Getting an old subwoofer to work with Yamaha RX-A820 Receiver - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 05-02-2013, 07:27 PM - Thread Starter
silentseba's Avatar
Hello, I recently purchased a RX-A820 Receiver and so far I have gotten the Front two speakers and center channel to work with my old speakers. When I try pluggin in my Subwoofer ( http://www2.yamaha.co.jp/manual/pdf/av/english/sub/YST-SW200_e.pdf ) and do the YPAO test, it sounds really clippy and plays at low volume, giving out a W-3 error. The sub has L/R input, and the receiver has two 1 output connections. I tried doing everything I could think of with these connections and nothing would make it sound good.
L or R to 1 or 2 from both sides
Y splitted from 1 or 2 to L/R
L to 1 R to 2
I figured I would ask here before I fry my sistem >.<<br />
Edit: Please asume I don't know anything about audio equipment. I am trying to learn instead of going off and buying a HTiaB. I am even making my own cables so they match my floor smile.gif
Edit 2: Forgot to add link to my SW
silentseba is offline
post #2 of 5 Old 05-02-2013, 07:34 PM
basshead81's Avatar
Quoted: 239 Post(s)
Liked: 6577
set the sub gain around 12:00 and re run ypao. for input just go from one of the sub outs to either the left channel, or use a y and connect both. also make sure the sub crossover is max.
basshead81 is offline
post #3 of 5 Old 05-03-2013, 04:24 AM - Thread Starter
silentseba's Avatar
I tried doing that. I am about to give up on the subwoofer, I believe it might be damaged. Now to look for subwoofer + 2 rear surrounds for under $500 tongue.gif
post #4 of 5 Old 05-03-2013, 05:53 AM
basshead81's Avatar
Quoted: 239 Post(s)
Liked: 6577
yea sounds like something is wrong with it. HSU has bookshelf/sub packages.
http://www.hsuresearch.com/products/value2pkg.html
http://www.hsuresearch.com/products/value1pkg.html
i would personally go with the 599.00 package even tho its slightly over budget.
post #5 of 5 Old 05-03-2013, 02:20 PM
basshead81's Avatar
Quoted: 239 Post(s)
Liked: 6577
