Challenging room setup 1 and 2 sub placement - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 04-24-2013, 09:25 AM - Thread Starter
JDErickson84088's Avatar
Quoted: 21 Post(s)
Please see diagram of my home theater room. Currently I have 1 sub at location listed. Is this a good spot for this room?
I plan on adding a second sub. Where would be the best place to put it (and the first sub) in a 2 sub setup.
SW-8MK2 (current sub)
specifications
› Frequency Range....................................................38 Hz-150 Hz
› Maximum Input Power.......................................................100 W
› Driver Size.................................................................................8”
› Dimensions (W x H x D) ...........12-3/16” x 14-3/16” x 12-3/16”
› Weight (each)..............................................................20 lbs 4 oz
› Power Consumption............................................................1.0 A
› Power Requirement................................................120 V / 60 Hz
› UPC........................................................................012562906133
Andrew Jones Designed 100-Watt* Powered Subwoofer
*50W FTC Power Output
RW12D (new sub arrives today)
SPECIFICATIONS
AMPLIFIER: BASH digital hybrid
AMPLIFIER POWER: FTC Rated Power: 350 watts continuous @ <2% THD / Dynamic Power*: 825 watts
DRIVE COMPONENTS: 12" (30.5cm) Cerametallic cone, front-firing woofer
ENCLOSURE TYPE: Bass-reflex via front-firing CornerPort
EXPORT VOLTAGE: 220 VAC 50/60Hz
FEATURES: DCS control and feature set w/ 3 system presets
FINISHES: Black Ash woodgrain vinyl
FREQUENCY RESPONSE: 24-120Hz +/-3dB
HEIGHT: 19.2" (48.8cm)
INPUTS: L/R Line-level RCA jacks, L/R High-level speaker binding posts
MAXIMUM ACOUSTIC OUTPUT: 116dB @ 30Hz 1/8 space, 1m
OUTPUTS: None
VOLTAGE: 110/120 VAC 60Hz
WEIGHT: 49lbs (22.2kg)
WIDTH: 14.6" (37.1cm)
Thank you.
JDErickson84088 is offline
