu or SVS, would that be the best option for me?
HarleyBC is offline
post #29 of 37 Old 04-10-2013, 05:41 PM
capricorn kid's Avatar
Liked: 25
Hi Vardo.
Wow...that really is a great graph from the RW12Ds...I have 2 RW 12Ds and 2 PL-200s. Since I moved all four of them to the front of the room, my response looks very good also.
Klipsch Synergy 3 speakers
Dual Klipsch RW 12D subs
Velodyne SMS-1
Sony STR-DG 720
Panasonic BDT 460 bluray player
Panasonic PT-AE 8000u projector
capricorn kid is offline
post #30 of 37 Old 04-10-2013, 06:10 PM
wvu80's Avatar
Quoted: 320 Post(s)
Liked: 285
wvu80 is offline
