looking for jl f110 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 05-04-2013, 11:41 PM - Thread Starter
ainchene's Avatar
I remember JL from my high school days and want to buy the F110 for my home theater. The only dealers in my area are car audio and can not get the home audio. Need help please
ainchene is offline
post #2 of 10 Old 05-05-2013, 12:15 AM
jbrown15's Avatar
Quoted: 2523 Post(s)
Liked: 1993
Are you looking at a JL because you need a compact sub? Or just want a JL?
jbrown15 is offline
post #3 of 10 Old 05-05-2013, 08:21 AM - Thread Starter
ainchene's Avatar
I just want one
ainchene is offline
post #4 of 10 Old 05-05-2013, 08:34 AM
jeremymak's Avatar
any compact sub recommend??
jeremymak is offline
post #5 of 10 Old 05-05-2013, 10:20 AM
jbrown15's Avatar
Liked: 1993
So if that's the only sub you're interested in what do you need help with?
jbrown15 is offline
post #6 of 10 Old 05-05-2013, 02:13 PM
eljaycanuck's Avatar
Quoted: 1228 Post(s)
Liked: 1802
... want to buy the F110 for my home theater. The only dealers in my area are car audio and can not get the home audio. Need help please
What kind of help are you looking for? If it's information on JL dealers in your area, you might want to let people know roughly where you live.
eljaycanuck is offline
post #7 of 10 Old 05-05-2013, 07:39 PM
deepat04's Avatar
Quoted: 94 Post(s)
Liked: 94
The SVS SB13 Ultra is a compact subwoofer, it will dig deeper then the F110 while playing louder across all FQ. Also it will not roll off at 80hz, the F110 is a very good subwoofer but at $2100 can't compete with offerings from the likes of SVS.
I would strongly recommend saving $600 and buying the SVS, liking a brand because of your history with it should not decide a purchase.
Svs subwoofer can be ordered directly and ships to your door free.
deepat04 is offline
post #8 of 10 Old 05-05-2013, 07:52 PM
Bill Fitzmaurice's Avatar
Liked: 4640
Originally Posted by ainchene View Post
I just want one
Then buy one.
Bill Fitzmaurice is offline
post #9 of 10 Old 05-05-2013, 11:20 PM
astrallite's Avatar
Quoted: 25 Post(s)
Liked: 26
You can find them on ebay and audiogon if you don't have a nearby distributor.
astrallite is offline
post #10 of 10 Old 05-08-2013, 07:04 PM - Thread Starter
ainchene's Avatar
thanks astrallite found one!
ainchene is offline
