Need help deciding on which Sub or Subs to purchase! - AVS Forum | Home Theater Discussions And Reviews
Old 05-11-2013, 11:02 AM - Thread Starter
keith31867's Avatar
Hi everyone,kinda new to this site and thread trying to get some input on which sub or subs to purchase for my HT,the room I will be using is 12x26 with 8 foot ceilings,its a living slash dining room that opens up to the kitchen. The front mains are Polk 75Ts the center is a Polk monitor 25c and my surrounds are Polk monitor 65Ts,any input would be Appreciated!!!
keith31867 is offline
Old 05-11-2013, 11:24 AM
basshead81's Avatar
Quoted: 179 Post(s)
Liked: 5205
budget?
what will the sub(s) primary duty be? music or movies...both?
have you considered duals for that size room?
keith31867 likes this.
Getting Started with REW: A Step by Step Guide -->http://www.roomeqwizard.com/REWhelp.pdf
Mini DSP Tutorial by Neutro --> http://www.avsforum.com/forum/113-su...g-minidsp.html
basshead81 is offline
Old 05-12-2013, 10:07 AM - Thread Starter
keith31867's Avatar
I would say my budget is around $500.00 for the sub or subs,Im powering my system with an Onkyo tx-nr809 and is a power conditioner really nessesary?
Old 05-12-2013, 10:09 AM - Thread Starter
keith31867's Avatar
Oh and my system will be 80-20% Movie/Music!
Old 05-12-2013, 10:36 AM
basshead81's Avatar
Quoted: 179 Post(s)
Liked: 5205
if you can swing 600.00 I would go with dual Klipsch RW-12D's from new egg. They are probably the best bang for buck sub. I do not think there is any single sub around 500.00 that will pressurize that room. The Rythmik LV12R might get you close, it runs 589.00 shipped.
