more than 2 sub on 7.2 avr ... - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 04-07-2013, 07:43 PM - Thread Starter
nemoreborn's Avatar
how can i connect more than 2 sub on my rxa1010 since it only have 2 sub out ? can i just buy a splitter and use it on one of the output !??
ive been told before it would lower the sound of the 2 subs that are connected behind that splitter ...( since the signal is splitted in half )
nemoreborn is offline
post #2 of 3 Old 04-07-2013, 07:50 PM
BeeMan458's Avatar
Liked: 813
This is the splitter that I'm currently using and once gain matched, any signal strength loss is ameliorated.
Ten bucks delivered and top of the line build quality.
BeeMan458 is offline
post #3 of 3 Old 04-07-2013, 08:28 PM
Bill Fitzmaurice's Avatar
Liked: 4840
Use a Y connector. The voltage to the inputs of both subs will be the same as they're parallel loads. There is no signal loss.
Bill Fitzmaurice is offline
