BIC F-12? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 19 Old 05-27-2013, 09:38 PM - Thread Starter
avthokie's Avatar
About to jump the gun on Amazon for $200...any final words of wisdom or hidden deals I should consider?
Denon AVR 3312ci--Samsung pn51e7000--Klipsch RC-62 II--2 Klipsch RF-82 II--Polk fxi-a4 surrounds--Panasonic DMP-BDT300--Xbox 360--PS3--Scientific Atlanta Explorer 8300HDC with TWC--2 Dayton sub 1200's
avthokie is offline
post #2 of 19 Old 05-27-2013, 09:50 PM
Mik James's Avatar
Quoted: 105 Post(s)
Liked: 81
More options:
Dayton Sub 1200: cheaper and probably close in performance.
Bic Venturi cheaper and probably very close performance.
Nxg subs Little more expensive maybe slightly better.
Premier Acoustics subs Pa 10 Compact, stylish likely similar performance and same price.
No bad choices here that I know of.
Mik James is offline
post #3 of 19 Old 05-27-2013, 09:53 PM - Thread Starter
avthokie's Avatar
Originally Posted by Mik James View Post
More options:
Thanks a lot. Compared to what I have I think it would be hard to go wrong. I really wanted the rw-12d but I missed out on the newegg deal.
avthokie is offline
post #4 of 19 Old 05-27-2013, 09:57 PM
Mik James's Avatar
Quoted: 105 Post(s)
Liked: 81
If you have 300$ (I think that's around the newegg deal price for the Klipsch) you might consider the Bic PL-200 and the Premier Acoustic Pa-120 to get close to that level of performance.
post #5 of 19 Old 05-27-2013, 10:03 PM - Thread Starter
avthokie's Avatar
I was considering the PL-200 as well. I was concerned that the RMS on the F-12 was a little low, but heard it was better than higher wattage counterparts such as the the polk 505 and JBL es250.
avthokie is offline
post #6 of 19 Old 05-27-2013, 10:18 PM
Mik James's Avatar
Quoted: 105 Post(s)
Liked: 81
For the F12 vs the Psw505 it seems to depend on who you ask: http://www.avsforum.com/t/1372356/bic-f12-or-psw505
http://www.avsforum.com/t/1459548/polk-psw505-vs-bic-f12-spl-and-clarity-below-30hz
As far as wattage goes 100 watts difference between the f12 and pl-200 is somewhere between 2-3db louder all things being equal. Unfortunately things aren't usually equal and the efficiency spec is more of a tell of overall volume. A few decibels difference on the efficiency spec is a few decibels more spl where as it takes 2x the wattage to add 3db and 10x the wattage to double the volume.
post #7 of 19 Old 05-27-2013, 10:27 PM
caloyzki's Avatar
Quoted: 168 Post(s)
Liked: 46
If you are located at ny area I am selling my klipsch rw12d for local pick up only. I'm buying another Dayton 1200.
caloyzki is offline
post #8 of 19 Old 05-27-2013, 10:31 PM - Thread Starter
avthokie's Avatar
Yeah the 505 is 229.99 and I really have to make a choice. I have a polk currently and agree that mine follows the "underpowered" polk stereotype. I can't argue what some have said about the 505 being clear though. I am primarily a gamer/HT/TV user (music is of little concern to me) and I would rather see the performance matter in an HT setting.
avthokie is offline
post #9 of 19 Old 05-27-2013, 10:33 PM - Thread Starter
avthokie's Avatar
I moved out of theNY area very recently....darn. I am interested if you decide to change your mind and ship. Thanks.
avthokie is offline
post #10 of 19 Old 05-27-2013, 11:05 PM
Mik James's Avatar
Quoted: 105 Post(s)
Liked: 81
2 Dayton Sub 1000's or even Sub 1200's would be another option for you.
200$ for a pair of 1000's and 260$ for a pair of 1200's, unfortunately they don't get mentioned much by the budget sub reviewers on avs so it would be hard to say exactly how well they stack up to the Bics.
post #11 of 19 Old 05-27-2013, 11:10 PM
Splicer010's Avatar
Liked: 39
Heard the BIC and own the 1200 (sister owns actually wink.gif ) and dollar for dollar, the 1200 bests the BIC with its BS claims of 'Peak' power quadruple what the RMS is...rolleyes.gif
Splicer010 is offline
post #12 of 19 Old 05-27-2013, 11:10 PM
Splicer010's Avatar
Liked: 39
Quadruple distortion is what it really is.
post #13 of 19 Old 05-27-2013, 11:28 PM - Thread Starter
avthokie's Avatar
Interesting. I mean I don't have the room for 2 to set-up perfectly, but that doesn't mean I cant get 2 now and wait it out. I want to make a choice I won't be regretting while watching some more action packed blu-rays. I also know that with my budget I can't go crazy, and even if I spend 250 now and save I can still enjoy a sub (or pair) for this money.
avthokie is offline
post #14 of 19 Old 05-27-2013, 11:32 PM
Mik James's Avatar
Quoted: 105 Post(s)
Liked: 81
Um rolleyes.gif the rms power of 120 watts is published on the page and I see no sign of this Peak power figure you mention: http://www.parts-express.com/pe/showdetl.cfm?partnumber=300-629
http://www.hsuresearch.com/products/vtf-15h.html
Power rating for the HSU Vtf15h as seen at the bottom of the product page in the link above.
"Amplifier Power (RMS) 1400 W Short Term, 350 W Continuous"
Now, if you want to talk about this distortion in more detail, describing the respective output of each subwoofer before distortion, the depth/extension that each achieves, and the general quality of sound i'm sure that would be more helpful information.
EDIT: Unless of course I read your post wrong and you we're actually talking about the Bics "Peak" power, in which case I would owe you an apology tongue.gif
In any case the Bics peak is only listed as 475 with an rms of 150 clearly listed in the specs as is common practice among speaker manufacturers. If they only listed peak power then that would certianly make them dishonest, but that's not the case.
post #15 of 19 Old 05-27-2013, 11:49 PM - Thread Starter
avthokie's Avatar
I am having a hard time find the peak for the Dayton sub-1200...but right now I am probably going to get 2 1200's and just make some space for the both of them.
avthokie is offline
post #16 of 19 Old 05-28-2013, 08:45 AM
Splicer010's Avatar
Liked: 39
The ONLY reason to post peak specs for an amp is to give it the illusion of being more capable than it really is...
post #17 of 19 Old 05-28-2013, 11:55 AM
Mik James's Avatar
Quoted: 105 Post(s)
Liked: 81
A very cost effective choice in my opinion, as long as you don't care about aesthetics and space 2 1200's should walk all over 1 Bic f 12 for only 25% more money.
And don't worry about power ratings so much, they are only 30 watts apart if they we're both measured exactly the same (unlikely) and one of them could be at least a few decibels more efficient than the other.
post #18 of 19 Old 05-28-2013, 07:00 PM - Thread Starter
avthokie's Avatar
I appreciate the help! I am excited about the set-up now. I have heard very good things from the small amount of reviews out there are on the Daytons. They most likely will be hidden from direct sight so i am not too worried about aesthetics, and my speakers are all similar color so it will go together. Again, thanks a lot. I will post some final pics when I am done.
avthokie is offline
post #19 of 19 Old 05-29-2013, 07:59 AM
Splicer010's Avatar
Liked: 39
The looks of the 1200 are nice. Rounded corners...folks just are not used to the round grill (saves costs on materials) is all. They are indeed VERY nice looking! cool.gif
