Dual Sub setup question to help fight a null? - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 36 Old 10-11-2013, 01:28 PM
KidHorn's Avatar
Quoted: 1374 Post(s)
Liked: 877
Any time you move subs around you make some things better and some worse. Although there are some placements that are really bad (I've found them on occasion), there's no such thing as a perfect placement. It's a question of what's important to you. One thing I like to do is move around the room and find a spot where the subs sound best. This will give you an idea of how good they can sound with proper placement. You'll probably never be able to get the subs sounding this good at the MLP, so if you can get the MLP to sound as good as that, then you know it's time to stop moving the subs around.
KidHorn is offline
post #32 of 36 Old 10-12-2013, 12:48 AM
Skylinestar's Avatar
Quoted: 1044 Post(s)
Liked: 182
Here's some REW screenshots of the 30Hz null :cry:
Skylinestar is offline
post #33 of 36 Old 10-12-2013, 01:00 AM
Liked: 182
Originally Posted by Bill Fitzmaurice View Post
the problem probably relates to having both of them at the front of the room.
Originally Posted by braveheart123 View Post
Spread your subs in the room and excite room modes from different locations; preferably one each on opposing walls.
In the future, I'll probably try with one on the front right corner and another one on my rear left corner.
post #34 of 36 Old 10-14-2013, 09:02 AM - Thread Starter
landshark1's Avatar
Quoted: 18 Post(s)
Liked: 62
Totally forgotten this thread and didn't notice it's still alive.
Anyway, I'm updating my result and hopefully will help others too.
Here's my latest FR graph at MLP and needless to say I'm very happy with it, finally! biggrin.gif
What I did is I stacked 4" thick of OC703 at the back wall (on top of the 2" OC703 + 2" air gap that's already on it) for more lower frequency bass trap, and added another PB12-Plus at the rear left corner, moved the original sub to the front right corner. And now I have an as smooth of FR at my seat as possible! So yes, multi-sub and spread them out, at least opposite corner/wall, would be the best solution.
landshark1 is offline
post #35 of 36 Old 10-14-2013, 09:19 AM
BeeMan458's Avatar
Liked: 813
Very nice! Congratulations on your efforts.
BeeMan458 is offline
post #36 of 36 Old 10-14-2013, 09:22 AM
braveheart123's Avatar
Quoted: 311 Post(s)
Liked: 273
Rock on !!!!
History is written by those who have hanged heroes ...
Main System: PSB X2T, PSB XC, PSB XB, Cambridge Audio Azur 751R, Rythmik FV15HP, PSB S500
braveheart123 is offline
