Fixing an Epik Legend Subwoofer - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 05-31-2013, 08:16 PM - Thread Starter
usbud's Avatar
I'm having the same issue other Epik Legend owners have had - fuses blowing constantly. I've attempted to contact Epik but have had no luck yet. I will keep trying but in the meantime does anyone know how to fix the issue. I don't want to have to purchase an entire new Sub so am wondering if I can keep the cabinet/speakers themselves and just replace the electronics (amp/driver?). Anyone? Thanks.
usbud is offline
post #2 of 7 Old 05-31-2013, 08:26 PM
steve nn's Avatar
Liked: 433
Read the last 5-10 pages or so. http://www.avsforum.com/t/885079/official-epik-subwoofer-thread
Klipsch RB-75
Klipsch C-7
Klipsch RB-35
On-going SW management class
Denon
PS3
steve nn is offline
post #3 of 7 Old 05-31-2013, 09:04 PM - Thread Starter
usbud's Avatar
So can I use a Yung SD300 plate amp to replace the one in the Epik Legend.
http://www.parts-express.com/pe/showdetl.cfm?partnumber=301-510
usbud is offline
post #4 of 7 Old 05-31-2013, 09:11 PM
steve nn's Avatar
Liked: 433
Post that question over there and I'm sure you will get a answer, or a amp that will work.
Klipsch RB-75
Klipsch C-7
Klipsch RB-35
Denon
PS3
steve nn is offline
post #5 of 7 Old 06-01-2013, 12:36 PM
deepat04's Avatar
Quoted: 94 Post(s)
Liked: 94
+1 to Steve nn...read thu last few pages of epik thread should find what your looking for.
deepat04 is offline
post #6 of 7 Old 06-01-2013, 12:58 PM
Tom Vodhanel's Avatar
Quoted: 2059 Post(s)
Liked: 6058
Do you have a DMM(multi meter?). If so, check each driver at the binding post before anything else. If one of the drivers has an issue, (which caused your amp to fail) it may cause the next amp to fail immediately too. If you don't have a DMM you can find cheap ones for like 15 bucks at sears, walmart, etc. Use the resistance mode on the DMM and make sure both drivers are showing about the same.
Tom V.
“Quality isn't expensive, it is priceless" --- fortune cookie
Tom Vodhanel is offline
post #7 of 7 Old 06-01-2013, 04:34 PM
steve nn's Avatar
Liked: 433
Tom V.
Hi Tom.. I posted your reply for you over in the epik Thread in case usbud does not return. I see he did go over there. Good advice as always.
Klipsch RB-75
Klipsch C-7
Klipsch RB-35
Denon
PS3
steve nn is offline
