Best sub choices in $200 range - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 04-18-2013, 08:19 AM - Thread Starter
Brad Sutliff's Avatar
Right now im using the sub that came with my first theatre system. The Klipsch HD300. its a 6.5in rear firing sub. im looking to upgrade my system slowly. i just bought a new center. and installed two height channels. What would be the best sub in the $200 range? Im most likely looking to buy two. one for underneath each front channel. Thanks!
Onkyo TXSR607, Mythos 8 Center, Studio Monitor 350's, Klipsch S-10 surrounds, Bic F12 sub
Epson Home Cinema 8100 Projector
Brad Sutliff is offline
post #2 of 9 Old 04-18-2013, 08:49 AM
eljaycanuck's Avatar
Quoted: 1344 Post(s)
Liked: 1959
eljaycanuck is offline
post #3 of 9 Old 04-18-2013, 10:23 AM - Thread Starter
would a standard reciever be able to power that?
post #4 of 9 Old 04-18-2013, 10:24 AM
Liked: 1959
The sub is self-powered ("active") - the receiver just sends a signal to it.
See page 5 of the owner's manual (PDF) for connection instructions.
post #5 of 9 Old 04-18-2013, 10:26 AM - Thread Starter
Oh ok cool. thanks. the sub looks great
post #6 of 9 Old 04-18-2013, 11:13 AM
swim33's Avatar
+1 on the JBL. I got the ES150 when it was on sale and I absolutely love it. For 200 you can't go wrong with the JBL.
-Ben
swim33 is offline
post #7 of 9 Old 04-18-2013, 11:38 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1241
Polk PSW 505
http://www.amazon.com/Polk-Audio-12-Inch-Powered-Subwoofer/dp/B000092TT0
arnyk is offline
post #8 of 9 Old 04-18-2013, 01:32 PM
basshead81's Avatar
Quoted: 234 Post(s)
Liked: 6453
I had 2 psw505's and they have alot of output in the 30-50hz range...however they do not have alot of output below 30hz. If that is not a concern for you then they are great reliable subs for the money. Imo get the klipsch rw-12d for 300.00 shipped and get another down the road if you want more. thats probably the best sub under 300.00 that offers fairly deep extension.
basshead81 is offline
post #9 of 9 Old 04-18-2013, 04:44 PM
swim33's Avatar
If you can swing $300 definitely go for the Klipsch. I have heard nothing but great things about it but if not the JBL is a solid choice.
-Ben
swim33 is offline
