what is needed for REW - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 51 Old 04-12-2013, 07:33 AM
basshead81's Avatar
Quoted: 179 Post(s)
Liked: 5202
i would get a seperate spl meter that way its cordless and you can walk around the room and see the areas where bass is loudest...be a little hard to do with a cord attatched, depending on how big your room is.
Getting Started with REW: A Step by Step Guide -->http://www.roomeqwizard.com/REWhelp.pdf
Mini DSP Tutorial by Neutro --> http://www.avsforum.com/forum/113-su...g-minidsp.html
basshead81 is offline
post #32 of 51 Old 04-12-2013, 08:02 AM
BeeMan458's Avatar
Liked: 813
And if you should decide you want to take the sound measuring device outside, you'd need a really long cord. There's no need to limit use of a sound meter to calibration REW or setting the gain on one's subwoofer.
Some folks think a sound meter is only used to setup one's sound system. Sound meters make great toys to take on walks or check out how loud your generator or automobile is. It's always fun to pull the sound meter out when watching a movie to see how loud it gets during a particular action scene in a movie. One can take sound meters to work and measure industrial noise levels or see how loud the noise level in the cab of their monster truck is. But if taking a sound meter into the great outdoors, one will need a sound meter that measures <40dB.
BeeMan458 is offline
post #33 of 51 Old 04-12-2013, 08:32 AM
basshead81's Avatar
Quoted: 179 Post(s)
Liked: 5202
Some folks think a sound meter is only used to setup one's sound system. Sound meters make great toys to take on walks or check out how loud your generator or automobile is. It's always fun to put the sound meter out when watching a movie to see how loud it gets during a particular action scene in a movie. One can take sound meters to work and measure industrial noise levels or see how loud the noise level in the cab of their monster truck is. But if taking a sound meter into the great outdoors, one will need a sound meter that measures <40dB.
very good point!
post #34 of 51 Old 04-12-2013, 04:57 PM
Ray77085's Avatar
Quoted: 132 Post(s)
Liked: 160
Originally Posted by datranz View Post
Buy the minidsp USB mic, it's integrated with REW with spl meter, you don't need a separate spl meter
Can you or anybody include the link on where to buy the UMIK-1 | miniDSP ? . I don't see any on Amazon , Parts Express etc.
MY 5.4.4 SET UP.
Onkyo TX-NR809, Denon X4200 (Klipsch-KF-28 mains),( Center KC-25), (side surrounds Primus P363), (Front height-Pioneer Dolby Atmos Enabled Add-On Speakers) ( Back height- Onkyo SKH-410 Dolby Atmos-Enabled Add-On Speakers) 2 each Klipsch RW12D subs. HSU VTF-3 MK3 and HSU VTF-3 MK4 subs.
Mitsubishi 3D DLP MODEL73-738, DarbeeVision DVP-5000.Pioneer BDP-62FD.
Ray77085 is offline
post #35 of 51 Old 04-12-2013, 07:07 PM - Thread Starter
nemoreborn's Avatar
directly from them ... www.minidsp.com
nemoreborn is offline
post #36 of 51 Old 04-13-2013, 04:46 AM
Ray77085's Avatar
Quoted: 132 Post(s)
Liked: 160
I wonder why they are not readily available from other vendors ? Any way thanks and this is what I need correct ?
Here's the link.
http://www.minidsp.com/products/acoustic-measurement/umik-1
MY 5.4.4 SET UP.
Ray77085 is offline
post #37 of 51 Old 04-13-2013, 05:00 AM - Thread Starter
nemoreborn's Avatar
Here's the link.
correct
post #38 of 51 Old 04-13-2013, 12:26 PM
landshark1's Avatar
Quoted: 18 Post(s)
Liked: 62
Question guys.
I have a older (late 2008) Macbook Pro that I could get a minDisplay port -> HDMI adapter. And could run Win7 via Bootcamp too. However, according to Apple, my model's display port doesn't support audio out via HDMI/display port. So what do I do if I want to try out REW + MiniDSP mic?? Or what else do I need??
I've seen Omnimic in action before, and seems pretty simple to connect/use since it comes with a DVD disc that you just play it through your DVD player and have the mic connect to your laptop for measurement. How does REW work? Is it generate all the tones directly from the computer and output it to the AVR instead of using a DVD disc like Omnimic?
landshark1 is offline
post #39 of 51 Old 04-13-2013, 01:53 PM
BeeMan458's Avatar
Liked: 813
Originally Posted by landshark1 View Post
Question guys.
I have no idea about Apple to Win7 conversions. As to the question regarding how does REW work? It's as you described with Omnimic. There's a measurement feature which includes a user defined frequency range, using the computer's headphone out, plays a tone sweep that's recorded and graphically displayed on the computer's screen. There's a bit of a steep learning curve but once past the frustration of the learning curve, it's pretty much point-n-click operation.
Using today's measuring effort, here's an example of what one can expect to see on their computer screen when taking measurements with REW.
post #40 of 51 Old 04-14-2013, 07:36 AM
colohtpc's Avatar
Is this a great found deal or is this a dud? Never heard of the brand but the discount looks good. Does anyone have any experience or knowledge of this meter?
http://www.amazon.com/dp/B005E8MV78/ref=dra_a_cs_mr_hn_it_P1300_1000?tag=dradis-20
colohtpc is offline
post #41 of 51 Old 04-14-2013, 07:48 AM
BeeMan458's Avatar
Liked: 813
Based on personal experience, personal needs included in my bias', this is a dud due to it being limited to >35Hz and having an accuracy of +/-3dB.
We deal in a world that is +/-3dB sensitive and this meter does not compliment that standard. One should look for a sound level meter that holds to a tighter, calibrated standard.
(my above is not a slam of the sound level meter itself)
The Amazon reviews are not particularly encouraging either.
After purchasing and using four sound level meters, the Radio Shack, digital sound meter included in this basket of sound meters, this is the meter I settled on.
It's big, bulky and I flat out love it. My one and only complaint, the back light stays on for "ONLY" some five seconds. Very, very, very annoying when measuring in the dark during a movie screening.
post #42 of 51 Old 04-14-2013, 07:54 AM
Bill Fitzmaurice's Avatar
Liked: 4628
They are:
http://www.parts-express.com/pe/showdetl.cfm?partnumber=390-808
Dayton doesn't make products, they source them. It would appear that Dayton and MiniDSP both source this mic from the same manufacturer.
It only has A weighting, useless for measuring speakers.
Bill Fitzmaurice is online now
post #43 of 51 Old 04-14-2013, 08:00 AM
BeeMan458's Avatar
Liked: 813
Good catch.
post #44 of 51 Old 04-14-2013, 08:08 AM
colohtpc's Avatar
Originally Posted by Bill Fitzmaurice View Post
They are:
Thank you, have no idea what specs I should be paying attention to as I begin to explore some measuring equip.
colohtpc is offline
post #45 of 51 Old 04-14-2013, 08:23 AM
BeeMan458's Avatar
Liked: 813
In the simple, the above linked microphone with linked sound level meter, coupled to a freeware copy of REW, all connected by cables and your computer, should get you where you want to go.....well, we'll say, the ability to successfully measure your room as you're on your own with everything else.
post #46 of 51 Old 08-13-2013, 05:58 PM
iron-marshal's Avatar
Can somebody clarify for me: I read in an earlier post that to save money one could simply connect their SPL directly to the computer rather than buy a usb mic. Is this correct? Are there any downsides to this approach? I've already got an SPL and would prefer not to buy a mic if possible.
iron-marshal is offline
post #47 of 51 Old 08-13-2013, 06:03 PM
basshead81's Avatar
Quoted: 179 Post(s)
Liked: 5202
no you need a mic...spl meter is simply another tool to aid in the process of correctly setting up a sub(s)
post #48 of 51 Old 08-15-2013, 12:50 AM
braveheart123's Avatar
Quoted: 311 Post(s)
Liked: 273
Yes you can. But the sound card on your pc/laptop must have a "Line-in" jack. It should also have a "Line-out" jack so you can loop back and measure flatness curve of the internal sound card itself. That will be required by REW for accurate measurements.
Mic/headphone jacks won't work for input/output ; they have a lot of inherent noise.
History is written by those who have hanged heroes ...
Main System: PSB X2T, PSB XC, PSB XB, Cambridge Audio Azur 751R, Rythmik FV15HP, PSB S500
braveheart123 is offline
post #49 of 51 Old 08-15-2013, 08:03 AM
Thanks for the clarification. Looks like its off to get a mic for me.
post #50 of 51 Old 08-15-2013, 08:17 AM
BeeMan458's Avatar
Liked: 813
Yes, "SOME" sound meters have an audio out and can be used in this fashion. Anything to get you up and running but like all endeavors, one is "ALWAYS" better served having the right tools in their tool bag.
(ex: I can use a piece of pipe as a hammer, a bolt and string to find plumb, a saw to cut wire, a river stone to sharpen a blade and a pair of pliers to remove a nut. that sort of thing)
(While I was composing the above, I see you decided to buy a microphone)
This is the current forum standard for a measuring microphone.
post #51 of 51 Old 08-15-2013, 09:15 AM
Quoted: 311 Post(s)
Liked: 273
Just get an Analog Radio Shack SPL meter.
Room Equilizer Wizard Rew
