Bass that can be felt? - Page 3 - AVS Forum | Home Theater Discussions And Reviews
post #61 of 71 Old 05-22-2013, 12:46 PM
LastButNotLeast's Avatar
Quoted: 1792 Post(s)
Liked: 1403
Originally Posted by BeeMan458 View Post
Why do you ask?
Hoping you're able to find a solution.
Besides another sub.
Did you really need to quote that entire post in your reply?
Downloadable FREE demo discs: Demonstration Blu-Ray Discs (Independently Authored)
Welcome to AVS - Get out while you still can!
Don't guess, measure: Getting Started With REW: A Step-by-Step Guide
LastButNotLeast is offline
post #62 of 71 Old 05-22-2013, 12:48 PM
BeeMan458's Avatar
Liked: 813
Originally Posted by asere View Post
My wife says its boomy when bass is deep because of the high spl. I tell her it is not boomy and with deep bass you get pressure from high spl and room modes. Boomy is like a car with a bad sub that rattles the trunk.
Using only one sub and genetically, considering a woman's hearing is better than a guy's hearing, she could be on to something and without measurements, one never knows as boomy, in a Home Theater sound reproduction system is a sign that a section of one's graph is being overly emphasized or boomy.
BeeMan458 is offline
post #63 of 71 Old 05-22-2013, 12:50 PM
asere's Avatar
Quoted: 1568 Post(s)
Liked: 319
With music for sure it is tight
asere is offline
post #64 of 71 Old 05-22-2013, 12:51 PM
BeeMan458's Avatar
Liked: 813
Agreed. A simple solution is a far better solution then adding a forth subwoofer. FWIW, I'm still trying to find a "simple" solution.
At this time and point, the prospects of a fourth subwoofer or a miniDSP are becoming more and more attractive.
Due to WAF, room treatments are not an option and the addition of a fourth subwoofer is not looking good. The good news, the cheaper solution, a miniDSP, is looking better and better.
post #65 of 71 Old 05-22-2013, 12:56 PM
BeeMan458's Avatar
Liked: 813
And you know this because of your evaluation or due to software based room measurements and are you basing this on a single sitting position or on all the seated positions in the room?
Have you played a 60Hz tone and walked the room, making note of the changes in intensity as you walk the room? The resulting undulations should be dramatic.
post #66 of 71 Old 05-22-2013, 01:03 PM
asere's Avatar
Liked: 319
Based on my evaluation across the room and out of the room. Now that you mention this basically just play 60hz in different areas of the room for music but what HZ for movies?
asere is offline
post #67 of 71 Old 05-22-2013, 01:41 PM
MKtheater's Avatar
Quoted: 1735 Post(s)
Liked: 1303
You can't just play a single tone to calibrate phase. Changing the phase at 60hz could change the phase at another.
Boomy sound is not what low end or deep bass sounds like. My room does not sound anything like a car.
Marantz 7702 Atmos
Outlaw 7140 and 5000
Speakers- DIY mini arrays all channels.
subs 2 XXX ported SLLT.
MKtheater is online now
post #68 of 71 Old 05-22-2013, 01:47 PM
Liked: 1403
post #69 of 71 Old 05-22-2013, 01:48 PM
asere's Avatar
Liked: 319
Mine does not sound like a car either. It is just the deep bass that is too loud for my wife and does not like how it sounds.
asere is offline
post #70 of 71 Old 05-22-2013, 02:54 PM
audiofan1's Avatar
Quoted: 1820 Post(s)
Liked: 1865
Depending on the sub! One sub can sound smooth in the room , this is best dealt with if one takes the context as a whole dedicated room or existing seating position, sub and speaker location and treatments and digital RC. My room falls into the existing category and I can only speak to that end. the steps i've taken to get accurate bass at the listening position takes time and error as I depend on my ears and the nod from the wife to make final setup decisions biggrin.gif My room is almost a perfect cube with a large brick fireplace and two large openings on the right rear and right that leads to the kitchen, dimensions are 20x21x8 , I have the 3 corners bass trapped (2) 24x24 4 inch open back bass traps behind the mains and an GIK 24x48 7 inch monster trap in the rear of the room and a 48x24 4 inch behind the main listening position 6ft away, my sub is a KK DXD12012 in the front right corner 2 inches from the side wall and 6 inches from the back wall as per ken's instructions, I also Audyssey XT32 to dial in the sound along with (2) 48x24 2 inch panels to deal with first reflection points and the front wall behind the display and mains have (3) 24x24 2 inch panels. the end result is smooth bass across the 5 seats and a room favoring 50hz bump is tamed and lower frequencies are as pronounced as the upper bass not to mention seamless integration with the mains center and surrounds! no matter where an effect is placed within the sound field the DXD12012 is there to act as an independent sub for that speaker and even the phantom pans between the speakers wink.gif my two channel is seamless as well ( and also my first priority) So yes depending on the subs ability to produce clean bass upper,mid or lower it can be done with one in the room and get high spouse approval at the same time! not boomy just great bass! wink.gif
audiofan1 is offline
post #71 of 71 Old 05-23-2013, 07:21 AM
asere's Avatar
Liked: 319
I also have the Kreisel 12012. One thing I have never tried is placing it away from a corner. I might sacrifice spl but might be smoother response.
asere is offline
Klipsch Rw 12d 12 Subwoofer Each
