Subwoofer on a laminate covered cement slab - AVS Forum | Home Theater Discussions And Reviews
Old 04-11-2013, 09:45 AM - Thread Starter
dsskid's Avatar
Quoted: 268 Post(s)
Liked: 257
Is having a front firing, bottom ported subwoofer (energy S10.3) directly on a laminate covered cement slab floor ok?
ISF Calibrator
Samsung PN64F8500
Pioneer Kuro Elite Pro-111FD
Pioneer Kuro BDP-320
Displays are like 100% cotton t-shirts. Always buy a size larger than you think you'll need, as they tend to shrink over time.
dsskid is offline
Old 04-11-2013, 01:09 PM
Bill Fitzmaurice's Avatar
Liked: 4944
It's fine, assuming it has rubber feet. But one of the advantages of down firing, be it a port or the driver, is the acoustic filtering of above bandwidth harmonics, which is greatly improved if there's carpet beneath the sub. For that matter carpet throughout the room will give a much better result than bare laminate.
Bill Fitzmaurice is online now
Old 04-11-2013, 04:36 PM - Thread Starter
dsskid's Avatar
Quoted: 268 Post(s)
Liked: 257
It's a front firing sub, with downward facing ports. Sub has wooden feet, but I will add rubber isolation pads. Carpeting the room is not an option, but there is a large throw rug in the room, and I'll also add a small piece of rug (2x2) under the sub if that will be helpful.
ISF Calibrator
Samsung PN64F8500
dsskid is offline
Old 04-13-2013, 11:18 AM - Thread Starter
dsskid's Avatar
Quoted: 268 Post(s)
Liked: 257
And how right you are Bill. I bought an indoor/outdoor rubber backed Berber type mat, trimmed it to size, and what a difference it makes tightening up the bass. The rubber feet I ordered will arrive Monday, and I'll attach them to the wooden legs as well.
Thanks again for your assistance.
ISF Calibrator
Samsung PN64F8500
dsskid is offline
