The ultimate subwoofer - AVS Forum | Home Theater Discussions And Reviews
 7Likes
post #1 of 51 Old 04-28-2013, 08:10 PM - Thread Starter
Nicoderm1's Avatar
I want to buy a subwoofer for my home theater. The price isn't a problem. According to you, what's the best subwoofer of all time?
Nicoderm1 is offline
post #2 of 51 Old 04-28-2013, 08:24 PM
pronghorn/az's Avatar
Quoted: 20 Post(s)
Liked: 31
Wow! Talk about opening up a can of worms! I love my Rythmik FV15. It really is a fantastic sub!
Jeff
pronghorn/az is offline
post #3 of 51 Old 04-28-2013, 08:29 PM
deepat04's Avatar
Quoted: 94 Post(s)
Liked: 94
Revel Rhythm2 Subwoofer buy two of these
deepat04 is offline
post #4 of 51 Old 04-28-2013, 08:33 PM
vardo's Avatar
Quoted: 56 Post(s)
Liked: 148
Knock yourself out!.........http://hometheaterreview.com/subwoofer-reviews-information/
+ anything from Power Sound Audio
(of course this is just Home Theater Review's list)
vardo
vardo is online now
post #5 of 51 Old 04-28-2013, 08:47 PM
jbrown15's Avatar
Quoted: 2523 Post(s)
Liked: 1995
I good argument could be made for dual JTR Orbit Shifters or dual Captivator S2's. They'd set you back 6grand for either setup. There's also rumors of a F4 sub from Seaton and the SubMersive XL.
As for as ID companies go and HT setups JTR and Seaton are pretty much at the top of the food chain!
jbrown15 is offline
post #6 of 51 Old 04-28-2013, 09:10 PM
stormwind13's Avatar
Quoted: 62 Post(s)
Liked: 96
I think there's more then just those two (although they both make outstanding products)
Funk audio comes to mind.
stormwind13 is offline
post #7 of 51 Old 04-28-2013, 09:12 PM
shadyJ's Avatar
Quoted: 1330 Post(s)
Liked: 1351
I think the Funk Audio 18.2 power level two might equal or surpass any of the above. But there are a lot of different ways subs can be the highest performing. For instance, the Thigpen Rotary woofer claims to do 110 dB from 5 hz to 25 hz, no other sub on earth is going to do that, but than you have huge horn loaded subs which can punch well over 135 dB at 40 hz and above. It depends on what you mean by 'best'. I think the Funk 18.2 might be one of the highest performing subs you can buy while being somewhat physically manageable, as in you don't need a forklift or a whole extra room for it.
shadyJ is offline
post #8 of 51 Old 04-28-2013, 09:15 PM
basshead81's Avatar
Quoted: 238 Post(s)
Liked: 6518
oh ya I agree with shadyj the funk audio 18.2 is a ****ing beast in the lower range!! that combined with a horn loaded sub for midbass might crack foundations!
basshead81 is offline
post #9 of 51 Old 04-28-2013, 11:48 PM
jbrown15's Avatar
Liked: 1995
You're absolutely right, Funk is also another ID company that would be at the head table for the top food chain guys.
Although I'm not to sure how much more output a 18.2 would have over a Cap S2 from JTR with both designs being dual sealed 18" drivers.
Funk defiantly has the power advantage though and is a gorgeous sub to look at also.
jbrown15 is offline
post #10 of 51 Old 04-28-2013, 11:50 PM
jbrown15's Avatar
Liked: 1995
basshead, the 18.2 isn't a horn designed sub its a dual opposed design like a Seaton SubMersive HP.
jbrown15 is offline
post #11 of 51 Old 04-29-2013, 02:49 AM
BZ1974's Avatar
What's the best? Depends. What are your wants, needs and desires? What is room size? Any size restrictions for the future sub?
$250 may not be a problem whereas $2,500 would be or you may have a no holds barred budget of $25,000.
Too many unknowns at this point to make an informed specific recommendation. However, various companies can be recommended. I would look at HSU, Rythmik Audio, Power Sounds Audio, SVS, Chase Home Theater and Seaton just to name a few.
BZ1974 is offline
post #12 of 51 Old 04-29-2013, 04:38 AM
eljaycanuck's Avatar
Quoted: 1346 Post(s)
Liked: 1962
The best subwoofer is the one that offers the best combination of output, extension, accuracy, price, aesthetics and ergonomics...and fits your budget. smile.gif
Cndctrdj likes this.
eljaycanuck is offline
post #13 of 51 Old 04-29-2013, 04:51 AM
BeeMan458's Avatar
Liked: 813
...+1
Well.............all except "ergonomics."
BeeMan458 is offline
post #14 of 51 Old 04-29-2013, 05:04 AM
Liked: 1962
+1 ... Well.............all except "ergonomics."
An example of what I mean by "ergonomics": My passive subs have a separate amp that is easily accessible because it's not stuck behind the sub. Making changes to settings is very straightforward. With my previous active subs, I'd either have to move the sub out of and back into position or undergo contortions in order to modify settings.
I much prefer the ergonomics of my passive subs to those of my previous powered subs. cool.gif
Similarly, I suspect that Klipsch RW-12d owners prefer having the control panel on top of the sub rather than behind it. smile.gif
post #15 of 51 Old 04-29-2013, 05:09 AM
Bill Fitzmaurice's Avatar
Liked: 5684
If you want the best result you won't get it from one sub. At the least you need two, and four are better. Read this:
http://www.harman.com/EN-US/OurCompany/Innovation/Documents/White%20Papers/multsubs.pdf
Steve Crowley likes this.
Bill Fitzmaurice is offline
post #16 of 51 Old 04-29-2013, 05:39 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1242
+1
arnyk is offline
post #17 of 51 Old 04-29-2013, 05:44 AM
basshead81's Avatar
Quoted: 238 Post(s)
Liked: 6518
reread the post i didnt say it was.
post #18 of 51 Old 04-29-2013, 05:54 AM
BeeMan458's Avatar
Liked: 813
Never had to consider ergonomics. Thanks for the insight.
post #19 of 51 Old 04-29-2013, 06:11 AM
Liked: 1962
post #20 of 51 Old 04-30-2013, 08:18 PM
manwithnocape's Avatar
Funk 18.2 power level 2. I heard it and its insane... so buy 2 just to be safe.
manwithnocape is offline
post #21 of 51 Old 05-01-2013, 06:25 AM
Quoted: 62 Post(s)
Liked: 96
Imo, if you are handy with woodworking- diy is where it's at as far as performance goes. Build yourself 4 gjallarhorns and watch your house implode. Or pay someone to build 4 gjallarhorns for you.
post #22 of 51 Old 05-01-2013, 09:44 AM
bsoko2's Avatar
Quoted: 79 Post(s)
Liked: 80
Just had to ask "The ultimate subwoofer" didn't you?
bsoko2 is online now
post #23 of 51 Old 05-01-2013, 01:37 PM
KlipschHead281's Avatar
Quoted: 35 Post(s)
Liked: 41
The MFW-15
AVR/Blu-Ray - Marantz SR7009 (9.3.2) - Blu-Ray Oppo UDP 203 - Apple TV
Front Height Amplifier - 2 Marantz MA6100's
Speakers - Klipsch RF-82 - Center RC-64 - Front Wide 2 RP-160M, Front Height 2 RB-10
Rear Surround - Surround Back 2 RS-52, Surround 2 R-14M
Subs - Triple MFW15's (Seaton Sound ICE amplifiers, 1 still has an AV123 amp, sadly)
TV -Samsung 55" 8500
KlipschHead281 is offline
post #24 of 51 Old 05-06-2013, 01:01 PM
padgman1's Avatar
If the parameters for "ultimate sub" were changed to primary music usage as opposed to HT usage ( the original OP's ), would the candidates change at all?
Which sub qualities would be more ( ?better) emphasized for music ?
padgman1 is offline
post #25 of 51 Old 05-06-2013, 01:09 PM
Liked: 5684
The only difference between the needs of music and HT is how low they go. Music is pretty much good with 35Hz, HT with as low as 15Hz, depending on how fanatical your are about it. Some say that subs that do work well for HT for some reason won't work as well for music as subs that don't go that low, but that's not the case. If a sub has accurate response it will sound good, no matter how low it goes. If it doesn't, it won't.
As for what the ultimate sub is, you'll get about as many opinions as you will answers. No offense OP, but it's a silly question. You might as well ask what is the best car, boat, whisky, beer, pizza, whatever.
Steve Crowley and gkf15 like this.
post #26 of 51 Old 05-06-2013, 01:45 PM
craig john's Avatar
Quoted: 536 Post(s)
Liked: 763
While I agree in principle, my ears and experience tell me something different. I "prefer" the sound of sealed subs for music. They sound more accurate and articulate to my ears. For HT use, sealed subs can work synergistically with the Pressure Vessel Gain, (aka "Room Gain), associated with low frequencies in smaller rooms. If one adds enough sealed subs that are tuned low enough, they can provide the same, (or better), ULF response than ported subs. It's a more expensive way to go, but ultimately provides the best of both worlds; SQ for music, and deep extension for HT. At least that's my experience, and I have designed my subwoofer system around that concept, (3 randomly placed Seaton Submersive, dual-opposed, sealed subs.) My system is flat to 15 Hz, (and probably below that, but that is the limit of my measurement gear.)
Craig
Lombardi said it:
"Perfection is not attainable, but if we chase perfection we can catch excellence."
My System
craig john is offline
post #27 of 51 Old 05-06-2013, 02:12 PM
padgman1's Avatar
What qualities , besides flat FR and distortion, make up accuracy for a subwoofer?
Are these qualities that make a subwoofer accurate different from those that make a speaker ( bookshelf/ floorstanding) accurate?
padgman1 is offline
post #28 of 51 Old 05-06-2013, 03:03 PM
vardo's Avatar
Quoted: 56 Post(s)
Liked: 148
8 days, Nicoderm1, with one post, asks what the "ultimate sub is" and he disappears. Actually makes for an
interesting thread though, with a lot of good preferences.
vardo
Surfdrifter likes this.
vardo is online now
post #29 of 51 Old 05-06-2013, 03:08 PM
Liked: 5684
Double blind testing has been done with vented versus sealed subs, and listeners could not tell the difference between the two when they had the same response. You may prefer a certain response curve, but how that response is arrived at doesn't matter. My preference is for horns, not for the response curve, but for the effortless unfettered output and total lack of distortion.
That pretty much covers it, since many of the finer points that can be heard in the midbass and higher frequencies can't be heard in the sub bass frequencies. Distortion is very much a critical aspect with subs, as it takes a very good sub not to run out of driver excursion capability at higher levels, and when it does THD will skyrocket and response will no longer be flat.
post #30 of 51 Old 05-06-2013, 03:48 PM
Mark Seaton's Avatar
Quoted: 682 Post(s)
Liked: 1841
I've never seen anything concrete in such a blind comparison, but I have seen a few approximated attempts. The part of having "the same response" is where things get tricky, particularly where the subs roll off. It's easy to make a sealed sub match the response of a ported box (and end up sounding very similar). The other way isn't as simple, and dynamic behavior of the subs differs as you start getting utilizing more of the output capability, but still well before the maximums are reached.
Mark Seaton
Seaton Sound, Inc.
"Make no little plans; they have no magic to stir men's blood..." Daniel H. Burnham
Mark Seaton is online now
Subwoofers , Fv15hp Subwoofer
