Dayton Titanic Mk III Subwoofer's have been discontinued - now what;) - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 43 Old 06-08-2013, 08:57 AM
steve nn's Avatar
Liked: 433
Originally Posted by GusGus748s View Post
I meant I want to do a porter DIY, but I've got to concerns. 1) I've never done one. 2) It might not blend well with my current KLipsch RW-12D.
No I’m afraid it would not, but you would come up with a much better sub though. You could sell the 12D after you built the DIY to help with funds if that’s a concern. As far as being able to do it, admittedly first time around has the steepest learning curve but they're plenty over in the DIY section that would be willing to help. I know I would notice your thread. It’s not close to as hard as you might think. .. it’s easy to keep things simple.
Klipsch RB-75
Klipsch C-7
Klipsch RB-35
On-going SW management class
Denon
PS3
steve nn is offline
post #32 of 43 Old 06-08-2013, 09:02 AM
Jay1's Avatar
Quoted: 236 Post(s)
Liked: 220
+1
Even a basic $250 build will make you want to sell your Klipsch.
Jay1 is offline
post #33 of 43 Old 06-08-2013, 09:29 AM
GusGus748s's Avatar
Quoted: 421 Post(s)
Liked: 703
Originally Posted by Jay1 View Post
+1
I've been pricing everything up, and this is what I come up with:
DIY Ported 4 cuft flat pack $120
http://www.diysoundgroup.com/subwoofer-flatpacks-2/ported-subwoofer-flatpacks/4-ported-sub-flat-pack.html
Dayton Audio RSS315HO-4 12" Reference HO Subwoofer 4 Ohm $150.00
http://www.parts-express.com/pe/showdetl.cfm?partnumber=295-466
Amp wise, I am not sure. Since the DIY box doesn't come pre-cut for a plate amp. So, I am not really sure what amp should be the best to use.
GusGus748s is offline
post #34 of 43 Old 06-08-2013, 10:08 AM
Jay1's Avatar
Quoted: 236 Post(s)
Liked: 220
That flat pack is great, but that does drop the value of a budget build compared to a $35 sheet of MDF. You should be able to fit the king of budget drivers, with maybe only some light sanding to the cutout.
http://www.amazon.com/Infinity-Reference-1260w-1200-watt-High-Performance/dp/B0028AVGEO/ref=sr_1_1?s=electronics&ie=UTF8&qid=1370710912&sr=1-1&keywords=1260w
You can also ask Eric to make a cutout for a specific plate amp, he doesn't have one pre-cut because every amp is different. This amp will do good with the Infinity
http://www.parts-express.com/pe/showdetl.cfm?partnumber=300-750
Of course that Dayton RS 12" HF with a 500 watt amp will work well in that box to.
http://www.parts-express.com/pe/showdetl.cfm?partnumber=295-464
http://www.parts-express.com/pe/showdetl.cfm?partnumber=300-752
Jay1 is offline
post #35 of 43 Old 06-08-2013, 01:31 PM
steve nn's Avatar
Liked: 433
Eric does wonderful work if you decide the half DIY approach. His enclosures are very well braced and easily put together. I see you have a thread over in the DIY section... Going the 15” rout would be even better as long as everything pertaining is kept in mind. A good 12” powered correctly in the rite enclosure can take out a 15”. You’re on the rite track imo.
Klipsch RB-75
Klipsch C-7
Klipsch RB-35
Denon
PS3
steve nn is offline
post #36 of 43 Old 06-12-2013, 05:31 PM
Jon S's Avatar
Quoted: 897 Post(s)
Liked: 281
Parts Express has the Titanic Mark IV listed online... It's supposed to be available mid-July...
http://www.parts-express.com/pe/showdetl.cfm?partnumber=295-403
If it's not a BIG screen, it's not a theater...
Jon S is offline
post #37 of 43 Old 06-12-2013, 05:43 PM - Thread Starter
scottvamp's Avatar
Liked: 31
Well that's interesting. Looks exactly the same though. Already bought the Ultimax and really like the their look and they sound great. But I may have to start over and get a sealed dual 12" box. Any suggestions on that would be great.
scottvamp is offline
post #38 of 43 Old 07-02-2013, 06:31 PM - Thread Starter
scottvamp's Avatar
Liked: 31
Just spent a half hour getting anyone still interested up to date and the pics glitch the system and I waste all my time - anyway, went sealed and they rock.......... eek.gif
GusGus748s likes this.
post #39 of 43 Old 07-02-2013, 06:34 PM
GusGus748s's Avatar
Quoted: 421 Post(s)
Liked: 703
Nice. I like that dual set up.
scottvamp likes this.
post #40 of 43 Old 07-02-2013, 07:12 PM
steve nn's Avatar
Liked: 433
Klipsch RB-75
Klipsch C-7
Klipsch RB-35
Denon
PS3
steve nn is offline
post #41 of 43 Old 07-02-2013, 07:23 PM - Thread Starter
scottvamp's Avatar
Liked: 31
Thanks Steve, gonna do that this week;)
post #42 of 43 Old 07-09-2013, 12:34 AM
steve nn's Avatar
Liked: 433
Would love to see a pic of what you come up with..
Klipsch RB-75
Klipsch C-7
Klipsch RB-35
Denon
PS3
steve nn is offline
post #43 of 43 Old 09-28-2013, 10:31 AM - Thread Starter
scottvamp's Avatar
Liked: 31
I just put the SVS amp in a simple box and painted it black. I ended up corner loading the two subs. I am sure I could do much more tweeking, but I am happy with the output. But something tells me I should have put more acoustic stuf in the Dayton box.
Svs Pb13 Ultra , Dayton Audio Tit400c 4 15 Titanic Mk Iii Subwoofer 4 Ohm
