Sub choices for around 1500? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 05-08-2013, 10:05 PM - Thread Starter
RON82ND's Avatar
So thanks to some on here it looks like the final 3 choices are as follows to bring low end into my 24x17 theater room.
Svs ultra 13
Rythmik f15hp
Or 2 psa xv15s
I would think 2 would be better than 1 but what is everyone's opinion on these and what would you all go with focusing primarily on HT. And I am running DT 8060 towers with 300 watt subs built into those if that matters at all.
RON82ND is offline
post #2 of 4 Old 05-08-2013, 10:08 PM
lespurgeon's Avatar
Quoted: 31 Post(s)
Liked: 52
Starting place is 2 subs centered on opposite walls and start adjusting from there.
lespurgeon is offline
post #3 of 4 Old 05-08-2013, 10:24 PM
basshead81's Avatar
Quoted: 179 Post(s)
Liked: 5213
One Rythmik FV15HP or 2 PSA XV15's imo. The Rythmik is a better sub, but 2 XV15's well get ya similar low end extension down to around 16-18hz depending on room gain and more midbass(40-63hz)...not to mention dual subs will help smooth the bass output.
data-bass.com/systems
add rougly 6db to the xv15's numbers if the 2 subs are co-located.
Getting Started with REW: A Step by Step Guide -->http://www.roomeqwizard.com/REWhelp.pdf
Mini DSP Tutorial by Neutro --> http://www.avsforum.com/forum/113-su...g-minidsp.html
basshead81 is offline
post #4 of 4 Old 05-09-2013, 08:52 AM
KidHorn's Avatar
Quoted: 1374 Post(s)
Liked: 877
2 XV15s. In a large room, you need multiple subs.
KidHorn is offline
