Best Subwoofer for $350 or less (Large room) - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 41 Old 06-03-2013, 07:21 AM
BeeMan458's Avatar
Liked: 813
Originally Posted by steve nn View Post
Okay, one more:
If a subwoofer system were a trumpet, our subwoofer system would be a piccolo that thought it was a clarinet.
BeeMan458 is offline
post #32 of 41 Old 06-03-2013, 04:44 PM - Thread Starter
screeli's Avatar
i stepped away from my computer and bam...look at these replies!
well thanks everyone for paying attention to my desperate needs. after reading through i think the consensus is, that the JBL's add a bit too much risk, the energy is too low voltage, and the PA-150 is worth the extra few dollars. my new options are below, which are starting to bang the budget a bit, but I'm open to the conversation...
Options:
1 - PA-150 ($373 after shipping) http://www.amazon.com/gp/offer-listing/B004436EEU/ref=dp_olp_new?ie=UTF8&condition=new
2 - Klipsch Rw-12 ($350) http://www.newegg.com/Product/Product.aspx?Item=N82E16882780078&nm_mc=KNC-GoogleAdwords&cm_mmc=KNC-GoogleAdwords-_-pla-_-Home+Audio+Speakers-_-N82E16882780078&gclid=CNWh-fL5yLcCFYVZ7AodOmkA9w
Like i said before, the room is quite large with allot of volume. also, I'm mostly watching movies so the lows that rattle the room are what we're looking for, not necessarily the best overall performer. So what will it be, Option 1 or Option 2..?
thanks again!
screeli is offline
post #33 of 41 Old 06-03-2013, 04:55 PM
Mik James's Avatar
Quoted: 105 Post(s)
Liked: 81
Option 2 when it goes on sale for around 300$ (frequently) or Option 1 if you can't wait.
I'd be interested to know myself the failure rate of that particular Jbl. I don't recall any links to that info being posted in this thread?
Edit: http://www.amazon.com/JBL-ES250PBK-High-Performance-12-Inch-Subwoofer/product-reviews/B00166ZFSO/ref=dp_top_cm_cr_acr_txt?ie=UTF8&showViewpoints=1
It does indeed seem to fail quite often.
Mik James is offline
post #34 of 41 Old 06-03-2013, 05:03 PM
Bond 007's Avatar
Quoted: 2375 Post(s)
Liked: 1911
The Amazon reviews will give you an idea.
Licence to Kill
Bond 007 is online now
post #35 of 41 Old 06-03-2013, 05:16 PM - Thread Starter
screeli's Avatar
yea, i went to amazon myself and read i think 11 reviews specific to failure within only a matter of years. in most cases they were 4-6 years ill admit, but if im going to spend $200 in high risk, i might as well spend $100-150 more and get a better sub with Much less risk of failure.
screeli is offline
post #36 of 41 Old 06-03-2013, 07:59 PM
PcGeek626's Avatar
I have had my JBL ES 250p for a year,
no issues at all...  Just thought id share that :)
Hsu Research HB-1 MK2
Hsu Research Hc-1 MK2
Hsu Research VTF3 mk4 12" subwoofer
PcGeek626 is offline
post #37 of 41 Old 06-05-2013, 01:05 PM
Rob Morse's Avatar
Quoted: 106 Post(s)
Liked: 41
If you are open to a Factory Refubished model, then I could suggest another option from Velodyne that might fit your requirements in performance and price.
When in comes to audio there are seldom right and wrong answers.  The opinions of "experts" are just that, and should be used as a suggestion only.  Remember at the end of the day it is your money, your system, and you will need to listen to it.
Rob Morse is offline
post #38 of 41 Old 06-05-2013, 03:11 PM
Bond 007's Avatar
Liked: 1911
Jump on it. Rob wont treat you wrong.
Licence to Kill
post #39 of 41 Old 06-06-2013, 12:29 AM
Rob Morse's Avatar
Quoted: 106 Post(s)
Liked: 41
Thanks - The VDR-12 subwoofer is on special for $249 (specs)
post #40 of 41 Old 06-06-2013, 02:36 AM
Bond 007's Avatar
Liked: 1911
Still get the 3 year-5 year warranty?
Licence to Kill
post #41 of 41 Old 06-06-2013, 09:08 AM
Rob Morse's Avatar
Quoted: 106 Post(s)
Liked: 41
Velodyne provides a standard 2 year warranty on all subwoofers.
Pioneer Sc 1222 7 2 Channel Network Ready Av Receiver , Jbl Es80bk 3 Way Dual 6 1 2 Floorstanding Speaker Black , Jbl Studio 120c Dual 4 Inch Center Channel Loudspeaker Limited Edition Black , Onkyo Sks Ht540 7 1 Channel Home Theater Speaker System , Jbl Sub150p Sudio 1 300 Watt Sub Woofer , Jbl Es250pbk 12 Inch Subwoofer Black , Energy Energy Power 12 Sub 12 Inch Front Firing Rear Ported Subwoofer , Martinlogan Dynamo 300 Home Theater And Stereo Subwoofer , Klipsch Rw 12d 12 Subwoofer Each
