Sub Recommendation - AVS Forum | Home Theater Discussions And Reviews
Old 04-29-2013, 06:44 PM - Thread Starter
mr1derful's Avatar
I am putting together my HT system. So far I have firmly decided on the Denon AVR-2313 CI, and the PSB Image T6/C5 for the LCR. Need help on matching up a sub woofer around the $500 range. The set up is going in the great room. About 70% movies and 30% music. I will be installing ceiling speakers for the rear. Thanks for your feedback.
mr1derful is offline
Old 04-29-2013, 07:06 PM
basshead81's Avatar
Quoted: 181 Post(s)
Liked: 5303
spend 100.00 more and get 2 klipsch rw-12's. right now they are 299.00 shipped each. great sub for the money and two of those would be better than one 500.00 sub imo.
Getting Started with REW: A Step by Step Guide -->http://www.roomeqwizard.com/REWhelp.pdf
Mini DSP Tutorial by Neutro --> http://www.avsforum.com/forum/113-su...g-minidsp.html
basshead81 is offline
Old 04-29-2013, 10:30 PM - Thread Starter
mr1derful's Avatar
I just checked Newegg, and the price is $349. Where is the $299 price?
Old 04-29-2013, 10:38 PM
crn3371's Avatar
Quoted: 240 Post(s)
Liked: 192
Subscribe to NewEggs eBlast newsletter as that's where you'll find the discount codes. I just got the RW-12D for $279. I believe the $70 off coupon expired on the 24th. Be patient as NewEgg is constantly discounting this sub.
crn3371 is offline
Old 04-29-2013, 10:44 PM - Thread Starter
mr1derful's Avatar
In your opinion, is going with 2 Klipsch better than going with 1 better sub ($500 range) based on my room?
Old 04-30-2013, 12:27 AM
deepat04's Avatar
Quoted: 94 Post(s)
Liked: 94
Outlaw LFM EX should also be a consideration, if budget is tight at $500 yes two rw 12s is the way to go
deepat04 is offline
