Dayton 12 subwoofer wiring ? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 05-14-2013, 05:16 AM - Thread Starter
infofrog's Avatar
I just got my Dayton 12 power subwoofer .
My ? is my receiver has one rca sub output . This subwoofer has two line level inputs L & R . The direction says for mono Connect to R input .
Also it has a note - If a LFE mono output is connected , set the crossover point to max.
Not sure what to do here .
here is the receiver I have Sony STRDG 500
http://www.docs.sony.com/release/specs/STRDG500_mksp.pdf
Thank you
infofrog is offline
post #2 of 7 Old 05-14-2013, 05:42 AM
Bill Fitzmaurice's Avatar
Liked: 5682
Do what the directions say.
Bill Fitzmaurice is offline
post #3 of 7 Old 05-14-2013, 05:55 AM
caloyzki's Avatar
Quoted: 168 Post(s)
Liked: 46
i have dayton 1200 too. you can put the rca in either one of them. it doesnt matter. yes set xover to max if you ran audysey.
caloyzki is offline
post #4 of 7 Old 05-14-2013, 05:55 AM
Splicer010's Avatar
Liked: 40
Max the frequency. Your amp should take care of everything else. Just connect a 'Y' cable OR use the 'R' input. Either way, it will be correct. wink.gif
Splicer010 is offline
post #5 of 7 Old 05-14-2013, 05:57 AM
Splicer010's Avatar
Liked: 40
I see you have the rw12 AND the 1200. Could you please go to this thread and give your impressions of the comparison?
http://www.avsforum.com/forum/newestpost/1471965
post #6 of 7 Old 05-14-2013, 05:59 AM
Splicer010's Avatar
Liked: 40
BTW...His Sony amp does not have Audyssey. Either way, the xover should be maxed out. wink.gif
post #7 of 7 Old 05-14-2013, 07:23 AM - Thread Starter
infofrog's Avatar
Thank you
infofrog is offline
