Good quality in room passive sub options? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 05-18-2013, 08:46 PM - Thread Starter
Nyal Mellor's Avatar
Quoted: 435 Post(s)
Liked: 312
Anyone know any good in room passive subs? Only need to go down to 40 or so before rolling off so can be small. I have the Procella option but they are pricey...
Want to learn about home theater design and acoustics? Read our blog.
Company: Acoustic Frontiers - design and creation of high performance home theaters for discerning audio/video enthusiasts.
Certifications: HAA Level I & II, THX Video Level I & II, CEDIA EST I & II.
AVS Projects: Too many to show in my signature - see here for the master list.
Nyal Mellor is offline
post #2 of 6 Old 05-20-2013, 08:19 AM
rdclark's Avatar
Quoted: 285 Post(s)
Liked: 544
Not a big market, since much of the point of a dedicated sub is so that the system's amplifiers don't have to handle the prodigious power required for low bass. Even those Procella subs come in versions without amps only because they expect you to dedicate an amp in your rack to them.
Why would a powered sub not work for you?
Wide Awake
on the Edge
of the World
rdclark is offline
post #3 of 6 Old 05-20-2013, 09:14 AM - Thread Starter
Quoted: 435 Post(s)
Liked: 312
Wiring logistics. It's a retrofit job and there is no power where I want to put the subs, but running low voltage (speaker wire) will be easy.
post #4 of 6 Old 05-20-2013, 09:49 AM
rdclark's Avatar
Quoted: 285 Post(s)
Liked: 544
Hmm. Velodyne "SubContractor" series, maybe?
There are a lot of passive subs in the pro-audio industry, of course, and also for car audio. Probably not what you want if it'll be exposed, however.
Wide Awake
on the Edge
of the World
rdclark is offline
post #5 of 6 Old 05-22-2013, 10:45 AM
desertdome's Avatar
Quoted: 1122 Post(s)
Liked: 1226
You could try a Blackbird or Raptor system from Dave at bossobass.com. He goes by bossobass here on the forum. Jeff (JTR Speakers) or Mark (Seaton Sound) could probably provide you with a passive sub. They use amps from Speaker Power and maybe they could use a rack mount DSP amp from Speaker Power instead of the plate amp. If you only want down to 40 Hz, the JTR Growler is ideal and it is passive. Although it isn't shown on the website, I think you can get them custom with veneers for a more upscale look. Danley Sound Labs has some passive subs, but they are probably larger than what you are looking for.
High Impact AV
desertdome is offline
post #6 of 6 Old 05-23-2013, 03:47 PM
Mark Seaton's Avatar
Quoted: 496 Post(s)
Liked: 1300
If the amp just needs to be remote, there are a variety of options from Velodyne and Triad. If you need something more ambitious, drop me a line as desertdome suggested.
Mark Seaton
Seaton Sound, Inc.
"Make no little plans; they have no magic to stir men's blood..." Daniel H. Burnham
Mark Seaton is online now
