Looking for research info on subs - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 04-21-2013, 04:29 PM - Thread Starter
Arogers78's Avatar
Well I just purchased my first set of klipsch speakers (KG 4.2 and KG 1.2v center) and they sound great, but my current sub (Yamaha yst-sw216) is basically useless with my new speakers. So my question is when looking for a good sub what do you look for?
2kg 4.2 / kg 1.2v
Arogers78 is offline
post #2 of 7 Old 04-21-2013, 04:34 PM
eljaycanuck's Avatar
Quoted: 1233 Post(s)
Liked: 1804
To start, it would help if you were to answer some (ideally, most) of the questions in post #1 of this thread:
1. Your budget.
2. Size requirements/limits.
3. Room dimensions.
4. Primary uses.
5. Listening habits.
6. Appearance requirements.
7. Timeframe.
Otherwise, you might get recommendations for a $2,300 Seaton SubMersive HP, when all you've got is an 10' x 12' room and $250 to spend. wink.gif
PioManiac likes this.
eljaycanuck is offline
post #3 of 7 Old 04-21-2013, 04:44 PM
basshead81's Avatar
Quoted: 180 Post(s)
Liked: 5252
1. Your budget.
3. Room dimensions.
4. Primary uses.
7. Timeframe.
lol so true!
Getting Started with REW: A Step by Step Guide -->http://www.roomeqwizard.com/REWhelp.pdf
Mini DSP Tutorial by Neutro --> http://www.avsforum.com/forum/113-su...g-minidsp.html
basshead81 is offline
post #4 of 7 Old 04-21-2013, 05:55 PM
Liked: 1804
Just realized that my reply didn't directly address the OP's question... d'oh! redface.gif ...so here goes again:
I look for a combination of the following:
- a sub with good specs;
- a sub with positive reviews (both professional and non-professional);
- a sub that looks good (because aesthetics do matter);
- a company with a reasonably good (or better) reputation; and
- positive word of mouth from people I deem to be knowledgeable and trustworthy.
(The list is not in any particular order, and may not be exhaustive.)
post #5 of 7 Old 04-23-2013, 01:47 PM - Thread Starter
Arogers78's Avatar
Thank for the feed back guys.
I have been looking at the spec on subs but what numbers should I be looking for on subs? Watts.... Ohms.... Herts...... And what exactly do these specs mean as far as the performance?
2kg 4.2 / kg 1.2v
post #6 of 7 Old 04-23-2013, 01:48 PM - Thread Starter
Arogers78's Avatar
Also what r your favorite brands and why?
2kg 4.2 / kg 1.2v
post #7 of 7 Old 04-23-2013, 02:53 PM
sputter1's Avatar
Liked: 42
The search function is your friend lol
sputter1 is offline
