Sub distortion...a good thing? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 06-02-2013, 12:20 PM - Thread Starter
Saturn94's Avatar
Quoted: 139 Post(s)
Liked: 468
I recently read this on Audioholics;
.... Higher-order and/or odd-order harmonics have progressively lower allowable distortion limits, as these tend to subjectively be more offensive to the human ear than lower order and/or even-order harmonics. I have personally seen, as far back as the early 1990's from my own research as a subwoofer system designer for Miller & Kreisel Sound, that we often could "tweak" a compressor in such a way where we found the result more musical and pleasing, yet the THD as measured by some very expensive and reliable HP equipment would actually go up as a percentage of the output. In my own personal experience, this was almost always a trade-off for more low harmonics (notably second or third) for less higher harmonics (fourth or higher)....
If I'm reading this correctly, low order sub distortion may actually make the sub sound more pleasing?
I'm currently shopping for a sub and thought the lower the distortion the better, but this seems to indicate that some low order distortion may actually be desirable.
I'd appreciate some feedback from those who know much more about this than me (I know next to nothing about it wink.gif ).
Saturn94 is offline
post #2 of 5 Old 06-02-2013, 12:36 PM
mbfleming's Avatar
Liked: 52
Distortion is bad if you care about fidelity.
I got some good responses to a similar question three years ago:
http://www.avsforum.com/t/1299983/the-problem-of-distortion
mbfleming is offline
post #3 of 5 Old 06-02-2013, 01:52 PM
shadyJ's Avatar
Quoted: 1330 Post(s)
Liked: 1352
A lot of good points were made in that thread, it was a pretty good discussion. Josh Ricci also had some interesting comments about distortion about a week ago here. This is why I say that the component distortion charts in subwoofer tests are more important than THD tests. Second Order Harmonic Distortion can comprise a large part of THD tests, but it can hardly even be heard unless it is really bad (even then, it will probably be masked by other sounds being played). A lot of people even prefer the sound of some harmonic distortion. Some subs are mistakenly perceived as more articulate because they are mistakenly producing higher frequency sounds, and since higher frequency sounds are more easily discerned, they are erroneously thought to have more definition.
Everything being equal, I would rather my subs have no distortion, however if I see a moderate amount of lower order harmonic distortion in subwoofer tests, I do not regard that as a big deal.
shadyJ is offline
post #4 of 5 Old 06-02-2013, 02:11 PM
Bill Fitzmaurice's Avatar
Liked: 5687
Most of what you read there applies to mains, not subs. The main issue with subs with high THD is that the harmonics heard may be well above the nominal sub pass band, and would be directionally locatable.
Bill Fitzmaurice is offline
post #5 of 5 Old 06-02-2013, 02:14 PM - Thread Starter
Saturn94's Avatar
Quoted: 139 Post(s)
Liked: 468
Thanks for the link. I'll check out that thread.
I do care about fidelity up to the point where it results in a system I enjoy. However, I'm learning that fidelity doesn't always equal enjoyment. And isn't enjoyment the ultimate goal? wink.gif
Thanks for the info. I'm certainly learning things I had no clue about when I bought my current sub (SVS 16-46PC+) ten years ago.
Saturn94 is offline
