Dayton Titanic Mk III Subwoofer's have been discontinued - now what;) - AVS Forum | Home Theater Discussions And Reviews
Old 05-29-2013, 06:52 PM - Thread Starter
scottvamp's Avatar
Liked: 31
Hi, I am new to the forum. Have been following the Tekton thread for abit. I have recently diy'ed a SVS PB2 Plus subwoofer. I used the 12.2's that were in one that I use to own. But the amp I used for my project was out of an SVS PB2 Ultra and seems to have more power. I would like to replace the drivers because on movies, I can only turn the amp volume up to 1.5 and I get a "chuffing" sound at stronger low bass notes. I have tried plugging different ports with no luck. Receiver gain is between 0 and -5. I am guessing I need higher power drivers. I have it paired with an SVS PB13-Ultra.
My question is, what and where are you guys using and buying drivers????
I need a 12", single coil, 4 ohm, high power and excellent sound quality. I heard good things about the Dayton Titanic Mk III Subwoofer's. They have been out of stock at Parts Express for 3 months and now just before stocking date I got an email that they are discontinued. The only other option would be the Dayton reference HO subwoofer. Can anyone testify to the quality of this driver? They have a power range of 700/1400 watts. I think $150 each seems like a fair price. Any recommendations would be appreciated. I watch 50% Movies & Music. Want to stay under $200 a driver. Here are some picks of the sub I built. Thanks, Scott
scottvamp is offline
Old 05-29-2013, 07:23 PM
Bill Fitzmaurice's Avatar
Liked: 4629
Chuffing is caused by insufficient port area. Plugging ports will only make matters worse, as that reduces port area.
Watts mean little. T/S specs mean everything. There are many twelves with similar specs to the Titanic, but if the Titanic specs aren't compatible with your cabs that's moot. And different drivers won't cure chuffing.
Bill Fitzmaurice is offline
Old 05-29-2013, 07:26 PM
fish323's Avatar
Quoted: 18 Post(s)
http://www.parts-express.com/pe/showdetl.cfm?partnumber=295-512
I would assume the Ultimax is the Titanic's replacement, that has an improved motor & looks much better IMO.
fish323 is offline
Old 05-29-2013, 07:45 PM - Thread Starter
scottvamp's Avatar
Liked: 31
Originally Posted by Bill Fitzmaurice View Post
Thanks fish323. I missed those because I used 4 ohm only in my search. That makes since. Those Ultimax's look awesome.
Hi Bill, this is an exact box and ports of the SVS model. I have three 4" ports. That should be enough for port area. Is there something I am missing? Maybe to much acoustic foam stuffing. I put in 3lbs through out the inside of the box. Any help would be appreciated.
Old 05-29-2013, 07:47 PM - Thread Starter
scottvamp's Avatar
Liked: 31
Thanks fish323. I missed those because I used 4 ohm only in my search. Those Ultimax's look awesome.eek.gif
Old 05-29-2013, 07:56 PM
steve nn's Avatar
Liked: 433
They are but I think they might take/want a little larger enclosure.
Klipsch RB-75
Klipsch C-7
Klipsch RB-35
On-going SW management class
Denon
PS3
steve nn is offline
Old 05-29-2013, 08:16 PM
Liked: 4629
Hi Bill, this is an exact box and ports of the SVS model. I have three 4" ports. That should be enough for port area..
Not necessarily. If it chuffs, it isn't for the power you're putting into it. But it also could be a warning sign that you're just pushing it too hard.
That doesn't mean they will work better, or even as good as, what you have, or if they will even work in your cabinet. Chances are they won't, Qes/Qts is way too high for best results in a ported cab.
Old 05-29-2013, 08:23 PM - Thread Starter
scottvamp's Avatar
Liked: 31
OK - I will have to figure out this "chuffing" problem and I might not need them.... for now;) The box is about 7 cubic feet with ports and drivers. They request 4 not including driver and ports. So I should be in the ballpark. I used 1 lbs of acoustic foam per 2 cubic feet. Not sure if that is a problem.
Old 05-29-2013, 08:35 PM
Liked: 4629
Why? Vented cabs should not be stuffed, only lined, with an inch or two of damping.
Old 05-29-2013, 08:57 PM
Jay1's Avatar
Quoted: 236 Post(s)
Liked: 220
You said your box is 7 ft3, and has three 4" ports. What are the port lengths?
Does the amp have the feature quoted below
- 4 Position Tune Switch (25 Hz, 20 Hz, 16 Hz, Bypass)
Which setting do you have it on?
Also, how do you have the PEQ set?
Right off the bat I will say to open all ports, put the tune switch to 25hz and give it a try. If that's what you have been doing already, then set the PEQ to 20hz, the Q to "high", and the "level" to the mid position and give it a try.
Jay1 is offline
Old 05-29-2013, 10:48 PM - Thread Starter
scottvamp's Avatar
Liked: 31
The box is not stuffed for say. It IS lined on all six sides.
Hi Jay1, I am plugging one port right now and set to 20hz. At first all ports were open at 25hz. Everything I have tried so far has produced chuffing noise at high levels. But I have yet to turn the amp up past 3.5 for even music. I need to play around with other settings. I will give your suggestion a try. The PEQ is set to off. My SVS PB13 Ultra has more settings than I even know what to do with - lol
I have done some reading and I seem to be doing everything right as for a flared ports and length. I do seem to be driving the subs hard, but the "level" is only at 1.5 for movies. I have just ordered a pair of Dayton Ultimax 12's. Parts express has a no question asked 45 day return policy. This amp was made for the SVS Ultra drivers. Not sure if it has more power than the amp used with the plus drivers.
Old 05-29-2013, 11:47 PM
Jay1's Avatar
Quoted: 236 Post(s)
Liked: 220
Well, I can tell you right now, the Ultimax 12's will not work very well ported in that box. They will work pretty well SEALED in that box. That will also remove your chuffing issue.
Like Bill already pointed out, the drivers dont really have anything to do with the chuffing.... Are you sure your box is sealed up air tight, including where the ports are mounted?
Jay1 is offline
Old 05-30-2013, 08:58 AM
Liked: 4629
But I have yet to turn the amp up past 3.5 for even music.. the "level" is only at 1.5 for movies.
The setting of the volume control does not indicate how much power is being output. Google 'gain staging'.
Old 05-30-2013, 10:44 AM - Thread Starter
scottvamp's Avatar
Liked: 31
I am running 2 subs so the gain gets a little more tricky. I ran the calibration on my Onkyo 818. I may end up going the sealed route. I will do some more different configurations this evening. Yes, the box is sealed well, matter of fact, I get a small noise from the air coming out of the holes on the RCA inputs on the amp - lol
Old 05-30-2013, 06:09 PM - Thread Starter
scottvamp's Avatar
Liked: 31
I tried your the PEQ settings Jay1, opened all ports and it helped to get more spl before "chuffing" comes into play but now I have noticed the "chuffing" sound is coming for the drivers themselves. One more than the other. They have been used for few years and have been packed away for this project.
Should the chuffing sound come directly from the ports or from the drivers. At lower volumes they sound great. I might just be over driving them. Though they are not bottoming out.
Old 05-30-2013, 06:33 PM
Jay1's Avatar
Quoted: 236 Post(s)
Liked: 220
There definitely shouldn't be anything resembling a chuffing sound from the drivers, that's strange...
Do you have gasket foam type material on the back of the drivers?
Jay1 is offline
Old 05-30-2013, 06:54 PM - Thread Starter
scottvamp's Avatar
Liked: 31
Yes, there is gasket foam on the drivers, amp and ports. When I push on the drivers, they are nice and smooth, no scratching.
Old 05-30-2013, 07:05 PM
Jay1's Avatar
Quoted: 236 Post(s)
Liked: 220
There's something not right going on? You should not have audible port noise with that peq on at all.
Jay1 is offline
Old 05-30-2013, 07:42 PM - Thread Starter
scottvamp's Avatar
Liked: 31
I don't hear the noise from the ports when I put my ear close to them. It seems to come from the drivers. Three 24" dual flared 4" ports, and an identical size box that the drivers were originally in, SVS PB2-Plus. My subs are placed on the front stage, about a 1/4 in from the corners. It was the most popular placement for duals. Ports are facing up.
Old 06-06-2013, 02:14 PM - Thread Starter
scottvamp's Avatar
Liked: 31
The Dayton Ultimax sub's came in yesterday. They are really nice looking subwoofers. Gonna install them tonight......
Old 06-06-2013, 02:27 PM
steve nn's Avatar
Liked: 433
COOL! Will be looking forward to your impression's. Oh and don’t forget pic’s. Are you able to measure and graph your system?
Klipsch RB-75
Klipsch C-7
Klipsch RB-35
Denon
PS3
steve nn is offline
Old 06-06-2013, 02:37 PM - Thread Starter
scottvamp's Avatar
Liked: 31
Hi Steve, no sorry no way to measure. The theater is in an open floor concept space also. Will post pic's tonight:)
Old 06-07-2013, 06:02 PM - Thread Starter
scottvamp's Avatar
Liked: 31
Sorry guys, tried to post sooner with my iPhone and was having trouble.
I was following the Tekton thread and have really been put off.....
I installed the Dayton's and the mounting holes had to be opened up at least a 1/4 inch. So far, the subs are really deep and clean. The build quality is excellent and the cone area is bullet proof.
I am getting the same sound of chuffing but at a higher spl. I have sealed all three ports and like the bass I am getting. I now think I am getting air turbulence from my internal bracing.
Going to maybe keep the svs drivers for another project unless anyone wants them.
The Ultimax's look fantastic!!!
Old 06-07-2013, 06:04 PM - Thread Starter
scottvamp's Avatar
Liked: 31
And the black box:) time to break them in this weekend!!!!
Old 06-08-2013, 12:13 AM
steve nn's Avatar
Liked: 433
Klipsch RB-75
Klipsch C-7
Klipsch RB-35
Denon
PS3
steve nn is offline
Old 06-08-2013, 03:08 AM
GusGus748s's Avatar
Quoted: 414 Post(s)
Liked: 699
That's one big box! I'm thinking of going with a DIY set up too. I'm kind of nervous about it since I've never done one.
GusGus748s is online now
Old 06-08-2013, 05:58 AM
steve nn's Avatar
Liked: 433
Oh! Are you thinking sealed or vented? That’s always a great option if a guy cares to take it on.
Klipsch RB-75
Klipsch C-7
Klipsch RB-35
Denon
PS3
steve nn is offline
Old 06-08-2013, 07:55 AM
GusGus748s's Avatar
Quoted: 414 Post(s)
Liked: 699
Vented/Porter!
Old 06-08-2013, 08:19 AM
steve nn's Avatar
Liked: 433
Vented/Porter!
Your 12D has a port, (vented) that's the tube at the front bottom or your unit. Sealed has no port.. the unit is totally enclosed. I think that's what you're asking?
Klipsch RB-75
Klipsch C-7
Klipsch RB-35
Denon
PS3
steve nn is offline
Old 06-08-2013, 09:26 AM
GusGus748s's Avatar
Quoted: 414 Post(s)
Liked: 699
I meant I want to do a porter DIY, but I've got to concerns. 1) I've never done one. 2) It might not blend well with my current KLipsch RW-12D.
Svs Pb13 Ultra , Dayton Audio Tit400c 4 15 Titanic Mk Iii Subwoofer 4 Ohm
