Subwoofer placement predicament... - AVS Forum | Home Theater Discussions And Reviews
Old 04-16-2013, 02:34 PM - Thread Starter
coarsehorse's Avatar
I'm trying to figure out speaker placement with this room layout. I'll have 2 bookshelf speakers and a subwoofer. As you can see, the layout is pretty limiting, so I'm wondering if I can put the subwoofer in that wall recess to the right of the fireplace.
If not, any recommendations?
coarsehorse is offline
Old 04-16-2013, 04:19 PM
eljaycanuck's Avatar
Quoted: 1228 Post(s)
Liked: 1802
Do a sub crawl to find the best locations for your sub, and put the sub in the location that also addresses whatever placement or other limitations you have.
eljaycanuck is offline
Old 04-16-2013, 04:44 PM
crn3371's Avatar
Quoted: 240 Post(s)
Liked: 192
If it won't fit in the cubby under the screen, perhaps you could go nearfield and place it next to your sofa. There are plenty of wireless options for subs, so don't let cabling (or lack thereof) deter you.
crn3371 is offline
Old 04-16-2013, 05:37 PM
wvu80's Avatar
Quoted: 320 Post(s)
Liked: 285
You're going to think I'm an idiot, but what about that space to the left of the TV where the flower is? My limited experience is that the sub actually enhances and enlarges the bass sound coming out of the speakers, and you don't always hear the sub itself. Try it, you may like it.
What have you got to lose? (other than your wife having to go trial for murdering you for trying to put that sub up there)
wvu80 is offline
Old 04-17-2013, 03:47 PM
Alan P's Avatar
Quoted: 4697 Post(s)
Liked: 3324
Man, just looking at the picture of that TV hung that high on the wall makes my neck hurt.......
Alan P is offline
Old 04-17-2013, 06:45 PM
Bill Fitzmaurice's Avatar
Liked: 4648
You may, but it might not work well there. Worth a shot.
Bill Fitzmaurice is offline
Old 04-18-2013, 04:38 AM
McStyvie's Avatar
Liked: 78
Exactly what I was thinking!!
Try where the flower is...but the best way is just trial and error, but man you have your work cut out for you though with that setup...
McStyvie is offline
Subwoofer Placement
