Klipsch RW12D Blown? Just purchased. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 22 Old 04-29-2013, 06:25 PM - Thread Starter
cessna1466u's Avatar
Quoted: 116 Post(s)
Liked: 201
Hello Everyone, if you have read my previous posts you know that I just picked up a used Klipsch RW12D yesterday. It sounded great at the persons house and sounds good at my house but when I am at very close range to the subwoofer or have just the subwoofer on alone I hear what I can only describe as what it would sound like if there was a wire or piece of trash touching the cone. I don't know if this makes sense. There is plenty of bass coming out of the sub. I played The Polar Express and at the begining with the train scene the entire house shakes but when I get within 12-18 inches from the sub I can hear a little rattle. The rattle sounds like as if something was touching the cone. I openend it up and there is nothing touching it. I push the cone in and out by hand and don't feel any rubbing. It is only when the bass hits. Any thoguhts? Is the voice coil going back, could it be a setting on my receiver or sub its self? I have it set to 80hz. I tried a different wire.
cessna1466u is offline
post #2 of 22 Old 04-29-2013, 07:10 PM
crn3371's Avatar
Quoted: 239 Post(s)
Liked: 192
Are you sure the port tube is secure? I also recall reading a post in the RW-12D thread where the poster was complaining about the Klipsch logo badge rattling.
crn3371 is offline
post #3 of 22 Old 04-29-2013, 07:25 PM
basshead81's Avatar
Quoted: 179 Post(s)
Liked: 5205
sounds like a bad capacitor on the amp...had a polk sub do the same thing. almost sounded like the dust cap was vibrating against the cone, turned out to be a bad power capacitor. Replaced both 35volt units with 50volt and bam like brand new again.
I have read a few having amp problems with those subs, so if its not the port being lose then its probably what i mentioned aove.
Getting Started with REW: A Step by Step Guide -->http://www.roomeqwizard.com/REWhelp.pdf
Mini DSP Tutorial by Neutro --> http://www.avsforum.com/forum/113-su...g-minidsp.html
basshead81 is offline
post #4 of 22 Old 04-29-2013, 10:33 PM - Thread Starter
Quoted: 116 Post(s)
Liked: 201
Thanks for the help folks, I am extremely disapointed. This sub has some serious potential. I don't know about caps, I know what they look like but I would have no way of telling if its bad or not. I still want this sub. I think I am going to try and take it to a local shop and see if they can do something about it. I know the air port is not loose, neither is the emblem. I am just mad that the guy that sold it to me didn't have the decency to at least mention it.
post #5 of 22 Old 04-29-2013, 10:53 PM
Colm's Avatar
Liked: 94
Maybe he never sat that close and didn't know. One should always check out a used item thoroughly before buying and pass if one isn't ready to deal with any possible defects.
Colm is offline
post #6 of 22 Old 04-29-2013, 11:11 PM
Joshjp's Avatar
Quoted: 13 Post(s)
Liked: 115
This sounds like the port baffle is loose, stick you hand in the port, wiggle it around, if it moves then its loose, if not then its somehing else, when you slide your hand in you can feel were it connects.
HT~
PANASONIC TC-P50ST60, OPPO BDP-103D, ONKYO TX-NR818, PANAMAX MR4000, KLIPSCH RF-62's, RC-62, RS-52's, PSA TRIAX
2.1CH~
ADAM AUDIO F5's, EMOTIVA STEALTH DC-1, SVS SB-2000
Joshjp is offline
post #7 of 22 Old 04-29-2013, 11:12 PM
lovinthehd's Avatar
Quoted: 4588 Post(s)
Liked: 4775
Caveat emptor. Are you sure it isn't the trim feature on the front of the sub (below the cone above the port)? Some have reported some buzzing from that IIRC. Search both of the bigger RW12d sub threads, it was discussed in one of them if not both.
lovinthehd is offline
post #8 of 22 Old 04-29-2013, 11:30 PM - Thread Starter
Quoted: 116 Post(s)
Liked: 201
Thanks guys, I double checked all the screws and the port it is not loose. I wish it was that easy. Even at very low volume where you the subwoofer is not even moving back and forth you can hear a bit of a scrape like noise. I definitely think either the sub is bad or the amplifier. I wish I know how to check the sub and amplifier separate.
post #9 of 22 Old 04-30-2013, 03:32 PM - Thread Starter
Quoted: 116 Post(s)
Liked: 201
FIXED!!! I don't know what I did but I took it apart, checked the amplifier for loose screws. I noticed there where a few loose screws on the amplifier. Some of the screws where to brackets that held down electrical components. They where loose. I also tightened everything inside, including zip-tying the wires together to make sure they where not rattling. I also crimped down the connector to the subwoofer to make sure they where not coming loose and making a bad connection. Turned it up this morning and the noise is gone. This thing is a beast. I love it.
One thing I did notice is that when I opened it up, the inside is bare wood. Even my cheapo Yamaha subwoofer had insulating material inside. So since I don't ever leave well enough alone, I am wondering if adding some insulation would improve sound? Any thoughts on this? Maybe spray on insulation like the Dynamat stuff?
post #10 of 22 Old 04-30-2013, 03:44 PM
BeeMan458's Avatar
Liked: 813
Absolutely, yes there will be a measurable difference. Adding insulation decreased the output a few Hz and improved interior noise. I used this poly-fiber A bit pricey and my understanding, less expensive product will get you to the same place. I filled two Klipsch, subwoofer boxes (SW-12 II) that already had two one inch foam sheets installed; one for the top and one for the bottom half. I placed the fill between the foam pads and the wood sides of the box's interior.
You mentioned you don't have any foam inside the box. Make sure you're not plugging up the port as I don't see that as a good thing. Maybe somebody can comment on that as I don't have proper insight regarding what happens when one stuffs the subwoofer port with Poly-fil.
I used maybe a pound of fill for each box that are a bit larger than the RW-12d. The overall response was lowered from a measured (using REW) 25Hz down to a measured, 22Hz. The addition of a third RW-12d, brought us down to a solid 19Hz.
Now you have me curious and I'll need to open the newest subwoofer and see what's what with it's inside and see if I need to stuff this turkey as we have plenty of poly-fill to use. tongue.gif
BeeMan458 is offline
post #11 of 22 Old 04-30-2013, 03:53 PM - Thread Starter
Quoted: 116 Post(s)
Liked: 201
We have that exact one at our local Wal-Mart for $24.97 for a 10lb carton. I have not seen it in person but is is just like the fill inside stuffed animals? If so did you just literraly "stuff it"? Just remover the speaker and fill the inside with about 1lb of this stuff? Is there no concern with the stuffing touching the amplifier circuits? Does the amp not get hot. My amp is not protected at all on the inside. I am also considering getting one of those Auralex Subdude for the bottom. My floor is a raised wood subfloor with carpet and our homes where not made very well. I can actually move the drywall and feel it being off the studs by about 1/8". All my walls rattle with this subwoofer going.
post #12 of 22 Old 04-30-2013, 04:12 PM
ack_bk's Avatar
Quoted: 548 Post(s)
Liked: 631
You need to be careful adding polyfill to a ported sub. You can certainly add some and then adjust to your liking. I would maybe start with 1lb and go from there. 10lbs would be way too much.
ack_bk is offline
post #13 of 22 Old 04-30-2013, 04:15 PM
basshead81's Avatar
Quoted: 179 Post(s)
Liked: 5205
you do not want the poly fill touching the amplifier components.
post #14 of 22 Old 04-30-2013, 04:25 PM - Thread Starter
Quoted: 116 Post(s)
Liked: 201
How would I keep the poly-fill from touching the amplifier? Do I just add it to the bottom and maybe staple some to the top and sides? Would I better off with something that sticks like Dynamat? I realize that the Dynamat helps more with the walls of the sub box not rattling and the poly-fill does something different. So is the increase in sound quality with polyfill work the risk of doing it wrong?
post #15 of 22 Old 04-30-2013, 04:35 PM
ack_bk's Avatar
Quoted: 548 Post(s)
Liked: 631
Perhaps someone like Bill Fitzmaurice or Mark Seaton will chime in, but in laymen's terms when you add polyfill to a box you are effectively slowing the soundwaves as they move through the box which effectively results in a smaller enclosure thinking it is larger.
With a ported or vented enclosure, it is designed speficially in regards to:
- The driver characteristics
- The size of the enclosure
- The tune desired (18hz tune, 20hz tune, 30hz tune, etc).
This tune and enclosure size determine the vent/port diameter and length. If you start adding polyfill or other insulation you could negatively affect your tune. I would hesitate in doing this unless you can measure response.
What I have seen DIYers with ported enclosures do is line the interior walls with egg crate material (mattress topper) that is about 1-2" thick. Spray on adhesive on the interior side walls then attach. Or something like this:
http://www.parts-express.com/pe/showdetl.cfm?Partnumber=260-520
ack_bk is offline
post #16 of 22 Old 04-30-2013, 04:38 PM - Thread Starter
Quoted: 116 Post(s)
Liked: 201
post #17 of 22 Old 04-30-2013, 04:41 PM
BeeMan458's Avatar
Liked: 813
Being a cretin, I just smeared the poly-fil all over everything; amplifier and wires. I made a tube out of the one inch foam sheets and the space between the created tube and the walls was unceremoniously stuffed. I can't fine the images I used as a guide but I did have pictures. tongue.gif
We have ported subs that use radiators, hence why I created an interior tube configuration. From what I recall, if one has a sealed sub, just fill the box up and be happy. Of course, leave room for the subwoofer driver.
Using pink batting works a treat also but one then has issues regarding fiberglass dust.
post #18 of 22 Old 04-30-2013, 04:44 PM
ack_bk's Avatar
Quoted: 548 Post(s)
Liked: 631
Thanks ACK, what effect does anything this eggcrate stuff do? Does it do the same as the polyfill?
I have never done it myself (only built sealed subs), but my understanding is that lining the sub results in "dampening" of the sound reflections. The DIY subforum would be a good place to search and ask.
ack_bk is offline
post #19 of 22 Old 04-30-2013, 05:12 PM
Oliver Deplace's Avatar
Liked: 33
If you haven't the facility to measure the output for a baseline and your subsequent changes, you're going to run around in circles and prolly end up with a bunch of stripped screw-holes.
You've stopped the rattling, and I'm sure that's a genuine improvement, so why not leave it be and just enjoy the sub? You're ahead at this point, it'd be a pity to ruin that.
Oliver Deplace is offline
post #20 of 22 Old 04-30-2013, 05:41 PM - Thread Starter
Quoted: 116 Post(s)
Liked: 201
Oliver, I like the way you think. You are right those screws are tough. I am always scared my hand is going to slip and I am going to puncture the surround of the subwoofer. I will be opening it one more time to secure the port tube. At the very end of the tube it looks like there are screw holes on each end, almost as if the tube was supposed to be secured to the back of the box but it is missing a 1" x 1" piece of wood to to attach the tube too. I am attempting to post a pic of it here. Lets see if it works.
post #21 of 22 Old 04-30-2013, 06:40 PM
vardo's Avatar
Quoted: 41 Post(s)
Liked: 130
Or you could use this......http://www.parts-express.com/pe/showdetl.cfm?partnumber=260-515
Cut separate pieces with scissors and adhere with 3M adhesive spray.
vardo
vardo is online now
post #22 of 22 Old 05-01-2013, 12:54 AM - Thread Starter
Quoted: 116 Post(s)
Liked: 201
Thanks all, I opened it up. Made sure all was tight. I used some 1" pieces of scrap wood to secure the port to the back of the enclosure and secured all the wiring inside. The other thing I did was very carefully I used some metal duct duct that forms bends easily to wrap around the outside of the port where the tube meets the flange and then also on the inside. I feel this helped with the port chuffing that everyone complains about. What I am getting now is some really nice clean bass, no weird vibrations or air noise. I love it!
Klipsch Rw 12d 12 Subwoofer Each
